Job not showing in position - 2.9.4 - v2.9-238.315
1 year 5 months ago #327843 by RNJFAB
Thanks Snow,
Willing to bet I have done something.
N00010; file name: Deer 3.tap
N00020; date and time: Mon May 05 2025 20:10:48
N00030; postprocessor: LinuxCNC PlasmaC.scpost rev: 0.4
N00040;
N00050;begin pre-amble
N00060 G21 (units: metric)
N00070 G40 (cutter compensation: off)
N00080 G90 (distance mode: absolute)
N00090 M52 P1 (adaptive feed: on)
N00100 M65 P2 (enable THC)
N00110 M65 P3 (enable torch)
N00120 M68 E3 Q0 (velocity 100%)
N00130 G64 P0.254 Q0.025 (tracking tolerances: 0.254mm)
N00140#<holes> = 3
N00150#<h_velocity> = 80
N00160#<h_diameter> = 32
N00170#<oclength> = 2
N00180;end pre-amble
N00190 M67 E3 Q100
N00200;
N00210;begin material setup
N00220 T0 M6 (select plasma tool)
N00230 G43 H0 (apply tool offsets)
N00240 (o=0,kw=1.4, ph=3.4, pd=0.4, ch=1.5, fr=6200, th=1, cv=121, pe=0, jh=0, jd=0)
N00250 F#<_hal[plasmac.cut-feed-rate]>
N00260;end material setup
N00270 G0 X302.004 Y71.417
N00280 M3 $0 S1 (plasma start)
N00290 M67 E3 Q100
N00300 G3 X299.444 Y73.977 I-2.56 J0
N00310 G1 X299.444 Y22.601
N00320 G1 X325.65 Y22.601
N00330 G1 X325.65 Y26.343
N00340 G1 X304.969 Y26.343
N00350 G2 X304.269 Y27.043 I0 J0.7
N00360 G1 X304.269 Y47.342
N00370 G2 X304.969 Y48.042 I0.7 J0
N00380 G1 X322.672 Y48.042
N00390 G1 X322.672 Y51.784
N00400 G1 X304.969 Y51.784
N00410 G2 X304.269 Y52.484 I0 J0.7
N00420 G1 X304.269 Y69.534
N00430 G2 X304.969 Y70.234 I0.7 J0
N00440 G1 X324.296 Y70.234
N00450 G1 X324.296 Y73.977
N00460 G1 X299.444 Y73.977
N00470 M5 $0 (plasma end)
N00480 G0 X268.279 Y71.417
N00490 M3 $0 S1 (plasma start)
N00500 G3 X265.719 Y73.977 I-2.56 J0
N00510 G1 X263.719 Y73.977
N00520 G1 X263.719 Y22.601
N00530 G1 X268.544 Y22.601
N00540 G1 X268.544 Y61.415
N00550 G2 X269.244 Y62.115 I0.7 J0
N00560 G1 X269.514 Y62.115
N00570 G2 X270.174 Y61.65 I0 J-0.7
N00580 G1 X284.082 Y22.601
N00590 G1 X290.466 Y22.601
N00600 G1 X290.466 Y73.977
N00610 G1 X285.641 Y73.977
N00620 G1 X285.641 Y35.163
N00630 G2 X284.941 Y34.463 I-0.7 J0
N00640 G1 X284.67 Y34.463
N00650 G2 X284.011 Y34.928 I0 J0.7
N00660 G1 X270.103 Y73.977
N00670 G1 X265.719 Y73.977
N00680 M5 $0 (plasma end)
N00690 G0 X239.756 Y71.417
N00700 M3 $0 S1 (plasma start)
N00710 G3 X237.196 Y73.977 I-2.56 J0
N00720 G1 X237.196 Y69.422
N00730 G1 X239.473 Y69.422
N00740 G2 X240.173 Y68.722 I0 J-0.7
N00750 G1 X240.173 Y27.855
N00760 G2 X239.473 Y27.155 I-0.7 J0
N00770 G1 X237.196 Y27.155
N00780 G1 X237.196 Y22.601
N00790 G1 X247.975 Y22.601
N00800 G1 X247.975 Y27.155
N00810 G1 X245.698 Y27.155
N00820 G2 X244.998 Y27.855 I0 J0.7
N00830 G1 X244.998 Y68.722
N00840 G2 X245.698 Y69.422 I0.7 J0
N00850 G1 X247.975 Y69.422
N00860 G1 X247.975 Y73.977
N00870 G1 X237.196 Y73.977
N00880 M5 $0 (plasma end)
N00890 G0 X197.265 Y71.417
N00900 M3 $0 S1 (plasma start)
N00910 G3 X194.705 Y73.977 I-2.56 J0
N00920 G1 X194.705 Y22.601
N00930 G1 X199.53 Y22.601
N00940 G1 X199.53 Y48.424
N00950 G2 X200.23 Y49.124 I0.7 J0
N00960 G1 X215.656 Y49.124
N00970 G2 X216.356 Y48.424 I0 J-0.7
N00980 G1 X216.356 Y22.601
N00990 G1 X221.181 Y22.601
N01000 G1 X221.181 Y73.977
N01010 G1 X216.356 Y73.977
N01020 G1 X216.356 Y53.566
N01030 G2 X215.656 Y52.866 I-0.7 J0
N01040 G1 X200.23 Y52.866
N01050 G2 X199.53 Y53.566 I0 J0.7
N01060 G1 X199.53 Y73.977
N01070 G1 X194.705 Y73.977
N01080 M5 $0 (plasma end)
N01090 G0 X172.618 Y71.734
N01100 M3 $0 S1 (plasma start)
N01110 G3 X169.302 Y73.188 I-2.385 J-0.931
N01120 G3 X167.485 Y72.288 I4.215 J-10.794
N01130 G1 X167.464 Y72.275
N01140 G3 X161.2 Y62.954 I6.102 J-10.866
N01150 G3 X165.494 Y51.939 I12.346 J-1.531
N01160 G3 X178.136 Y42.794 I84.901 J104.051
N01170 G2 X181.074 Y39.938 I-4.715 J-7.792
N01180 G1 X181.105 Y39.886
N01190 G2 X179.327 Y28.714 I-8.342 J-4.4
N01200 G1 X179.258 Y28.655
N01210 G2 X172.614 Y26.614 I-6.197 J8.336
N01220 G2 X167.021 Y28.693 I-0.113 J8.256
N01230 G1 X166.997 Y28.716
N01240 G2 X164.354 Y35.459 I6.145 J6.298
N01250 G1 X164.348 Y37.71
N01260 G1 X159.521 Y37.71
N01270 G1 X159.521 Y35.705
N01280 G3 X163.394 Y26.172 I13.75 J0.034
N01290 G3 X164.965 Y24.806 I7.641 J7.199
N01300 G3 X173.941 Y22.613 I7.763 J12.311
N01310 G1 X173.997 Y22.616
N01320 G3 X183.227 Y26.188 I-0.039 J13.812
N01330 G3 X187.08 Y36.495 I-10.704 J9.875
N01340 G1 X187.08 Y36.516
N01350 G3 X181.23 Y46.18 I-10.909 J-0
N01360 G1 X181.203 Y46.195
N01370 G2 X169.732 Y54.388 I37.733 J64.956
N01380 G2 X168.011 Y56.09 I10.349 J12.184
N01390 G2 X166.946 Y66.121 I6.058 J5.715
N01400 G2 X177.978 Y68.368 I6.489 J-3.651
N01410 G1 X178.002 Y68.348
N01420 G2 X181.024 Y60.762 I-5.595 J-6.623
N01430 G1 X185.74 Y60.762
N01440 G1 X185.744 Y60.976
N01450 G1 X185.744 Y60.986
N01460 G3 X182.599 Y70.449 I-14.361 J0.482
N01470 G3 X174.186 Y73.964 I-8.15 J-7.682
N01480 G1 X174.132 Y73.965
N01490 G3 X169.302 Y73.188 I-0.616 J-11.572
N01500 M5 $0 (plasma end)
N01510 G0 X129.709 Y71.417
N01520 M3 $0 S1 (plasma start)
N01530 G3 X127.149 Y73.977 I-2.56 J0
N01540 G1 X125.149 Y73.977
N01550 G1 X125.149 Y22.601
N01560 G1 X129.974 Y22.601
N01570 G1 X129.974 Y61.415
N01580 G2 X130.674 Y62.115 I0.7 J0
N01590 G1 X130.945 Y62.115
N01600 G2 X131.604 Y61.65 I0 J-0.7
N01610 G1 X145.512 Y22.601
N01620 G1 X151.896 Y22.601
N01630 G1 X151.896 Y73.977
N01640 G1 X147.071 Y73.977
N01650 G1 X147.071 Y35.163
N01660 G2 X146.371 Y34.463 I-0.7 J0
N01670 G1 X146.101 Y34.463
N01680 G2 X145.441 Y34.928 I0 J0.7
N01690 G1 X131.534 Y73.977
N01700 G1 X127.149 Y73.977
N01710 M5 $0 (plasma end)
N01720 G0 X108.768 Y70.66
N01730 M3 $0 S1 (plasma start)
N01740 G3 X106.815 Y73.708 I-2.501 J0.548
N01750 G1 X106.815 Y69.659
N01760 G2 X109.354 Y67.975 I-3.6 J-8.182
N01770 G2 X111.271 Y65.281 I-5.401 J-5.872
N01780 G1 X111.276 Y65.269
N01790 G2 X112.798 Y59.54 I-21.089 J-8.669
N01800 G2 X113.352 Y43.026 I-98.705 J-11.576
N01810 G2 X112.586 Y35.855 I-56.375 J2.392
N01820 G2 X111.451 Y31.733 I-21.771 J3.779
N01830 G2 X106.812 Y26.911 I-7.997 J3.051
N01840 G1 X106.815 Y22.854
N01850 G3 X112.883 Y26.26 I-2.216 J11.055
N01860 G3 X117.006 Y35.012 I-15.825 J12.801
N01870 G3 X117.604 Y58.586 I-71.94 J13.62
N01880 G3 X115.02 Y67.203 I-29.093 J-4.027
N01890 G3 X106.815 Y73.708 I-10.757 J-5.141
N01900 M5 $0 (plasma end)
N01910 G0 X97.156 Y69.229
N01920 M3 $0 S1 (plasma start)
N01930 G3 X93.623 Y68.437 I-1.37 J-2.162
N01940 G3 X92.94 Y67.203 I10.028 J-6.355
N01950 G3 X90.356 Y58.586 I26.509 J-12.645
N01960 G3 X90.955 Y35.012 I72.538 J-9.954
N01970 G3 X95.078 Y26.26 I19.948 J4.049
N01980 G3 X101.415 Y22.818 I8.2 J7.544
N01990 G1 X101.415 Y26.836
N02000 G2 X96.509 Y31.734 I2.934 J7.845
N02010 G2 X95.374 Y35.856 I20.642 J7.901
N02020 G2 X94.609 Y43.026 I55.602 J9.561
N02030 G2 X95.163 Y59.549 I99.313 J4.936
