Changing material but spot not working.. maybe a bug ot it's me?
24 Feb 2024 00:26 - 24 Feb 2024 00:45 #294148 by jazzkramer
I opened another file: the error is consistent:
First physical part is OK.
From the second physical part (after line 92 in my file) to the last one, ALL center spots tiny moves get changed to a bigger move, causing the error.
I really do not understand how it is possible, it's a really strange behaviour.
And please note in the first part the tiny moves are correct. From the second physical part only they are wrong, changed.
It looks to me like an overflowing variable/memory location, transforming a floating point number in a negative one or something like that.. but why it is not happening to the first Center Spots? It is happening only if before the Center Spots I already cut normal lines.
I installed LinuxCNC by the ISO, ver 2.9.1 some month ago (but I did not cut nested parts with nested center spot). I "apt updated/upgraded" not more 10 days ago. So LinuxCNC got upgraded so I'm now using QtPlasmaC v2.9.236.301
If no one get my error I will reinstall new from the ISO and hope the problem goes away.
Last edit: 24 Feb 2024 00:45 by jazzkramer.
24 Feb 2024 01:30 #294158 by phillc54
All good here.
If you are using a buildbot package can you do an update and see if that changes things.
Warning: Spoiler!
24 Feb 2024 01:48 #294162 by jazzkramer
Thanks again, so I sure need to upgrade again.
I installed using the ISO, but I will check other methods.
Here i posted a video of the error if someone want to check it, (and sorry, my spoken English is a lot worse than my written one !!)
Thanks again for helping me. I hope upgrading the problem will go away,
Alberto.
24 Feb 2024 02:57 #294165 by phillc54
I have tried with different locales and I still cannot see any errors.
Can you load one of the files then click the "EDIT" button and see if all the "tiny move" are the same as what is in the G-code display.
24 Feb 2024 11:30 - 24 Feb 2024 11:37 #294189 by jazzkramer
In the edit all tiny moves are correct:
I saved it, rewriting the same file, but in the code display it remains wrong...
Some days ago I made #sudo apt upgrade && sudo apt update, so some libraries were updated, as well as LinuxCNC itself.
Maybe an updated library used in the code display and not in the edit display has something wrong or not compatible...
Last edit: 24 Feb 2024 11:37 by jazzkramer.
24 Feb 2024 11:35 #294191 by phillc54
That is weird, I have no idea what is happening.
Do you have a file named custom_filter.py in your configuration directory?
24 Feb 2024 11:51 - 24 Feb 2024 11:52 #294196 by jazzkramer
No, I only have custom.hal and custom_postgui.hal.
The second one is empty (only a comment inside).
Today I will do a fresh install again and check if the problem goes away.
Last edit: 24 Feb 2024 11:52 by jazzkramer.
24 Feb 2024 11:53 #294199 by phillc54
What locale is your system set for?
24 Feb 2024 12:02 #294202 by jazzkramer
I see the clock is 3 hours late (no internet connection) but I don't think could be the cause of the problem...
24 Feb 2024 14:33 - 24 Feb 2024 14:35 #294215 by jazzkramer
So, follow up, I discovered something, maybe this could happen in other cases too, so, maybe it's of interest:
resume: if I change the preceding line of the tiny move from G91 to G90 (I said reversed in the video!) the tiny move line get displayed correctly in the code display.
(of course the code modified this way cannot be used because it's incorrect).
BUT the G91 is doing something in the "code parsing process"...?
Here the video:
Last edit: 24 Feb 2024 14:35 by jazzkramer.
Time to create page: 0.887 seconds
