New set of problems
2 years 5 months ago #300789 by phillc54
Replied by phillc54 on topic New set of problems
Thanks, the one I am looking for is 41624test_V2.10-005.033_24-05-15_08-30-08.tar.gz
I will check it out later today.
2 years 5 months ago - 2 years 5 months ago #300790 by acourtjester
Replied by acourtjester on topic New set of problems
File Name: 41624test_...05-16.gz
File Size:15.1 KB
hope this is it    I think I miss understood the above reply,  was that info in the above reply I sent to you??
Last edit: 2 years 5 months ago by acourtjester.
2 years 5 months ago #300797 by phillc54
The reason that you are getting the  "invalid material number" warning is because you have  materials #1000000 and #1000001 in your materials file (41624test_material.cfg). They both need to be deleted.
Warning: Spoiler!
I cannot find an obvious (to me) reason for the THC issue that you are having.
It is probably worth trying a cut with the VAD Threshold set to 905 rather than the current 64%.
If that doesn't help then try a cut after checking the Auto Activate checkbox.
The following user(s) said Thank You: acourtjester
2 years 5 months ago #300826 by tommylight
Replied by tommylight on topic New set of problems
What is the THC delay set to?
Seems like being quite long so THC is not active till near the end where it activates and plunges.
2 years 5 months ago #300833 by acourtjester
In the material number I select in the G-code and manually before the cut it is 0.2.
Which I assume is 0.2 seconds. That should be way before the last part of the cut I was making.
2 years 5 months ago #300843 by tommylight
Not pierce delay, there is also THC delay and that can be causing this, as the THC will remain inactive during that time.
Time to create page: 0.070 seconds