N02040 G2 X96.684 Y65.269 I22.576 J-2.94
N02050 G1 X96.694 Y65.29
N02060 G2 X101.415 Y69.739 I7.749 J-3.494
N02070 G1 X101.415 Y73.741
N02080 G3 X93.623 Y68.437 I2.236 J-11.66
N02090 M5 $0 (plasma end)
N02100 G0 X75.533 Y69.787
N02110 M3 $0 S1 (plasma start)
N02120 G3 X74.117 Y73.119 I-2.374 J0.958
N02130 G3 X72.209 Y73.708 I-4.461 J-11.056
N02140 G1 X72.209 Y69.659
N02150 G2 X74.747 Y67.975 I-3.6 J-8.182
N02160 G2 X76.664 Y65.281 I-5.401 J-5.872
N02170 G1 X76.669 Y65.269
N02180 G2 X78.191 Y59.54 I-21.089 J-8.669
N02190 G2 X78.745 Y43.026 I-98.705 J-11.576
N02200 G2 X77.979 Y35.855 I-56.375 J2.392
N02210 G2 X76.844 Y31.733 I-21.771 J3.779
N02220 G2 X72.205 Y26.911 I-7.997 J3.051
N02230 G1 X72.208 Y22.854
N02240 G3 X78.276 Y26.26 I-2.216 J11.055
N02250 G3 X82.399 Y35.012 I-15.825 J12.801
N02260 G3 X82.997 Y58.586 I-71.94 J13.62
N02270 G3 X80.413 Y67.203 I-29.093 J-4.027
N02280 G3 X74.117 Y73.119 I-10.757 J-5.141
N02290 M5 $0 (plasma end)
N02300 G0 X61.746 Y68.411
N02310 M3 $0 S1 (plasma start)
N02320 G3 X58.333 Y67.203 I-1.102 J-2.311
N02330 G3 X55.749 Y58.586 I26.509 J-12.645
N02340 G3 X56.348 Y35.012 I72.538 J-9.954
N02350 G3 X60.471 Y26.26 I19.948 J4.049
N02360 G3 X66.808 Y22.818 I8.2 J7.544
N02370 G1 X66.808 Y26.836
N02380 G2 X61.902 Y31.734 I2.934 J7.845
N02390 G2 X60.767 Y35.856 I20.642 J7.901
N02400 G2 X60.002 Y43.026 I55.602 J9.561
N02410 G2 X60.557 Y59.549 I99.313 J4.936
N02420 G2 X62.077 Y65.269 I22.576 J-2.94
N02430 G1 X62.087 Y65.29
N02440 G2 X66.808 Y69.739 I7.749 J-3.494
N02450 G1 X66.808 Y73.741
N02460 G3 X58.333 Y67.203 I2.236 J-11.66
N02470 M5 $0 (plasma end)
N02480 G0 X23.511 Y71.417
N02490 M3 $0 S1 (plasma start)
N02500 G3 X20.951 Y73.977 I-2.56 J0
N02510 G1 X20.951 Y22.601
N02520 G1 X24.964 Y22.601
N02530 G1 X24.964 Y61.415
N02540 G2 X25.664 Y62.115 I0.7 J0
N02550 G1 X26.206 Y62.115
N02560 G2 X26.896 Y61.529 I0 J-0.7
N02570 G1 X33.295 Y22.601
N02580 G1 X36.437 Y22.601
N02590 G1 X42.836 Y61.529
N02600 G2 X43.527 Y62.115 I0.691 J-0.114
N02610 G1 X44.068 Y62.115
N02620 G2 X44.768 Y61.415 I0 J-0.7
N02630 G1 X44.768 Y22.601
N02640 G1 X48.781 Y22.601
N02650 G1 X48.781 Y73.977
N02660 G1 X41.414 Y73.977
N02670 G1 X35.827 Y40.191
N02680 G2 X35.137 Y39.605 I-0.691 J0.114
N02690 G1 X34.595 Y39.605
N02700 G2 X33.905 Y40.191 I0 J0.7
N02710 G1 X28.318 Y73.977
N02720 G1 X20.951 Y73.977
N02730 M5 $0 (plasma end)
N02740 G0 X55.247 Y102.592
N02750 M3 $0 S1 (plasma start)
N02760 G3 X56.423 Y106.016 I-1.124 J2.3
N02770 G1 X56.076 Y106.727
N02780 G1 X55.245 Y108.485
N02790 G1 X55.239 Y108.497
N02800 G1 X54.362 Y110.446
N02810 G1 X54.353 Y110.467
N02820 G1 X53.919 Y111.523
N02830 G1 X53.911 Y111.546
N02840 G1 X53.629 Y112.304
N02850 G2 X53.109 Y114.496 I9.425 J3.394
N02860 G1 X53.106 Y114.526
N02870 G1 X53.099 Y114.614
N02880 G1 X53.097 Y114.668
N02890 G2 X53.341 Y115.933 I3.408 J-0.001
N02900 G1 X53.349 Y115.952
N02910 G2 X54.223 Y117.464 I7.09 J-3.092
N02920 G1 X54.232 Y117.476
N02930 G1 X55.541 Y119.169
N02940 G1 X56.288 Y120.162
N02950 G1 X56.77 Y120.834
N02960 G3 X58.884 Y124.498 I-17.896 J12.765
N02970 G1 X59.247 Y125.381
N02980 G1 X59.267 Y125.433
N02990 G2 X58.042 Y124.842 I-6.317 J11.531
N03000 G1 X56.674 Y124.234
N03010 G1 X56.639 Y124.22
N03020 G1 X55.266 Y123.697
N03030 G1 X55.251 Y123.691
N03040 G1 X53.57 Y123.094
N03050 G1 X50.611 Y122.083
N03060 G1 X48.938 Y121.491
N03070 G1 X47.161 Y120.828
N03080 G1 X46.263 Y120.461
N03090 G3 X43.714 Y119.044 I4.975 J-11.948
N03100 G3 X42.824 Y118.168 I5.542 J-6.525
N03110 G3 X40.932 Y115.487 I16.247 J-13.472
N03120 G1 X40.609 Y114.957
N03130 G3 X34.997 Y102.581 I66.089 J-37.424
N03140 G1 X34.99 Y102.561
N03150 G1 X34.979 Y102.53
N03160 G3 X34.618 Y101.334 I8.413 J-3.187
N03170 G1 X34.322 Y100.067
N03180 G1 X34.316 Y100.042
N03190 G1 X34.2 Y99.62
N03200 G2 X33.663 Y98.278 I-6.683 J1.895
N03210 G1 X33.629 Y98.208
N03220 G2 X33.007 Y97.156 I-8.329 J4.212
N03230 G1 X33.761 Y95.585
N03240 G1 X34.686 Y93.769
N03250 G3 X38.144 Y87.402 I117.856 J59.888
N03260 G1 X38.764 Y86.327
N03270 G2 X50.279 Y87.791 I11.679 J-45.826
N03280 G1 X51.726 Y87.816
N03290 G1 X51.736 Y87.817
N03300 G1 X53.673 Y87.82
N03310 G1 X53.685 Y87.82
N03320 G1 X57.912 Y87.756
N03330 G1 X63.126 Y87.641
N03340 G3 X63.164 Y88.422 I-5.055 J0.637
N03350 G3 X62.993 Y89.999 I-14.263 J-0.745
N03360 G1 X62.852 Y90.036
N03370 G1 X62.761 Y90.067
N03380 G2 X61.896 Y91.062 I0.574 J1.373
N03390 G2 X61.947 Y91.552 I0.677 J0.178
N03400 G1 X62.427 Y92.516
N03410 G3 X60.081 Y98.408 I-65.221 J-22.563
N03420 G1 X58.622 Y101.515
N03430 G1 X56.423 Y106.016
N03440 M5 $0 (plasma end)
N03450 G0 X177.076 Y4.415
N03460 M3 $0 S1 (plasma start)
N03470 G3 X177.613 Y5.407 I0.269 J0.496
N03480 G3 X177.613 Y5.407 I-0.537 J-0.992
N03490 M5 $0 (plasma end)
N03500 G0 X271.094 Y106.976
N03510 M3 $0 S1 (plasma start)
N03520 G3 X274.715 Y106.984 I1.806 J1.814
N03530 G1 X276.387 Y108.701
N03540 G1 X277.411 Y109.79
N03550 G3 X279.848 Y112.741 I-24.183 J22.451
N03560 G1 X280.526 Y113.825
N03570 G3 X280.979 Y115.182 I-3.433 J1.9
N03580 G1 X280.983 Y115.228
N03590 G3 X280.539 Y116.404 I-1.952 J-0.066
N03600 G1 X280.508 Y116.444
N03610 G1 X280.112 Y117.002
N03620 G3 X275.038 Y122.272 I-39.38 J-32.838
N03630 G1 X275.019 Y122.289
N03640 G1 X272.161 Y125.056
N03650 G1 X271.329 Y125.878
N03660 G2 X269.256 Y128.21 I18.905 J18.899
N03670 G1 X269.174 Y128.316
N03680 G1 X269.154 Y128.343
N03690 G2 X268.115 Y130.767 I5.335 J3.723
N03700 G1 X267.922 Y131.558
N03710 G1 X267.916 Y131.584
N03720 G1 X267.888 Y131.721
N03730 G2 X267.132 Y136.44 I60.885 J12.163
N03740 G1 X267.111 Y136.431
N03750 G1 X266.741 Y136.273
N03760 G1 X266.72 Y136.264
N03770 G2 X262.123 Y134.79 I-14.551 J37.48
N03780 G1 X262.099 Y134.785
N03790 G1 X260.515 Y134.438
N03800 G2 X256.326 Y133.822 I-7.02 J33.206
N03810 G2 X256.034 Y133.742 I-0.328 J0.618
N03820 G1 X254.734 Y133.674
N03830 G1 X252.993 Y133.549
N03840 G1 X252.949 Y133.548
N03850 G1 X249.5 Y133.521
N03860 G1 X249.489 Y133.521
N03870 G1 X247.523 Y133.538
N03880 G1 X247.509 Y133.539
N03890 G1 X245.542 Y133.594
N03900 G2 X238.485 Y134.311 I1.556 J50.396
N03910 G1 X238.341 Y134.336
N03920 G2 X235.776 Y134.871 I5.023 J30.51
N03930 G1 X235.766 Y134.874
N03940 G1 X235.375 Y134.979
N03950 G3 X233.81 Y126.396 I43.961 J-12.45
N03960 G1 X233.808 Y126.376
N03970 G1 X233.546 Y124.077
N03980 G1 X233.39 Y122.818
N03990 G1 X232.908 Y118.217
N04000 G1 X232.482 Y114.414
N04010 G1 X232.117 Y110.907
N04020 G1 X231.601 Y105.371
N04030 G1 X231.413 Y102.388
N04040 G1 X231.374 Y101.501
N04050 G3 X231.471 Y99.138 I15.268 J-0.56
N04060 G1 X231.475 Y99.088
N04070 G1 X231.524 Y98.056
N04080 G1 X231.524 Y98.037
N04090 G1 X231.545 Y96.997
N04100 G1 X231.545 Y96.986
N04110 G2 X231.336 Y94.713 I-11.85 J-0.057
