Random Questions on setup
2 years 4 months ago #302426 by phillc54
Replied by phillc54 on topic Random Questions on setup
Switch is at the top most portion of Z axis.
If that is the case then your ini settings should be one of  these , during homing Z moves to the top (switch) then to complete homing it moves 0.125" down which is the home position. If these don't work then something else is wrong.
I assume when you press the Z+ jog button then the Z axis moves upwards.
Does you home switch stay activated if the Z axis is on or past the home switch?
2 years 4 months ago - 2 years 4 months ago #302507 by caretech
Replied by caretech on topic Random Questions on setup
I noticed one of the plates showing in red that it had been cut already and then it went back to white like it hadn't been cut yet.
Which version of LinuxCNC and QtPlasmaC are you running? The plot only saves so many historic moves in the buffer, and rolls off older ones as it goes. This makes parts done some time ago, go back to white as if they have not yet been cut.
After some searching, I found a thread I remembered discussing the MAX_POINTS param -- forum.linuxcnc.org/qtvcp/41566-seems-lik...ighlighting?start=20
From the above conversation, it sounds like you should have ten-fold more points saved in your backplot if you're running master (2.10). Anyone with more knowledge on this is welcome to correct me.
Another relevant thread -- forum.linuxcnc.org/21-axis/33219-backplo...olour-during-millimg
Last edit: 2 years 4 months ago by caretech. Reason: Found forum threads I was looking for
