Random Questions on setup
2 years 5 months ago #301907 by tommylight
HOME_OFFSET is the location of the home switch:
linuxcnc.org/docs/devel/html/config/ini-...ng.html#_home_offset
HOME is where the Z axis moves to at HOME_FINAL_VEL to complete homing, it is not a requirement that this is zero.
linuxcnc.org/docs/devel/html/config/ini-homing.html#_home
So this :
Final Pos = -.125 <<<<<< notice - in front of value
Home switch location = 0
should probably be reversed, is that correct?
I will edit the above post after confirmation, thank you.
2 years 5 months ago #301908 by phillc54
Replied by phillc54 on topic Random Questions on setup
It looks to me that he would like Z axis top to be positive and that his limit switch is at the top so I think something like:
MIN_LIMIT = 0.00 MAX_LIMIT = 7.00 HOME_OFFSET = 7.00 HOME = 6.875
The MIN and MAX should be set the same in the AXIS and JOINT sections.
A "conventional" setup would more be like:
MIN_LIMIT = -7.00 MAX_LIMIT = 0.00 HOME_OFFSET = 0.00 HOME = -0.125
2 years 5 months ago #301963 by FlaredFins
So this is what I wound up going with
MIN_LIMIT = -7.00
MAX_LIMIT = 0.00
HOME_OFFSET = -2.00
HOME = 0.00
I tried the other configurations and changing home latch direction, some would cause Z to just jam up into the ballnut or put the axis in a bad position for travel. the problem im seeing is im telling it to go to -2.00 but when it parks the DRO reads 2.993 if i change the Home offset to -4.00 it goes to -4.993 so not sure what that is all about.
As it is Homing Z seems sufficient now. but with odd results
OH... while performing all this one of the runs caused the Z to dig into the plate and trip my probe switch. this caused an error and was unable to bypass or override the switch to get the Z axis into a better place. Am I overlooking something? error stated Jogging was not available and since i hadn't homed it all i could MDI my way out of it.
2 years 5 months ago - 2 years 5 months ago #302019 by phillc54
HOME_OFFSET is the location of the home switch.
Where is your z home switch located in relation to the top of Z travel?
Override Limits on the SETTINGS tab should allow you to jog after hitting a limit.
Last edit: 2 years 5 months ago by phillc54.
2 years 4 months ago - 2 years 4 months ago #302246 by FlaredFins
Switch is at the top most portion of Z axis.
Ill look on the settings tab again today. still trying to work my way around QTPlasmac.
Also is there a way to change the Velocity position and Size on the screen?
Oh and switch the Buttons on the Jog like switch + and -
Last edit: 2 years 4 months ago by FlaredFins.
2 years 4 months ago - 2 years 4 months ago #302423 by snowgoer540
Position - not easily (it's an open source project so there's usually always a way)
Size - yes. Follow these directions: linuxcnc.org/docs/devel/html/plasma/qtpl...#_add_a_custom_style
inside of qtplasmac_custom.qss, add these lines:
#velocity_label { font: 14pt } #velocity_show { font: 14pt }
That will change the size of the VEL: label and the indicator to 14pt font, in this case.
Again, no, not easily. but why would you want to? The X and Y indicators in the preview point toward X and Y positive. The GUI buttons follow as pictured below:
To do anything else would be ... wrong.
Maybe you are expecting the table to behave differently given the orientation of your control console. In that case, .ini file changes are in order....
Last edit: 2 years 4 months ago by snowgoer540. Reason: this editor is the biggest most colossal piece of shit ever
