New set of problems
- acourtjester
- Thank you received: 29
14 May 2024 21:14 - 14 May 2024 21:16 #300610
by acourtjester
New set of problems was created by acourtjester
HI
I am getting the "invalid material number" again, last time you said make sure Default material =1 and it is.
Next for some reason there is a problem at the end of a cut, the torch seems to be at a good height until just before the end and it dives. These images show it both top and bottom shown.
Next the material info seems to be reset to 10000001: temporary 10000001 after it cuts. Before the cut I set it to one from the list.
one other question is should I run the Latency test before I do anything at the start?? I am running version V2.10-005-033
Thanks for your time
Tom
Tom
Last edit: 14 May 2024 21:16 by acourtjester.
- phillc54
- Thank you received: 2100
15 May 2024 02:46 #300639
by phillc54
Replied by phillc54 on topic New set of problems
Can you post the g-code file for the above cut and also the BACKUP from the SETTINGS tab.
The following user(s) said Thank You: acourtjester
- acourtjester
15 May 2024 13:53 #300681
by acourtjester
Replied by acourtjester on topic New set of problems
Thanks for the reply, attached are the g-code and .job file from SheetCam and the file I think is the backup you want.
No expert on G-codes but cannot see any reason for the cut to end as it does. It does not give an error just acts like it is finished.
- phillc54
16 May 2024 00:30 #300709
by phillc54
- acourtjester
16 May 2024 13:23 #300738
by acourtjester
I did click on that but could not find where it was stored to copy and send.
Sorry I will try again, here are 2 other files from that date are either the one you are looking for??
config_info.txt
config_info.txt
- acourtjester
16 May 2024 13:28 - 16 May 2024 13:32 #300739
by acourtjester
Here is a zip with all the files for what I am using.
Last edit: 16 May 2024 13:32 by acourtjester.
- phillc54
16 May 2024 23:35 #300789
by phillc54
Thanks, the one I am looking for is 41624test_V2.10-005.033_24-05-15_08-30-08.tar.gz
I will check it out later today.
- acourtjester
16 May 2024 23:59 - 17 May 2024 00:03 #300790
by acourtjester
hope this is it I think I miss understood the above reply, was that info in the above reply I sent to you??
Last edit: 17 May 2024 00:03 by acourtjester.
- phillc54
17 May 2024 04:30 #300797
by phillc54
The reason that you are getting the "invalid material number" warning is because you have materials #1000000 and #1000001 in your materials file (41624test_material.cfg). They both need to be deleted.
I cannot find an obvious (to me) reason for the THC issue that you are having.
It is probably worth trying a cut with the VAD Threshold set to 905 rather than the current 64%.
If that doesn't help then try a cut after checking the Auto Activate checkbox.
- Thank you received: 7484
17 May 2024 13:10 #300826
Replied by tommylight on topic New set of problems
What is the THC delay set to?
Seems like being quite long so THC is not active till near the end where it activates and plunges.
Time to create page: 0.234 seconds