N04120 G1 X231.097 Y93.476
N04130 G1 X231.09 Y93.448
N04140 G2 X230.579 Y92.144 I-4.86 J1.154
N04150 G2 X229.735 Y91.829 I-0.609 J0.344
N04160 G3 X229.197 Y89.865 I57.632 J-16.859
N04170 G1 X229.187 Y89.829
N04180 G2 X229.086 Y89.607 I-0.678 J0.176
N04190 G1 X229.078 Y89.596
N04200 G2 X227.857 Y89.72 I-0.576 J0.397
N04210 G1 X227.786 Y89.892
N04220 G1 X227.729 Y89.76
N04230 G1 X227.4 Y88.878
N04240 G1 X227.381 Y88.818
N04250 G2 X226.013 Y89.029 I-0.669 J0.207
N04260 G1 X226.015 Y89.4
N04270 G3 X225.948 Y89.107 I3.804 J-1.03
N04280 G1 X225.938 Y89.064
N04290 G1 X225.623 Y87.836
N04300 G1 X225.619 Y87.823
N04310 G2 X225.247 Y86.832 I-5.782 J1.606
N04320 G1 X225.24 Y86.815
N04330 G1 X225.776 Y86.814
N04340 G3 X257.615 Y88.609 I1.576 J255.466
N04350 G1 X257.36 Y88.911
N04360 G2 X257.196 Y89.393 I0.535 J0.451
N04370 G1 X257.211 Y89.728
N04380 G2 X257.308 Y90.053 I0.699 J-0.031
N04390 G1 X257.318 Y90.071
N04400 G2 X257.946 Y90.414 I0.603 J-0.356
N04410 G1 X263.862 Y90.194
N04420 G1 X268.117 Y90.079
N04430 G1 X271.35 Y90.019
N04440 G2 X269.817 Y92.323 I8.689 J7.445
N04450 G1 X269.809 Y92.34
N04460 G1 X269.777 Y92.406
N04470 G1 X269.768 Y92.428
N04480 G2 X269.061 Y94.354 I17.375 J7.465
N04490 G1 X268.463 Y96.228
N04500 G1 X268.445 Y96.277
N04510 G2 X268.781 Y99.665 I3.812 J1.333
N04520 G1 X268.84 Y99.766
N04530 G2 X271.228 Y103.19 I20.998 J-12.095
N04540 G2 X274.715 Y106.984 I49.348 J-41.858
N04550 M5 $0 (plasma end)
N04560 G0 X327.259 Y127.334
N04570 M3 $0 S1 (plasma start)
N04580 G1 X327.574 Y128.705
N04590 G1 X327.785 Y129.745
N04600 G1 X327.863 Y131.798
N04610 G1 X327.802 Y131.79
N04620 G3 X326.843 Y131.577 I1.188 J-7.633
N04630 G1 X325.625 Y130.543
N04640 G1 X325.693 Y126.244
N04650 G1 X325.823 Y121.538
N04660 G1 X326.338 Y123.485
N04670 G1 X326.869 Y125.636
N04680 G1 X327.259 Y127.334
N04690 M5 $0 (plasma end)
N04700 G0 X335.917 Y158.802
N04710 M3 $0 S1 (plasma start)
N04720 G3 X334.865 Y159.211 I-0.526 J0.204
N04730 G3 X334.865 Y159.211 I1.052 J-0.409
N04740 M5 $0 (plasma end)
N04750 G0 X174.712 Y315.773
N04760 M3 $0 S1 (plasma start)
N04770 G3 X175.728 Y316.264 I0.508 J0.245
N04780 G3 X175.728 Y316.264 I-1.016 J-0.491
N04790 M5 $0 (plasma end)
N04800 G0 X119.557 Y298.31
N04810 M3 $0 S1 (plasma start)
N04820 G3 X116.246 Y299.775 I-2.388 J-0.923
N04830 G3 X105.227 Y295.031 I56.986 J-147.509
N04840 G2 X116.894 Y296.65 I11.6 J-40.741
N04850 G1 X117.466 Y296.651
N04860 G2 X148.941 Y282.977 I0.003 J-43.056
N04870 G2 X154.556 Y282.398 I-4.062 J-66.811
N04880 G1 X155.944 Y282.189
N04890 G1 X155.958 Y282.187
N04900 G1 X159.765 Y281.535
N04910 G1 X159.8 Y281.531
N04920 G3 X165.187 Y281.27 I4.521 J37.674
N04930 G1 X170.069 Y281.454
N04940 G1 X173.307 Y281.53
N04950 G1 X173.32 Y281.531
N04960 G1 X174.974 Y281.539
N04970 G1 X176.807 Y281.524
N04980 G1 X176.818 Y281.524
N04990 G1 X178.728 Y281.477
N05000 G2 X178.022 Y282.049 I0.728 J1.623
N05010 G1 X177.984 Y282.106
N05020 G2 X177.967 Y284.769 I2.275 J1.346
N05030 G1 X177.974 Y284.781
N05040 G1 X178.002 Y284.83
N05050 G2 X179.855 Y286.285 I2.972 J-1.877
N05060 G1 X179.959 Y286.321
N05070 G1 X179.986 Y286.329
N05080 G2 X181.32 Y286.508 I1.246 J-4.223
N05090 G1 X181.414 Y286.507
N05100 G2 X182.574 Y286.336 I-0.097 J-4.703
N05110 G1 X190.187 Y286.178
N05120 G1 X199.233 Y285.951
N05130 G1 X203.207 Y285.813
N05140 G1 X203.217 Y285.813
N05150 G1 X207.468 Y285.603
N05160 G1 X209.636 Y285.555
N05170 G1 X210.969 Y285.552
N05180 G1 X211.974 Y285.565
N05190 G3 X216.679 Y285.843 I-0.941 J55.873
N05200 G1 X217.399 Y285.918
N05210 G2 X220.794 Y285.897 I1.588 J-17.289
N05220 G1 X220.812 Y285.894
N05230 G1 X222.933 Y285.619
N05240 G1 X223.927 Y285.503
N05250 G1 X224.772 Y285.483
N05260 G1 X225.089 Y285.54
N05270 G3 X225.137 Y286.058 I-0.18 J0.278
N05280 G1 X225.085 Y286.113
N05290 G1 X225.078 Y286.122
N05300 G3 X224.649 Y286.326 I-0.5 J-0.499
N05310 G1 X223.923 Y286.387
N05320 G1 X222.654 Y286.433
N05330 G1 X222.633 Y286.435
N05340 G1 X221.736 Y286.495
N05350 G1 X221.662 Y286.504
N05360 G1 X221.1 Y286.602
N05370 G1 X217.175 Y286.676
N05380 G1 X217.12 Y286.679
N05390 G1 X216.634 Y286.727
N05400 G1 X216.523 Y286.747
N05410 G2 X214.813 Y289.971 I0.64 J2.405
N05420 G1 X214.824 Y290.001
N05430 G1 X214.844 Y290.051
N05440 G2 X216.307 Y291.466 I2.489 J-1.111
N05450 G2 X217.523 Y291.906 I3.655 J-8.189
N05460 G1 X217.743 Y291.971
N05470 G1 X217.759 Y291.976
N05480 G2 X219.685 Y292.308 I2.741 J-10.151
N05490 G2 X220.169 Y292.739 I0.655 J-0.247
N05500 G1 X220.191 Y292.745
N05510 G2 X220.402 Y292.765 I0.171 J-0.679
N05520 G1 X222.131 Y292.665
N05530 G1 X222.144 Y292.664
N05540 G1 X238.917 Y291.405
N05550 G1 X240.152 Y291.3
N05560 G1 X240.168 Y291.298
N05570 G3 X251.788 Y290.72 I10.753 J98.997
N05580 G3 X136.345 Y306.05 I-77.455 J-140.943
N05590 G1 X134.156 Y305.515
N05600 G3 X117.465 Y300.241 I38.764 J-151.715
N05610 G1 X117.082 Y300.096
N05620 G3 X116.246 Y299.775 I56.151 J-147.829
N05630 M5 $0 (plasma end)
N05640 G0 X74.16 Y268.48
N05650 M3 $0 S1 (plasma start)
N05660 G3 X77.468 Y269.95 I0.92 J2.389
N05670 G1 X77.471 Y269.957
N05680 G2 X88.407 Y285.701 I39.357 J-15.668
N05690 G3 X86.859 Y284.696 I81.975 J-128.012
N05700 G1 X83.481 Y282.431
N05710 G1 X83.299 Y282.303
N05720 G3 X65.019 Y267.447 I88.16 J-127.154
N05730 G1 X64.759 Y267.201
N05740 G3 X57.369 Y259.649 I107.554 J-112.648
N05750 G1 X56.941 Y259.17
N05760 G2 X57.712 Y259.489 I17.892 J-42.085
N05770 G2 X58.011 Y259.539 I0.262 J-0.649
N05780 G1 X58.179 Y259.53
N05790 G1 X58.204 Y259.528
N05800 G3 X74.963 Y259.06 I12.139 J134.493
N05810 G2 X77.468 Y269.95 I39.51 J-3.357
N05820 M5 $0 (plasma end)
N05830 G0 X72.594 Y244.985
N05840 M3 $0 S1 (plasma start)
N05850 G3 X75.884 Y246.498 I0.888 J2.401
N05860 G2 X75.768 Y246.995 I38.532 J9.214
N05870 G1 X75.055 Y247
N05880 G3 X72.306 Y246.645 I0.343 J-13.504
N05890 G1 X72.057 Y246.584
N05900 G1 X72.032 Y246.578
N05910 G2 X69.593 Y246.409 I-1.827 J8.668
N05920 G1 X68.187 Y246.495
N05930 G1 X67.498 Y246.436
N05940 G3 X66.634 Y245.127 I0.224 J-1.087
N05950 G3 X66.869 Y244.72 I0.892 J0.243
N05960 G3 X68.892 Y243.723 I2.914 J3.36
N05970 G3 X73.721 Y243.382 I3.661 J17.492
N05980 G1 X76.682 Y243.639
N05990 G2 X75.884 Y246.498 I37.734 J12.073
N06000 M5 $0 (plasma end)
N06010 G0 X123.588 Y256.873
N06020 M3 $0 S1 (plasma start)
N06030 G3 X126.204 Y254.371 I2.559 J0.057
N06040 G1 X135.34 Y254.574
N06050 G2 X136.453 Y254.746 I1.213 J-4.169
N06060 G1 X136.562 Y254.748
N06070 G2 X137.862 Y254.554 I0.074 J-3.964
N06080 G1 X137.89 Y254.545
N06090 G1 X138.036 Y254.49
N06100 G2 X139.724 Y253.064 I-1.162 J-3.088
N06110 G1 X139.749 Y253.018
N06120 G1 X139.781 Y252.952
N06130 G2 X139.75 Y250.367 I-2.382 J-1.264
N06140 G1 X139.727 Y250.329
N06150 G1 X139.711 Y250.304
N06160 G1 X139.662 Y250.238
