Arc Ok Problem
- phillc54
- Thank you received: 2100
25 Feb 2024 05:37 #294336
by phillc54
Replied by phillc54 on topic Arc Ok Problem
From what I can gather, the error is no arc-ok, is that correct?
If so then we need to find out why there is no arc-ok.
- acourtjester
- Thank you received: 29
25 Feb 2024 05:47 - 25 Feb 2024 05:49 #294337
by acourtjester
Replied by acourtjester on topic Arc Ok Problem
I have looked at the Arc Ok signal in Hal show and can see it trigger when the Plasma fires. the error I get is about the material 1000000
At first it seemed the Arc Ok was not getting through and it would not get past the torch fire at the start. I turned off Auto Volts and then it would fire the torch and then continue on to the next operation. As seen in the center punching video it runs like all is ok.
But when I try to run the G-code to fully cut the parts it fails right at the first cut start.
Last edit: 25 Feb 2024 05:49 by acourtjester.
- phillc54
25 Feb 2024 05:53 #294338
by phillc54
Is your QtPlasmaC version up to date?
Can you open the SETTINGS TAB then click the BACKUP button and post the resulting file here.
- acourtjester
25 Feb 2024 06:01 #294340
by acourtjester
No it is not I did a complete reinstall with bookworm and the QTPlasmaC but that is on another computer. I have not copied the new disc to the table computer yet. When I first install linuxcnc on the table computer it did cut without a problem.
I when off and switched the table to do router work and was using Axis for that.
Now switched back to plasma and QTPlasmaC and it has problems. I wanted to get these parts cut before switching to the newer bookworm.
- acourtjester
25 Feb 2024 06:20 #294341
by acourtjester
I found this while looking around
Ignore Arc OK mode disables the THC, will begin a cut without requiring an Arc OK signal, and will ignore a lost Arc OK signal during a cut.
This mode can be selected by:
Checking the Ignore Arc OK check button in the CONTROL section of the MAIN Tab.
- acourtjester
26 Feb 2024 18:45 - 26 Feb 2024 18:47 #294542
by acourtjester
Ok my fire is out for now I clicked on ignore Arc Ok and no THC and I was able to cut the parts I needed. My next step is a complete new download and reconfigure the controller software. I will be following a post here recommended by a member on PS which should give me the newer version of QTPlasmaC
Thanks for your time. video of the cutting
drive.google.com/file/d/1mTytmUI8LUFoJ-7.../view?usp=drive_link
Last edit: 26 Feb 2024 18:47 by acourtjester.
Time to create page: 0.108 seconds
