Thanks Snow,
You always do a great job, i'm just a bit different.
Using the laser button is 3 clicks and wait for lag. first to "laser" then "mark edge" then "set origin", then the machine moves.
With the user button, its a one click and the machine moves to where i need it, zero's, and i'm ready to start cutting. the code i'm using is the one I found worked many years ago and i have just kept it. i also have another button used for the air scribe offset (albeit still a work in progress). I have only had this issue since the update to 2.9.4.
My normal operation flow goes.
home machine
sheet on machine
import drawing
align x,y using laser
click laser offset to zero torch on where i lined up laser pointer
frame to check cut file will fit (done alot when cutting multiple parts from sheets that have already been cut)
then cut
I'll try the new code now and see how it all goes.
new code is G10 L20 P0 X0 Y0 \ G0 X-2.5 Y104.3 \ G10 L20 P0 X0 Y0
Works perfectly, thanks again Snow !!