N06170 G2 X139.024 Y249.726 I-1.562 J1.296
N06180 G1 X141.77 Y249.774
N06190 G1 X141.785 Y249.774
N06200 G1 X144.334 Y249.767
N06210 G1 X144.347 Y249.767
N06220 G1 X146.372 Y249.722
N06230 G1 X146.385 Y249.722
N06240 G1 X151.436 Y249.52
N06250 G3 X153.91 Y249.52 I1.228 J36.432
N06260 G3 X154.472 Y255.568 I-33.762 J6.189
N06270 G1 X154.472 Y255.709
N06280 G3 X147.937 Y275.847 I-34.655 J-0.118
N06290 G1 X145.319 Y275.875
N06300 G1 X145.303 Y275.875
N06310 G1 X144.369 Y275.907
N06320 G1 X144.321 Y275.91
N06330 G1 X143.798 Y275.965
N06340 G2 X143.593 Y276.018 I0.072 J0.696
N06350 G1 X142.412 Y276.018
N06360 G2 X139.968 Y276.724 I0.032 J4.698
N06370 G1 X139.715 Y276.885
N06380 G3 X138.767 Y277.341 I-2.543 J-4.07
N06390 G1 X137.82 Y277.61
N06400 G1 X137.55 Y277.673
N06410 G2 X136.729 Y278.003 I0.762 J3.078
N06420 G2 X135 Y279.83 I2.17 J3.786
N06430 G2 X134.782 Y281.72 I2.267 J1.219
N06440 G1 X134.808 Y281.797
N06450 G1 X134.884 Y281.989
N06460 G1 X134.934 Y282.089
N06470 G2 X136.536 Y283.454 I2.826 J-1.693
N06480 G1 X136.599 Y283.484
N06490 G1 X136.623 Y283.494
N06500 G2 X139.77 Y284.066 I2.877 J-6.886
N06510 G3 X117.297 Y291.367 I-22.408 J-30.738
N06520 G1 X117.214 Y291.367
N06530 G3 X101.49 Y287.984 I0.034 J-38.404
N06540 G3 X80.32 Y259.486 I14.163 J-32.632
N06550 G1 X81.198 Y259.58
N06560 G1 X81.217 Y259.582
N06570 G1 X96.836 Y260.827
N06580 G1 X99.078 Y260.988
N06590 G1 X99.104 Y260.989
N06600 G1 X99.526 Y261.004
N06610 G2 X100.206 Y260.551 I0.025 J-0.7
N06620 G2 X102.049 Y260.207 I-0.73 J-9.01
N06630 G1 X102.072 Y260.2
N06640 G1 X102.914 Y259.917
N06650 G1 X103 Y259.882
N06660 G1 X103.724 Y259.526
N06670 G1 X103.768 Y259.502
N06680 G2 X104.831 Y258.23 I-1.232 J-2.11
N06690 G1 X104.84 Y258.205
N06700 G1 X104.85 Y258.175
N06710 G2 X104.273 Y255.56 I-2.53 J-0.813
N06720 G1 X104.256 Y255.543
N06730 G1 X104.232 Y255.518
N06740 G1 X104.21 Y255.496
N06750 G2 X103.06 Y254.962 I-1.404 J1.517
N06760 G1 X103.036 Y254.96
N06770 G1 X102.511 Y254.913
N06780 G1 X102.457 Y254.91
N06790 G1 X99.694 Y254.878
N06800 G1 X99.021 Y254.856
N06810 G1 X98.189 Y254.729
N06820 G1 X98.118 Y254.722
N06830 G1 X95.871 Y254.61
N06840 G1 X95.399 Y254.542
N06850 G3 X95.11 Y254.368 I0.148 J-0.575
N06860 G1 X95.099 Y254.355
N06870 G3 X95.01 Y253.806 I0.42 J-0.35
N06880 G3 X95.406 Y253.715 I0.432 J0.97
N06890 G1 X96.343 Y253.76
N06900 G1 X99.167 Y254.14
N06910 G1 X99.19 Y254.142
N06920 G1 X99.48 Y254.172
N06930 G2 X102.034 Y254.189 I1.369 J-13.763
N06940 G1 X102.048 Y254.188
N06950 G1 X103.101 Y254.076
N06960 G3 X107.494 Y253.805 I5.391 J51.611
N06970 G1 X108.8 Y253.79
N06980 G1 X109.725 Y253.795
N06990 G3 X114.046 Y253.954 I-0.769 J79.408
N07000 G1 X115.811 Y254.053
N07010 G1 X115.824 Y254.054
N07020 G1 X119.695 Y254.194
N07030 G1 X126.201 Y254.371
N07040 G1 X126.204 Y254.371
N07050 M5 $0 (plasma end)
N07060 G0 X130.456 Y239.902
N07070 M3 $0 S1 (plasma start)
N07080 G3 X127.685 Y242.232 I-2.55 J-0.221
N07090 G3 X122.033 Y241.338 I3.501 J-40.458
N07100 G1 X120.442 Y240.97
N07110 G2 X115.962 Y240.078 I-17.973 J78.553
N07120 G1 X115.89 Y240.07
N07130 G1 X114.822 Y240.001
N07140 G1 X114.801 Y240
N07150 G1 X111.452 Y239.884
N07160 G1 X111.402 Y239.884
N07170 G1 X110.286 Y239.926
N07180 G1 X110.23 Y239.93
N07190 G2 X108.709 Y240.56 I0.351 J2.999
N07200 G1 X108.7 Y240.567
N07210 G1 X108.69 Y240.575
N07220 G1 X108.679 Y240.584
N07230 G2 X107.607 Y242.313 I2.152 J2.531
N07240 G1 X107.594 Y242.376
N07250 G1 X107.494 Y243.032
N07260 G1 X107.49 Y243.064
N07270 G2 X108.571 Y245.349 I2.41 J0.258
N07280 G1 X108.595 Y245.364
N07290 G1 X108.906 Y245.55
N07300 G3 X109.334 Y245.955 I-0.807 J1.282
N07310 G1 X109.38 Y246.022
N07320 G1 X109.406 Y246.061
N07330 G1 X108.613 Y245.983
N07340 G1 X108.585 Y245.981
N07350 G2 X107.063 Y246.046 I-0.436 J7.6
N07360 G1 X106.854 Y246.076
N07370 G3 X105.768 Y246.075 I-0.54 J-3.574
N07380 G1 X105.356 Y245.98
N07390 G1 X104.631 Y245.761
N07400 G1 X104.609 Y245.754
N07410 G1 X103.239 Y245.389
N07420 G1 X103.22 Y245.384
N07430 G1 X102.113 Y245.123
N07440 G1 X102.09 Y245.118
N07450 G1 X101.703 Y245.04
N07460 G1 X101.673 Y245.035
N07470 G2 X99.541 Y244.991 I-1.229 J7.888
N07480 G1 X97.66 Y245.119
N07490 G1 X96.336 Y245.046
N07500 G1 X96.064 Y245.007
N07510 G2 X93.709 Y244.784 I-3.938 J29.049
N07520 G1 X93.695 Y244.783
N07530 G1 X91.803 Y244.72
N07540 G1 X91.751 Y244.72
N07550 G1 X90.636 Y244.765
N07560 G1 X90.554 Y244.773
N07570 G1 X89.805 Y244.893
N07580 G1 X89.756 Y244.903
N07590 G2 X88.704 Y245.403 I0.625 J2.67
N07600 G1 X88.686 Y245.417
N07610 G1 X88.635 Y245.459
N07620 G1 X88.625 Y245.468
N07630 G2 X87.924 Y246.331 I2.038 J2.373
N07640 G1 X87.743 Y246.647
N07650 G3 X87.465 Y246.922 I-0.742 J-0.473
N07660 G3 X85.708 Y246.947 I-0.907 J-1.998
N07670 G1 X85.653 Y246.927
N07680 G1 X84.658 Y246.605
N07690 G2 X81.625 Y246.313 I-2.209 J7.071
N07700 G1 X81.594 Y246.318
N07710 G1 X81.39 Y246.35
N07720 G3 X82.224 Y243.769 I33.149 J9.284
N07730 G1 X82.923 Y243.677
N07740 G1 X82.936 Y243.675
N07750 G2 X85.911 Y242.021 I-0.719 J-4.798
N07760 G1 X86.291 Y241.581
N07770 G1 X86.341 Y241.514
N07780 G1 X86.633 Y241.079
N07790 G1 X86.665 Y241.027
N07800 G2 X86.881 Y240.077 I-1.549 J-0.852
N07810 G1 X86.875 Y240.019
N07820 G1 X86.867 Y239.958
N07830 G1 X86.844 Y239.853
N07840 G2 X85.922 Y238.664 I-2.006 J0.604
N07850 G2 X84.894 Y238.171 I-3.098 J5.141
N07860 G3 X109.449 Y220.783 I31.895 J19.009
N07870 G1 X108.924 Y221.581
N07880 G1 X108.915 Y221.595
N07890 G1 X107.485 Y223.883
N07900 G2 X105.877 Y226.775 I31.664 J19.5
N07910 G1 X105.828 Y226.874
N07920 G1 X105.824 Y226.884
N07930 G2 X105.483 Y227.965 I3.78 J1.785
N07940 G1 X105.467 Y228.059
N07950 G2 X106.184 Y228.877 I0.69 J0.119
N07960 G1 X106.21 Y228.876
N07970 G1 X106.31 Y228.865
N07980 G2 X107.519 Y228.209 I-0.405 J-2.191
N07990 G1 X107.888 Y227.837
N08000 G1 X108.06 Y227.684
N08010 G1 X108.108 Y227.637
N08020 G1 X108.895 Y226.785
N08030 G1 X108.905 Y226.773
N08040 G2 X113.903 Y220.804 I-109.401 J-96.67
N08050 G1 X114.473 Y220.095
N08060 G3 X117.21 Y219.985 I2.967 J39.391
N08070 G1 X117.349 Y219.985
N08080 G3 X119.657 Y220.063 I-0.195 J39.799
N08090 G1 X119.022 Y221.485
N08100 G1 X119.013 Y221.508
N08110 G1 X118.24 Y223.42
N08120 G1 X118.233 Y223.436
N08130 G1 X117.867 Y224.409
N08140 G1 X117.85 Y224.463
N08150 G1 X117.756 Y224.791
N08160 G2 X117.729 Y225.012 I0.673 J0.193
N08170 G1 X117.752 Y225.588
N08180 G1 X117.761 Y225.673
N08190 G1 X117.765 Y225.697
N08200 G2 X118.992 Y226.033 I0.691 J-0.114
N08210 G1 X119.064 Y225.947
N08220 G1 X119.075 Y225.934
N08230 G2 X121.977 Y221.821 I-32.926 J-26.316
N08240 G1 X122.883 Y220.395
N08250 G3 X152.606 Y244.555 I-4.975 J36.484
N08260 G3 X150.239 Y244.157 I0.13 J-8.003
N08270 G1 X149.527 Y243.888
