Cut Recovery Not Consistently Triggering
1 year 10 months ago #316436 by phillc54
I do have another question on why it can't go back further than the last M03 (or any M-code)
That is a limitation of the reverse run feature that was added to LinuxCNC a few years back. From memory it is in the trajectory planner.
1 year 10 months ago - 1 year 10 months ago #316437 by snowgoer540
Thanks! I was able to get it to work by connecting my components pause-program output to the qtplasmac.ext_pause (I haven't updated yet to try to the ext_pause_only).
Worth noting that I added the _only pin with you in mind. It’s because the program can also be resumed if that pin you are currently using is triggered again somehow. I figured having the option to only pause no matter how many times the pin is hit may be handy.
Last edit: 1 year 10 months ago by snowgoer540.
The following user(s) said Thank You: Uthayne
1 year 10 months ago #317785 by gekonko
Hello,
I have similiar problem.
I was running latest version of linuxcnc(complete installation from usb drive), and cut recovery function was working correctly.
Because I am in the process of creating localisation for the qtplasmac, I did the RIP install (v2.10-008.054). And now the cut recovery is not working.
The cut recovery window shows up ( when paused or triggered by arc-ok loss), Z goes up, but forward and back buttons are not working. I mean they click "yellow", but axes doesnt move on the contour. directional buttons on the screen are working.
I did two of these RIP installations on different computers, and behaviour is the same.
Even in the qtplasmac-metric simulator it is not working.
M52 P1 is called in the program.
Do you have any idea what can cause this problem? thank you.
1 year 9 months ago #317857 by phillc54
I don't see this issue on a current RIP build.
Are you by chance using a Wayland desktop and/or a non English locale?
1 year 9 months ago #317862 by gekonko
My system is basically :
- installed from linuxcnc usb stick
- removed linuxcnc using synaptic
- installed RIP linuxcnc using documentation.
My locale is SK (Slovak)
i will try to install RIP in new, EN locale.
1 year 9 months ago #317888 by phillc54
I can confirm that it misbehaves if I change my location to SK.
I will look into it further.
Time to create page: 0.060 seconds
