Config will not open after Buildbot2 upgade from 2.9.4 to 2.10
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Mar 2025 22:19 #324607 by rodw
update_log.txt
Warning: Spoiler!
machine_log
Warning: Spoiler!
Clearly there is no error reporting to the screen or to any log. I checked the screeen handler code. My comments about exception handling lacking stand.
22 Mar 2025 22:33 #324608 by snowgoer540
There is no error.  It’s informational.  There’s over twenty logs of updating to 001.017 in the update log file.
As I said, expecting handling is present:
github.com/LinuxCNC/linuxcnc/blob/0e1f56...asmac/updater.py#L31
github.com/LinuxCNC/linuxcnc/blob/0e1f56...asmac/updater.py#L42
Nonetheless all of that is irrelevant; something’s up with your installation/OS.  All of the issues you mentioned have been taken care of for some time now.
  • rodw
  • Platinum Member
  • Platinum Member
22 Mar 2025 23:22 #324614 by rodw
Yes, there are over 20 messages saying it upgraded but not one message saying it got an error and failed during that upgrade attempt.
You can see I tried several times tying to get to the bottom of it, each generating a message.
The issue is that on two different PC's, the upgrade to a sim install failed without reporting an error which left me in the dark.
You seem unwilling to actually test such an upgrade process and instead want to blame my installation.
23 Mar 2025 07:50 #324654 by snowgoer540
That's because it didn't fail, at least not in the eyes of the try/except handler.
I don't know what you mean by "the upgrade to a sim install". Could you please elaborate?
I wouldn't say I am unwilling, even in the absence of steb-by-step directions from you as to how to reproduce what it is you are experiencing, I took my own steps to try to duplicate your issue:
I removed the package version I had installed, added the secret buildbot, and installed master for bookworm. I then launched linuxcnc by typing linuxcnc in the terminal. Navigated to Sample Configurations > sim > qtplasmac > qtplasmac_l_metric, and clicked OK. It worked fine with no update messages. I repeated for a RIP installation, it worked fine with no update messages.
The thing is that this issue has been solved by the aforementioned commits, and a sim config never needs to be updated, as it has the necessary changes. So it leads me to the conclusion that something went wrong in the process of going from 2.9.4 to 2.10.
Are you copying the config and trying to make a usable machine out of it? Or are you trying to actually simulate your machine?
If it's the latter, there's a way to simulate your actual table.
  • rodw
  • Platinum Member
  • Platinum Member
23 Mar 2025 08:08 #324656 by rodw
For the third time with some more detail. To replicate
1. Install Linuxcnc 2.9.4 (rip should be fine but I used the ISO)
2. Install the Qtplasmac sim to the config folder
3. Open the sim to confirm its working
4. Close the sim
5. Install Linuxcnc 2.10 or run from another RIP folder
6. Open linuxcnc 2.10
7. Open the previously installed sim.
8. Upgrade message should be displayed
9. Repeat 6,7 The upgrade message will be displayed again and Linuxcnc exits without error message.
I just wanted to test an upgrade from the 2.9.4 ISO to use 2.10 before asking a customer to upgrade his working system. I now know the workarounds but I don't think the bug will bite on a live system
FYI, I have just posted an upgrade script to go from 2.9.4 to 2.10 in the Installing Linuxcnc section that shows what I want to achieve. Becasue Linuxcnc does not maintain a buildbot on Linuxcnc.org, some changes to  the apt folders are required to point to the buildbot2 repo. We follow the Debian standards for APT in the ISO so there is some data in subfolders that needs removing.
Ref: forum.linuxcnc.org/9-installing-linuxcnc...n-2-10-master-branch
  • Moderator
  • Moderator
23 Mar 2025 08:23 #324660 by tommylight
2. How? Why?
3. when you do this, LinuxCNC will copy the sim config folder to your "linuxcnc/configs" folder, so there is absolutely no reason for 2.
If you did 2. for whatever non existing reason, that might be the issue with permissions...
23 Mar 2025 08:30 #324662 by snowgoer540
2. How? Why?
I too am miffed by what you mean for #2.
Are you saying that you are trying to open the 2.9.4 sim config that was probably put in "My Sample Configurations" on a 2.10 installation?
If so, that could be the problem, just open a simulation from Sample Configurations > sim > qtplasmac > qtplasmac_l_metric.
(I think Tommy and I might be saying the same thing)
23 Mar 2025 10:54 #324672 by snowgoer540
Here is opening a sample config on a fresh package 2.10 install:
Warning: Spoiler!
Here is opening the copied config from my config folder, as well as from my sample configs on the launcher:
Warning: Spoiler!
  • rodw
  • Platinum Member
  • Platinum Member
23 Mar 2025 20:39 #324714 by rodw
Just accept that I ran a Sim in Step 2 and it copied it to the configs folder
You tests prove nothing becasue you have not taken a sim installed under 2.94 then run it under to 2.10 (steps 5,6,7)
You are clearly not listening to the issue or following my instructions to replicate the issue. Tommy just goes off on a tangent on Item 2.
What I wanted to do is simply confirm using a SIM, things would work once I asked a customer to upgrade a live install on a production table over 1000 miles from me. Doing it on the sim found some issues. They may not apply to a live install.
I am done with this issue as I received enough information to solve the problem manually from Snowgoer's initial post.
24 Mar 2025 20:13 - 24 Mar 2025 20:14 #324848 by snowgoer540
It seems neither Tommy nor I fully understood what you were doing in step 2. I follow now.
While waiting for clarification, I was attempting to replicate your issue and validate the process.
Honestly, it seems like you’d benefit from learning how to simulate your customer’s actual machine. This guide explains how to convert a “live” config into a simulation config, which you may find more useful than the bog standard simulation config: forum.linuxcnc.org/plasmac/43425-simulator-for-qtplasmac
It’s good you were able to gather enough information to solve the problem manually.
The core issue stems from the interaction between the .ini file and the .inc file, resulting in ini.combined. The changes were correctly applied to that file, but the problem is that it’s overwritten every time LinuxCNC launches, so it applies the changes repeatedly.
I still maintain that this is an issue related to your setup/installation and/or an unintended use case. That said, I’m considering adding a check for “expanded” in the filename and display a warning if it looks like an older simulation config is being used. I’m also considering tweaking some of the messaging to clarify this process moving forward.
Thanks for being patient with me while I worked through this.
Last edit: 24 Mar 2025 20:14 by snowgoer540.
Time to create page: 0.268 seconds