N08280 G2 X148.035 Y243.442 I-3.792 J9.97
N08290 G1 X147.923 Y243.419
N08300 G2 X145.602 Y243.224 I-2.015 J10.064
N08310 G1 X144.358 Y243.259
N08320 G3 X141.599 Y242.95 I-0.19 J-10.767
N08330 G1 X139.985 Y242.571
N08340 G1 X139.958 Y242.565
N08350 G1 X139.874 Y242.549
N08360 G2 X136.329 Y242.255 I-3.145 J16.434
N08370 G1 X132.668 Y242.374
N08380 G1 X131.142 Y242.383
N08390 G3 X127.685 Y242.232 I0.045 J-40.61
N08400 M5 $0 (plasma end)
N08410 G0 X133.374 Y214.938
N08420 M3 $0 S1 (plasma start)
N08430 G3 X130.175 Y216.634 I-2.447 J-0.751
N08440 G2 X129.971 Y216.571 I-12.678 J41.286
N08450 G1 X130.992 Y215.676
N08460 G1 X131.007 Y215.662
N08470 G1 X133.28 Y213.546
N08480 G1 X133.735 Y213.132
N08490 G1 X134.662 Y212.465
N08500 G3 X135.398 Y212.082 I2.34 J3.599
N08510 G1 X134.649 Y214.553
N08520 G1 X134.295 Y215.776
N08530 G2 X133.753 Y217.907 I36.504 J10.417
N08540 G2 X130.175 Y216.634 I-16.255 J40.013
N08550 M5 $0 (plasma end)
N08560 G0 X135.974 Y204.313
N08570 M3 $0 S1 (plasma start)
N08580 G3 X134.823 Y207.746 I-2.292 J1.141
N08590 G2 X133.179 Y208.872 I3.216 J6.458
N08600 G1 X133.16 Y208.888
N08610 G2 X131.691 Y210.284 I12.409 J14.529
N08620 G2 X129.232 Y213.171 I34.737 J32.082
N08630 G1 X128.466 Y214.133
N08640 G1 X128.444 Y214.161
N08650 G1 X128.017 Y214.757
N08660 G1 X127.53 Y215.397
N08670 G1 X127.488 Y215.458
N08680 G1 X127.256 Y215.841
N08690 G2 X125.823 Y215.538 I-9.84 J43.088
N08700 G1 X126.285 Y214.724
N08710 G1 X126.292 Y214.713
N08720 G1 X127.029 Y213.355
N08730 G1 X127.035 Y213.344
N08740 G1 X129.759 Y208.11
N08750 G1 X130.925 Y205.823
N08760 G1 X130.935 Y205.804
N08770 G1 X131.366 Y204.891
N08780 G3 X135.137 Y203.084 I15.89 J28.314
N08790 G1 X136.73 Y202.423
N08800 G1 X137.055 Y202.323
N08810 G1 X137.119 Y202.435
N08820 G3 X137.218 Y202.741 I-0.997 J0.491
N08830 G3 X137.273 Y204.465 I-6.885 J1.084
N08840 G3 X136.985 Y206.361 I-20.405 J-2.132
N08850 G1 X136.845 Y207.089
N08860 G2 X134.823 Y207.746 I1.194 J7.115
N08870 M5 $0 (plasma end)
N08880 G0 X121.401 Y213.52
N08890 M3 $0 S1 (plasma start)
N08900 G3 X120.727 Y214.841 I-0.998 J0.323
N08910 G2 X118.731 Y214.727 I-3.55 J44.485
N08920 G3 X121.508 Y211.826 I24.342 J20.52
N08930 G1 X121.547 Y211.789
N08940 G3 X124.48 Y209.252 I24.642 J25.522
N08950 G1 X121.934 Y214.954
N08960 G2 X120.727 Y214.841 I-4.758 J44.372
N08970 M5 $0 (plasma end)
N08980 G0 X13.549 Y163.385
N08990 M3 $0 S1 (plasma start)
N09000 G3 X12.42 Y163.385 I-0.564 J0
N09010 G3 X12.42 Y163.385 I1.129 J0
N09020 M5 $0 (plasma end)
N09030 G0 X118.817 Y98.306
N09040 M3 $0 S1 (plasma start)
N09050 G3 X121.318 Y100.923 I-0.058 J2.559
N09060 G3 X120.223 Y112.048 I-74.198 J-1.688
N09070 G1 X120.217 Y112.091
N09080 G1 X120.026 Y113.788
N09090 G1 X120.024 Y113.807
N09100 G1 X119.79 Y116.538
N09110 G1 X119.49 Y120.648
N09120 G1 X119.257 Y123.369
N09130 G1 X119.113 Y124.724
N09140 G3 X118.007 Y130.908 I-45.486 J-4.939
N09150 G1 X114.513 Y130.924
N09160 G1 X103.091 Y130.798
N09170 G1 X98.93 Y130.779
N09180 G2 X88.992 Y131.044 I-0.398 J171.442
N09190 G1 X88.816 Y131.055
N09200 G2 X80.35 Y132.516 I3.187 J43.72
N09210 G1 X80.338 Y132.519
N09220 G1 X79.024 Y132.908
N09230 G1 X78.889 Y132.939
N09240 G2 X77.424 Y129.837 I-10.765 J3.186
N09250 G1 X76.769 Y128.797
N09260 G1 X76.745 Y128.761
N09270 G1 X76.699 Y128.697
N09280 G1 X76.692 Y128.688
N09290 G2 X71.065 Y121.753 I-86.144 J64.15
N09300 G1 X67.938 Y118.146
N09310 G1 X66.192 Y116.061
N09320 G1 X65.344 Y115.007
N09330 G1 X64.52 Y113.946
N09340 G1 X64.028 Y113.249
N09350 G1 X63.564 Y112.521
N09360 G3 X63.199 Y111.593 I2.827 J-1.647
N09370 G3 X63.128 Y110.31 I9.91 J-1.193
N09380 G3 X63.404 Y107.296 I24.9 J0.76
N09390 G1 X63.478 Y106.786
N09400 G3 X66.754 Y94.047 I78.019 J13.274
N09410 G1 X66.86 Y93.737
N09420 G1 X66.879 Y93.673
N09430 G1 X67.29 Y91.958
N09440 G1 X67.654 Y90.698
N09450 G3 X68.635 Y89.011 I4.503 J1.489
N09460 G1 X70.246 Y87.486
N09470 G1 X121.397 Y86.346
N09480 G2 X121.447 Y86.575 I2.734 J-0.482
N09490 G1 X121.464 Y86.629
N09500 G1 X121.732 Y87.389
N09510 G1 X121.741 Y87.413
N09520 G1 X121.962 Y87.973
N09530 G3 X122.08 Y88.472 I-2.07 J0.752
N09540 G1 X122.082 Y88.49
N09550 G3 X121.714 Y90.299 I-3.405 J0.248
N09560 G1 X121.694 Y90.34
N09570 G1 X121.371 Y91.081
N09580 G1 X121.359 Y91.112
N09590 G1 X121.111 Y91.765
N09600 G1 X121.098 Y91.802
N09610 G1 X120.867 Y92.159
N09620 G1 X120.796 Y92.241
N09630 G2 X120.776 Y93.13 I0.531 J0.456
N09640 G1 X121.12 Y93.567
N09650 G3 X121.318 Y100.923 I-74 J5.668
N09660 M5 $0 (plasma end)
N09670 G0 X282.633 Y100.385
N09680 M3 $0 S1 (plasma start)
N09690 G3 X279.139 Y99.439 I-1.274 J-2.22
N09700 G2 X277.921 Y99.444 I-0.607 J0.348
N09710 G1 X277.112 Y97.564
N09720 G2 X276.117 Y97.235 I-0.643 J0.277
N09730 G1 X275.891 Y96.528
N09740 G2 X275.676 Y96.207 I-0.667 J0.213
N09750 G1 X275.66 Y96.194
N09760 G2 X275.367 Y96.046 I-0.452 J0.535
N09770 G1 X275.259 Y96.021
N09780 G1 X275.129 Y96.004
N09790 G3 X275.226 Y95.756 I6.406 J2.362
N09800 G1 X275.231 Y95.744
N09810 G1 X275.257 Y95.676
N09820 G3 X276.354 Y93.74 I13.871 J6.579
N09830 G1 X276.421 Y93.614
N09840 G2 X276.58 Y89.965 I-5.074 J-2.049
N09850 G3 X307.888 Y91.429 I2.266 J286.9
N09860 G3 X308.193 Y95.35 I-8.621 J2.643
N09870 G1 X308.187 Y95.403
N09880 G1 X308.179 Y95.53
N09890 G3 X307.805 Y98.44 I-31.538 J-2.571
N09900 G1 X307.607 Y99.615
N09910 G1 X307.035 Y102.014
N09920 G3 X306.391 Y104.268 I-31.521 J-7.787
N09930 G1 X306 Y105.503
N09940 G1 X305.409 Y107.118
N09950 G1 X304.927 Y108.344
N09960 G1 X304.447 Y109.452
N09970 G1 X303.557 Y111.32
N09980 G1 X303.464 Y111.497
N09990 G3 X296.706 Y121.274 I-42.592 J-22.215
N10000 G1 X295.883 Y122.215
N10010 G1 X294.094 Y124.163
N10020 G1 X289.939 Y128.469
N10030 G1 X289.109 Y129.336
N10040 G1 X289.101 Y129.344
N10050 G2 X286.545 Y132.524 I21.454 J19.869
N10060 G1 X284.823 Y134.35
N10070 G1 X284.634 Y134.534
N10080 G1 X283.44 Y133.404
N10090 G1 X282.184 Y132.083
N10100 G3 X280.759 Y129.661 I5.689 J-4.977
N10110 G3 X280.96 Y128.002 I2.809 J-0.502
N10120 G3 X281.958 Y126.312 I9.15 J4.268
N10130 G1 X282.062 Y126.175
N10140 G3 X287.999 Y121.471 I13.206 J10.57
N10150 G1 X288.017 Y121.463
N10160 G1 X288.184 Y121.378
N10170 G3 X289.741 Y120.804 I3.228 J6.362
N10180 G1 X289.757 Y120.8
N10190 G1 X290.42 Y120.624
N10200 G1 X290.464 Y120.611
N10210 G1 X291.544 Y120.246
N10220 G1 X291.624 Y120.213
N10230 G1 X291.696 Y120.178
N10240 G2 X291.868 Y120.061 I-0.305 J-0.63
N10250 G2 X292.482 Y116.914 I-1.849 J-1.994
N10260 G1 X292.461 Y116.862
N10270 G2 X291.373 Y114.877 I-8.915 J3.596
N10280 G1 X291.363 Y114.863
N10290 G2 X288.66 Y111.851 I-18.738 J14.091
N10300 G1 X287.746 Y110.995
N10310 G3 X280.588 Y101.811 I37.27 J-36.433
N10320 G1 X280.582 Y101.801
N10330 G1 X279.687 Y100.395
N10340 G1 X279.139 Y99.439
N10350 M5 $0 (plasma end)
N10360 G0 X117.37 Y171.19
N10370 M3 $0 S1 (plasma start)
N10380 G3 X120.274 Y169.028 I2.533 J0.371
N10390 G1 X121.603 Y169.222
N10400 G1 X123.639 Y169.493
N10410 G1 X124.861 Y169.64
N10420 G1 X124.89 Y169.643
N10430 G1 X125.743 Y169.71
N10440 G1 X125.806 Y169.712
N10450 G1 X127.222 Y169.694
N10460 G1 X127.239 Y169.694
N10470 G1 X127.928 Y169.669
N10480 G1 X129.441 Y169.699
N10490 G1 X129.497 Y169.702
N10500 G3 X138.028 Y173.247 I-1.812 J16.401
N10510 G1 X138.047 Y173.261
N10520 G1 X138.202 Y173.378
N10530 G3 X145.717 Y182.851 I-17.409 J21.529
N10540 G1 X145.732 Y182.879
N10550 G3 X146.252 Y184.155 I-5.574 J3.018
N10560 G1 X146.256 Y184.169
N10570 G3 X146.354 Y184.909 I-2.151 J0.662
N10580 G2 X138.564 Y189.655 I1.86 J11.82
N10590 G1 X138.5 Y189.738
N10600 G1 X138.458 Y189.797
N10610 G2 X137.886 Y191.241 I3.604 J2.261
N10620 G2 X137.924 Y191.636 I0.687 J0.134
N10630 G1 X138.187 Y192.293
N10640 G2 X138.531 Y192.661 I0.65 J-0.261
N10650 G1 X138.562 Y192.676
N10660 G2 X138.769 Y192.74 I0.306 J-0.63
N10670 G2 X142.026 Y192.548 I1.156 J-8.128
N10680 G1 X144.067 Y192.06
N10690 G3 X145.517 Y191.841 I2.253 J9.989
N10700 G1 X145.532 Y191.84
N10710 G1 X147.255 Y191.667
N10720 G3 X147.997 Y191.664 I0.389 J4.789
N10730 G1 X148.046 Y191.694
N10740 G1 X149.15 Y192.5
N10750 G2 X149.317 Y192.616 I2.959 J-4.086
N10760 G1 X149.229 Y192.727
N10770 G1 X148.452 Y193.216
N10780 G3 X146.425 Y194.035 I-6.571 J-13.331
N10790 G3 X141.471 Y195.409 I-20.419 J-64.002
N10800 G1 X138.099 Y196.228
N10810 G1 X136.412 Y196.658
N10820 G1 X135.776 Y196.829
N10830 G1 X135.742 Y196.839
N10840 G1 X135.057 Y197.061
N10850 G1 X135.022 Y197.073
N10860 G2 X124.812 Y202.974 I13.441 J35.04
N10870 G1 X124.682 Y203.075
N10880 G2 X121.492 Y205.739 I32.741 J42.446
N10890 G1 X121.344 Y205.873
N10900 G2 X115.467 Y212.008 I32.783 J37.282
N10910 G1 X115.441 Y212.043
N10920 G1 X113.439 Y214.875
N10930 G2 X79.477 Y237.005 I3.383 J42.317
N10940 G2 X78.496 Y236.895 I-1.175 J6.034
N10950 G1 X74.582 Y236.696
N10960 G1 X73.543 Y236.656
N10970 G1 X73.521 Y236.655
N10980 G1 X70.577 Y236.634
N10990 G3 X67.9 Y236.453 I0.323 J-24.707
N11000 G1 X67.477 Y236.399
N11010 G2 X64.245 Y236.283 I-2.293 J18.801
N11020 G1 X63.373 Y236.329
N11030 G3 X58.519 Y236.467 I-5.036 J-91.953
N11040 G1 X58.31 Y236.467
N11050 G3 X55.546 Y236.223 I0.057 J-16.405
N11060 G1 X55.196 Y236.159
N11070 G3 X53.357 Y235.625 I1.753 J-9.465
N11080 G3 X52.482 Y235.045 I1.034 J-2.512
N11090 G1 X52.417 Y234.979
N11100 G3 X51.956 Y234.39 I2.646 J-2.55
N11110 G1 X52.388 Y234.378
N11120 G1 X53.351 Y234.396
N11130 G2 X56.223 Y234.314 I0.594 J-29.342
N11140 G1 X56.267 Y234.309
N11150 G1 X57.407 Y234.148
N11160 G1 X57.444 Y234.142
N11170 G1 X57.836 Y234.065
N11180 G1 X59.675 Y233.834
N11190 G1 X60.68 Y233.743
N11200 G1 X60.753 Y233.732
N11210 G1 X61.206 Y233.643
N11220 G1 X61.278 Y233.624
N11230 G2 X61.978 Y233.121 I-0.405 J-1.303
N11240 G1 X61.993 Y233.1
N11250 G1 X62.011 Y233.072
N11260 G2 X62.267 Y232.139 I-1.463 J-0.903
N11270 G1 X62.264 Y232.087
N11280 G2 X59.875 Y228.67 I-4.19 J0.387
N11290 G1 X59.847 Y228.658
N11300 G1 X59.782 Y228.63
N11310 G1 X59.734 Y228.613
N11320 G2 X58.139 Y228.406 I-1.317 J3.896
N11330 G1 X54.435 Y228.623
N11340 G1 X52.89 Y228.671
N11350 G1 X51.925 Y228.647
N11360 G1 X50.377 Y228.457
N11370 G1 X47.455 Y228.022
N11380 G2 X44.85 Y227.729 I-5.348 J35.873
N11390 G1 X44.83 Y227.728
N11400 G1 X42.93 Y227.64
N11410 G1 X42.884 Y227.639
N11420 G1 X42.589 Y227.645
N11430 G1 X42.563 Y227.646
N11440 G2 X40.757 Y227.85 I0.916 J16.173
N11450 G1 X40.728 Y227.855
N11460 G2 X35.875 Y229.293 I2.889 J18.654
N11470 G3 X29.049 Y214.703 I126.841 J-68.236
N11480 G1 X28.034 Y212.124
N11490 G1 X27.747 Y211.354
N11500 G3 X23.264 Y197.095 I130.306 J-48.809
N11510 G1 X22.707 Y194.918
N11520 G1 X21.929 Y191.559
N11530 G1 X21.53 Y189.671
N11540 G3 X18.746 Y153.485 I143.386 J-29.23
N11550 G1 X18.932 Y150.119
N11560 G1 X19.041 Y148.682
N11570 G3 X19.806 Y141.499 I125.938 J9.776
N11580 G1 X20.189 Y138.691
N11590 G1 X20.717 Y135.4
N11600 G1 X21.194 Y132.832
N11610 G3 X23.227 Y123.794 I133.504 J25.29
N11620 G1 X24.402 Y119.554
N11630 G1 X25.206 Y116.898
N11640 G1 X25.804 Y115.039
N11650 G1 X26.268 Y113.655
N11660 G1 X27.348 Y110.576
N11670 G1 X28.501 Y107.5
N11680 G1 X28.617 Y107.197
N11690 G1 X28.66 Y107.025
N11700 G1 X29.917 Y104.028
N11710 G1 X30.026 Y104.088
N11720 G1 X30.199 Y104.164
N11730 G1 X30.307 Y104.202
N11740 G1 X30.932 Y104.362
N11750 G1 X30.988 Y104.383
N11760 G1 X31.015 Y104.485
N11770 G1 X31.564 Y106.09
N11780 G1 X32.028 Y107.549
N11790 G3 X34.89 Y118.723 I-154.63 J45.565
N11800 G1 X35.931 Y123.251
N11810 G1 X36.557 Y125.89
N11820 G2 X37.154 Y127.97 I26.771 J-6.564
N11830 G1 X37.168 Y128.009
N11840 G2 X38.639 Y129.3 I1.999 J-0.793
N11850 G1 X39.098 Y129.463
N11860 G1 X39.368 Y129.572
N11870 G1 X39.422 Y129.591
N11880 G1 X42.925 Y130.688
N11890 G3 X45.354 Y131.572 I-12.573 J38.344
N11900 G3 X49.471 Y133.788 I-6.787 J17.54
N11910 G1 X49.507 Y133.814
N11920 G1 X49.542 Y133.838
N11930 G3 X53.361 Y139.653 I-4.563 J7.158
N11940 G1 X53.377 Y139.842
N11950 G3 X53.457 Y142.848 I-29.607 J2.29
N11960 G1 X53.389 Y144.688
N11970 G1 X53.168 Y148.385
N11980 G1 X53.111 Y149.63
N11990 G1 X53.111 Y149.645
N12000 G1 X53.082 Y150.882
N12010 G2 X53.412 Y155.545 I25.725 J0.525
N12020 G1 X53.418 Y155.589
N12030 G2 X58.575 Y164.312 I12.692 J-1.617
N12040 G1 X58.548 Y164.345
N12050 G3 X57.985 Y164.877 I-3.127 J-2.742
N12060 G1 X57.885 Y164.958
N12070 G3 X56.443 Y165.935 I-9.029 J-11.767
N12080 G1 X55.115 Y166.724
N12090 G1 X55.087 Y166.741
N12100 G1 X53.808 Y167.584
N12110 G1 X53.791 Y167.595
N12120 G2 X51.714 Y169.843 I4.139 J5.909
N12130 G1 X51.708 Y169.854
N12140 G1 X51.69 Y169.885
N12150 G2 X51.112 Y171.981 I3.908 J2.205
N12160 G1 X51.112 Y172.007
N12170 G2 X51.663 Y175.139 I9.871 J-0.12
N12180 G1 X52.627 Y178.19
N12190 G2 X53.768 Y181.315 I42.806 J-13.857
N12200 G1 X53.82 Y181.442
N12210 G2 X54.876 Y183.536 I10.289 J-3.879
N12220 G2 X56.091 Y184.082 I1.026 J-0.66
N12230 G1 X56.312 Y184.059
N12240 G2 X56.518 Y184.006 I-0.072 J-0.696
N12250 G1 X56.54 Y183.996
N12260 G2 X56.924 Y183.583 I-0.277 J-0.643
N12270 G1 X56.964 Y183.469
N12280 G1 X56.974 Y183.436
N12290 G2 X57.622 Y178.856 I-15.413 J-4.516
N12300 G1 X57.681 Y176.969
N12310 G1 X57.81 Y175.389
N12320 G3 X62.603 Y167.82 I12.449 J2.582
N12330 G1 X63.633 Y167.138
N12340 G1 X64.154 Y166.867
N12350 G3 X65.08 Y166.778 I0.596 J1.338
N12360 G1 X65.145 Y166.79
N12370 G1 X65.244 Y166.803
N12380 G1 X65.289 Y166.808
N12390 G2 X76.884 Y166.313 I3.588 J-52.056
N12400 G1 X81.591 Y165.713
N12410 G1 X83.154 Y165.54
N12420 G1 X84.717 Y165.398
N12430 G1 X85.499 Y165.341
N12440 G1 X85.514 Y165.34
N12450 G3 X98.674 Y165.614 I5.391 J57.23
N12460 G1 X102.434 Y166.106
N12470 G1 X106.461 Y166.728
N12480 G1 X115.527 Y168.274
N12490 G1 X119.57 Y168.925
N12500 G1 X119.58 Y168.926
N12510 G1 X120.274 Y169.028
N12520 M5 $0 (plasma end)
N12530 G0 X4.265 Y89.25
N12540 M3 $0 S1 (plasma start)
N12550 G3 X6.825 Y86.69 I2.56 J0
N12560 G1 X26.985 Y86.69
N12570 G1 X25.912 Y88.699
N12580 G1 X25.905 Y88.714
N12590 G1 X24.578 Y91.349
N12600 G1 X23.778 Y92.989
N12610 G2 X18.834 Y104.454 I136.872 J65.826
N12620 G1 X17.999 Y106.66
N12630 G1 X17.995 Y106.671
N12640 G1 X17.255 Y108.733
N12650 G1 X16.531 Y110.825
N12660 G1 X16.526 Y110.838
N12670 G1 X15.26 Y114.753
N12680 G1 X15.256 Y114.767
N12690 G1 X14.435 Y117.506
N12700 G1 X14.432 Y117.516
N12710 G1 X13.974 Y119.133
N12720 G1 X13.971 Y119.145
N12730 G1 X13.377 Y121.391
N12740 G1 X12.875 Y123.383
N12750 G1 X12.871 Y123.397
N12760 G1 X11.698 Y128.497
N12770 G1 X11.693 Y128.518
N12780 G1 X11.255 Y130.725
N12790 G1 X11.252 Y130.736
N12800 G1 X10.638 Y134.103
N12810 G1 X10.636 Y134.118
N12820 G1 X10.091 Y137.509
N12830 G1 X10.089 Y137.527
N12840 G1 X9.563 Y141.468
N12850 G1 X9.561 Y141.479
N12860 G1 X9.381 Y143.013
N12870 G1 X9.38 Y143.025
N12880 G1 X9.006 Y146.775
N12890 G1 X9.005 Y146.788
N12900 G1 X8.822 Y149.016
N12910 G1 X8.821 Y149.032
N12920 G1 X8.611 Y152.607
N12930 G1 X8.52 Y154.643
N12940 G1 X8.46 Y156.482
N12950 G1 X8.431 Y157.868
N12960 G1 X8.431 Y157.88
N12970 G1 X8.423 Y160.322
N12980 G1 X8.446 Y163.391
N12990 G1 X8.446 Y163.404
N13000 G1 X8.507 Y165.651
N13010 G1 X8.507 Y165.663
N13020 G1 X8.637 Y168.623
N13030 G1 X8.737 Y170.358
N13040 G2 X11.365 Y190.691 I156.582 J-9.902
N13050 G1 X11.535 Y191.535
N13060 G2 X26.492 Y233.25 I152.809 J-31.252
N13070 G1 X27.967 Y235.97
N13080 G1 X27.974 Y235.982
N13090 G1 X29.225 Y238.188
N13100 G1 X30.223 Y239.897
N13110 G2 X35.944 Y248.85 I144.423 J-86.002
N13120 G1 X37.786 Y251.476
N13130 G1 X37.793 Y251.485
N13140 G1 X39.066 Y253.238
N13150 G1 X40.69 Y255.412
N13160 G1 X40.698 Y255.422
N13170 G1 X41.182 Y256.046
N13180 G2 X56.915 Y273.63 I127.317 J-98.078
N13190 G1 X60.747 Y277.227
N13200 G1 X60.757 Y277.236
N13210 G1 X62.168 Y278.509
N13220 G2 X69.692 Y284.786 I111.664 J-126.194
N13230 G1 X72.618 Y287.032
N13240 G1 X72.627 Y287.04
N13250 G1 X74.581 Y288.487
N13260 G1 X76.565 Y289.914
N13270 G2 X90.97 Y299.007 I96.356 J-136.682
N13280 G1 X95.014 Y301.209
N13290 G1 X95.026 Y301.215
N13300 G1 X97.051 Y302.265
N13310 G1 X97.061 Y302.27
N13320 G1 X99.766 Y303.618
N13330 G1 X99.779 Y303.624
N13340 G1 X102.515 Y304.919
N13350 G1 X103.939 Y305.579
N13360 G1 X103.951 Y305.585
N13370 G1 X107.43 Y307.117
N13380 G1 X107.442 Y307.122
N13390 G1 X109.315 Y307.907
N13400 G1 X111.208 Y308.673
N13410 G1 X113.112 Y309.418
N13420 G1 X116.051 Y310.523
N13430 G1 X116.069 Y310.53
N13440 G1 X120.763 Y312.146
N13450 G1 X120.776 Y312.15
N13460 G1 X123.787 Y313.118
N13470 G1 X123.801 Y313.123
N13480 G1 X126.842 Y314.032
N13490 G1 X126.853 Y314.035
N13500 G1 X128.906 Y314.612
N13510 G1 X128.92 Y314.616
N13520 G1 X133.557 Y315.819
N13530 G1 X133.572 Y315.822
N13540 G1 X135.765 Y316.342
N13550 G1 X135.775 Y316.344
N13560 G1 X137.522 Y316.73
N13570 G2 X146.545 Y318.472 I35.538 J-159.876
N13580 G1 X146.798 Y318.513
N13590 G2 X181.09 Y320.563 I27.359 J-169.818
N13600 G1 X181.351 Y320.552
N13610 G2 X262.922 Y295.954 I-6.713 J-169.812
N13620 G1 X263.662 Y295.5
N13630 G2 X281.756 Y282.61 I-88.083 J-142.794
N13640 G1 X281.966 Y282.439
N13650 G2 X318.384 Y240.459 I-103.803 J-126.838
N13660 G1 X318.695 Y239.942
N13670 G2 X329.328 Y218.759 I-134.967 J-81.007
N13680 G1 X329.431 Y218.509
N13690 G2 X340.944 Y154.999 I-142.773 J-58.681
N13700 G1 X340.906 Y153.553
N13710 G1 X340.905 Y153.536
N13720 G1 X340.698 Y149.503
N13730 G1 X340.697 Y149.486
N13740 G1 X340.399 Y145.621
N13750 G1 X340.398 Y145.606
N13760 G1 X340.135 Y142.917
N13770 G1 X340.134 Y142.906
N13780 G1 X339.895 Y140.814
N13790 G1 X339.708 Y139.318
N13800 G1 X339.706 Y139.306
N13810 G1 X339.17 Y135.579
N13820 G1 X339.168 Y135.566
N13830 G1 X338.71 Y132.768
N13840 G1 X338.707 Y132.751
N13850 G1 X338.632 Y132.358
N13860 G2 X336.709 Y123.106 I-148.134 J25.968
N13870 G1 X335.861 Y119.756
N13880 G1 X335.856 Y119.74
N13890 G1 X334.74 Y115.715
N13900 G1 X334.736 Y115.701
N13910 G1 X334.236 Y114.035
N13920 G1 X334.231 Y114.02
N13930 G1 X332.571 Y108.918
N13940 G1 X332.565 Y108.899
N13950 G1 X331.759 Y106.636
N13960 G1 X330.609 Y103.539
N13970 G1 X330.604 Y103.526
N13980 G1 X329.819 Y101.539
N13990 G1 X329.816 Y101.53
N14000 G1 X328.824 Y99.12
N14010 G1 X328.817 Y99.104
N14020 G1 X327.362 Y95.805
N14030 G1 X327.356 Y95.792
N14040 G1 X325.501 Y91.8
N14050 G1 X325.491 Y91.781
N14060 G1 X323.508 Y87.84
N14070 G1 X323.499 Y87.825
N14080 G1 X322.892 Y86.69
N14090 G1 X343.394 Y86.69
N14100 G2 X347.427 Y80.661 I0.009 J-4.357
N14110 G3 X347.435 Y14.499 I79.651 J-33.073
N14120 G2 X343.404 Y8.488 I-4.031 J-1.654
N14130 G1 X230.587 Y8.488
N14140 G2 X181.093 Y-0.595 I-54.8 J159.222
N14150 G1 X180.417 Y-0.627
N14160 G1 X180.396 Y-0.628
N14170 G1 X176.173 Y-0.7
N14180 G1 X176.155 Y-0.7
N14190 G1 X171.85 Y-0.662
N14200 G1 X171.839 Y-0.662
N14210 G1 X169.051 Y-0.594
N14220 G1 X167.869 Y-0.548
N14230 G2 X155.838 Y0.395 I7.489 J172.722
N14240 G1 X154.903 Y0.502
N14250 G2 X144.764 Y2.007 I20.023 J169.773
N14260 G1 X142.912 Y2.354
N14270 G1 X139.699 Y2.999
N14280 G1 X137.603 Y3.448
N14290 G1 X137.593 Y3.45
N14300 G1 X135.433 Y3.948
N14310 G1 X132.971 Y4.552
N14320 G1 X132.959 Y4.555
N14330 G1 X129.11 Y5.568
N14340 G1 X129.092 Y5.573
N14350 G1 X125.474 Y6.625
N14360 G1 X125.462 Y6.629
N14370 G1 X122.419 Y7.573
N14380 G1 X120.551 Y8.182
N14390 G1 X119.653 Y8.488
N14400 G1 X3.672 Y8.488
N14410 G2 X-0.367 Y14.516 I-0.015 J4.357
N14420 G3 X-0.374 Y80.678 I-79.651 J33.073
N14430 G2 X3.657 Y86.69 I4.031 J1.654
N14440 G1 X6.825 Y86.69
N14450 M5 $0 (plasma end)
N14460 G0 X316.937 Y100.298
N14470 M3 $0 S1 (plasma start)
N14480 G3 X315.289 Y97.075 I0.787 J-2.436
N14490 G1 X315.589 Y96.147
N14500 G1 X315.596 Y96.122
N14510 G1 X315.867 Y95.161
N14520 G1 X316.755 Y96.987
N14530 G1 X318.538 Y100.89
N14540 G1 X319.367 Y102.804
N14550 G1 X320.107 Y104.597
N14560 G1 X320.989 Y106.84
N14570 G1 X321.159 Y110.939
N14580 G1 X321.252 Y114.878
N14590 G1 X321.298 Y118.822
N14600 G1 X321.326 Y130.676
N14610 G1 X321.338 Y132.538
N14620 G1 X321.137 Y132.911
N14630 G1 X321.026 Y133.079
N14640 G3 X320.344 Y133.794 I-3.523 J-2.677
N14650 G1 X319.465 Y134.508
N14660 G1 X319.452 Y134.519
N14670 G1 X318.237 Y135.556
N14680 G2 X317.289 Y135.395 I-1.051 J3.312
N14690 G1 X317.171 Y135.401
N14700 G1 X316.988 Y135.427
N14710 G1 X316.871 Y135.454
N14720 G2 X316.371 Y135.837 I0.284 J0.888
N14730 G1 X316.071 Y135.699
N14740 G1 X316.002 Y135.672
N14750 G1 X315.668 Y135.56
N14760 G1 X315.531 Y135.529
N14770 G1 X315.154 Y135.483
N14780 G1 X315.051 Y135.478
N14790 G2 X314.505 Y135.641 I0.029 J1.094
N14800 G2 X312.721 Y135.434 I-1.557 J5.616
N14810 G1 X312.66 Y135.439
N14820 G1 X312.388 Y135.473
N14830 G2 X312.168 Y135.539 I0.088 J0.694
N14840 G1 X311.981 Y135.63
N14850 G2 X311.808 Y135.751 I0.308 J0.629
N14860 G2 X311.536 Y136.343 I0.601 J0.634
N14870 G1 X311.545 Y136.495
N14880 G1 X311.571 Y136.646
N14890 G1 X311.589 Y136.722
N14900 G2 X311.359 Y136.743 I0.146 J2.845
N14910 G1 X311.301 Y136.753
N14920 G1 X311.247 Y136.765
N14930 G2 X310.929 Y136.928 I0.15 J0.684
N14940 G1 X310.902 Y136.953
N14950 G2 X310.68 Y137.354 I0.468 J0.52
N14960 G1 X310.674 Y137.39
N14970 G1 X310.664 Y137.525
N14980 G1 X310.53 Y137.541
N14990 G1 X310.5 Y137.546
N15000 G1 X309.664 Y137.691
N15010 G2 X308.409 Y137.406 I-1.299 J2.813
N15020 G1 X308.366 Y137.407
N15030 G1 X308.261 Y137.412
N15040 G2 X307.085 Y138.173 I0.063 J1.386
N15050 G1 X307.055 Y138.242
N15060 G2 X306.947 Y138.636 I2.074 J0.781
N15070 G2 X306.472 Y138.602 I-0.487 J3.549
N15080 G1 X306.458 Y138.603
N15090 G1 X306.404 Y138.603
N15100 G2 X305.214 Y138.721 I0.148 J7.582
N15110 G2 X304.299 Y139.063 I0.496 J2.721
N15120 G2 X303.848 Y141.18 I0.766 J1.269
N15130 G1 X303.867 Y141.205
N15140 G2 X305.624 Y142.355 I2.513 J-1.921
N15150 G1 X306.166 Y142.501
N15160 G2 X306.639 Y143.39 I2.065 J-0.529
N15170 G1 X306.518 Y143.507
N15180 G1 X306.154 Y143.851
N15190 G1 X306.126 Y143.879
N15200 G1 X305.917 Y144.1
N15210 G1 X305.898 Y144.12
N15220 G2 X305.501 Y144.83 I1.485 J1.298
N15230 G1 X305.472 Y144.969
N15240 G1 X305.463 Y145.064
N15250 G1 X305.471 Y145.258
N15260 G2 X305.933 Y146.042 I1.292 J-0.233
N15270 G2 X306.482 Y146.295 I0.716 J-0.833
N15280 G1 X306.64 Y146.301
N15290 G1 X307.423 Y146.243
N15300 G2 X307.426 Y146.893 I1.528 J0.317
N15310 G2 X307.328 Y147.117 I0.933 J0.543
N15320 G1 X307.297 Y147.306
N15330 G1 X307.292 Y147.502
N15340 G2 X307.319 Y147.715 I0.7 J0.019
N15350 G2 X307.727 Y148.452 I1.826 J-0.53
N15360 G2 X308.518 Y149.194 I4.583 J-4.093
N15370 G2 X308.155 Y149.45 I0.54 J1.15
N15380 G1 X308.114 Y149.495
N15390 G1 X308.095 Y149.518
N15400 G2 X307.964 Y149.759 I0.538 J0.448
N15410 G1 X307.951 Y149.804
N15420 G2 X307.96 Y150.245 I0.669 J0.206
N15430 G1 X307.988 Y150.324
N15440 G2 X308.145 Y150.576 I0.659 J-0.235
N15450 G1 X308.342 Y150.78
N15460 G1 X308.367 Y150.804
N15470 G2 X307.495 Y151.813 I2.22 J2.799
N15480 G2 X307.198 Y152.541 I1.944 J1.218
N15490 G2 X307.395 Y153.59 I1.288 J0.301
N15500 G2 X307.533 Y153.739 I0.577 J-0.396
N15510 G1 X307.599 Y153.792
N15520 G2 X307.892 Y153.932 I0.44 J-0.545
N15530 G1 X307.934 Y153.941
N15540 G2 X308.372 Y153.893 I0.147 J-0.684
N15550 G1 X308.497 Y153.836
N15560 G1 X308.507 Y153.831
N15570 G3 X310.397 Y153.08 I6.576 J13.791
N15580 G2 X310.383 Y154.055 I1.587 J0.51
N15590 G1 X310.392 Y154.086
N15600 G1 X310.42 Y154.165
N15610 G1 X310.441 Y154.22
N15620 G2 X311.075 Y154.939 I1.44 J-0.631
N15630 G2 X311.961 Y155.322 I1.928 J-3.245
N15640 G2 X312 Y155.584 I2.488 J-0.234
N15650 G1 X311.051 Y155.324
N15660 G1 X311.02 Y155.317
N15670 G2 X309.657 Y155.182 I-1.227 J5.463
N15680 G1 X309.643 Y155.183
N15690 G1 X309.384 Y155.194
N15700 G1 X309.272 Y155.208
N15710 G1 X309.137 Y155.237
N15720 G1 X309.045 Y155.263
N15730 G2 X308.53 Y156.398 I0.292 J0.817
N15740 G1 X308.568 Y156.478
N15750 G1 X308.685 Y156.691
N15760 G1 X308.753 Y156.792
N15770 G2 X309.433 Y157.466 I3.309 J-2.657
N15780 G1 X309.493 Y157.509
N15790 G1 X309.782 Y157.691
N15800 G2 X310.266 Y157.966 I4.68 J-7.657
N15810 G2 X309.778 Y158.762 I1.596 J1.527
N15820 G1 X309.756 Y158.838
N15830 G2 X310.864 Y160.207 I1.091 J0.249
N15840 G1 X310.92 Y160.204
N15850 G1 X311.335 Y160.164
N15860 G1 X311.457 Y160.141
N15870 G1 X312.194 Y159.936
N15880 G1 X312.345 Y159.905
N15890 G3 X313.775 Y159.834 I1.212 J9.946
N15900 G2 X313.863 Y160.057 I0.686 J-0.139
N15910 G1 X313.877 Y160.081
N15920 G2 X314.033 Y160.261 I0.599 J-0.362
N15930 G1 X313.816 Y160.732
N15940 G1 X313.765 Y160.778
N15950 G2 X313.515 Y161.365 I0.593 J0.599
N15960 G1 X312.978 Y162.58
N15970 G1 X312.972 Y162.593
N15980 G1 X312.921 Y162.714
N15990 G1 X312.882 Y162.838
N16000 G1 X312.879 Y162.852
N16010 G1 X312.864 Y163.029
N16020 G2 X313.235 Y163.69 I0.841 J-0.037
N16030 G2 X313.235 Y163.96 I2.844 J0.133
N16040 G1 X313.237 Y163.987
N16050 G2 X313.527 Y164.593 I0.948 J-0.082
N16060 G2 X314.002 Y164.831 I0.593 J-0.589
N16070 G2 X313.404 Y165.567 I5.498 J5.082
N16080 G2 X313.293 Y165.808 I0.57 J0.406
N16090 G1 X313.281 Y165.858
N16100 G2 X313.31 Y166.28 I0.68 J0.165
N16110 G1 X313.334 Y166.34
N16120 G1 X313.392 Y166.454
N16130 G2 X313.621 Y166.706 I0.808 J-0.506
N16140 G1 X313.564 Y166.744
N16150 G2 X313.046 Y167.734 I0.755 J1.026
N16160 G1 X313.046 Y167.775
N16170 G1 X313.047 Y167.794
N16180 G1 X313.048 Y167.815
N16190 G2 X313.534 Y168.739 I1.267 J-0.077
N16200 G2 X313.509 Y169.342 I1.313 J0.358
N16210 G2 X313.343 Y170.38 I1.129 J0.712
N16220 G1 X313.386 Y170.502
N16230 G1 X313.503 Y170.756
N16240 G1 X313.534 Y170.815
N16250 G2 X314.661 Y171.405 I1.032 J-0.601
N16260 G1 X314.683 Y171.498
N16270 G1 X314.752 Y171.681
N16280 G1 X314.853 Y171.863
N16290 G2 X314.62 Y172.237 I0.513 J0.578
N16300 G1 X314.598 Y172.353
N16310 G2 X314.621 Y172.662 I0.897 J0.089
N16320 G2 X313.23 Y173.684 I1.254 J3.166
N16330 G1 X313.169 Y173.773
N16340 G1 X312.996 Y174.07
N16350 G1 X312.95 Y174.166
N16360 G2 X312.935 Y174.918 I1.009 J0.396
N16370 G1 X313.026 Y175.094
N16380 G1 X313.097 Y175.194
N16390 G1 X313.123 Y175.228
N16400 G1 X312.955 Y175.363
N16410 G1 X312.893 Y175.419
N16420 G1 X312.115 Y176.21
N16430 G1 X312.105 Y176.22
N16440 G2 X311.087 Y177.537 I6.13 J5.787
N16450 G2 X310.558 Y178.826 I3.306 J2.11
N16460 G1 X310.547 Y178.898
N16470 G1 X310.542 Y178.939
N16480 G2 X310.576 Y179.24 I0.696 J0.074
N16490 G1 X310.598 Y179.304
N16500 G2 X310.725 Y179.528 I0.662 J-0.226
N16510 G1 X310.798 Y179.615
N16520 G2 X311.073 Y179.814 I0.536 J-0.451
N16530 G1 X311.136 Y179.839
N16540 G2 X311.652 Y179.841 I0.26 J-0.65
N16550 G1 X313.419 Y179.149
N16560 G3 X315.539 Y178.582 I3.916 J10.399
N16570 G1 X316.255 Y178.489
N16580 G1 X316.235 Y178.591
N16590 G1 X316.23 Y178.622
N16600 G1 X316.227 Y178.65
N16610 G1 X316.221 Y178.727
N16620 G2 X316.809 Y179.606 I0.925 J0.018
N16630 G2 X317.261 Y179.655 I0.314 J-0.784
N16640 G1 X317.412 Y179.613
N16650 G1 X317.692 Y179.498
N16660 G1 X317.837 Y179.418
N16670 G1 X318.11 Y179.22
N16680 G1 X318.278 Y179.124
N16690 G3 X319.374 Y178.655 I3.303 J6.209
N16700 G1 X319.678 Y178.579
N16710 G2 X319.607 Y178.871 I0.726 J0.332
N16720 G1 X319.608 Y178.951
N16730 G2 X319.318 Y179.08 I1.13 J2.929
N16740 G2 X319.111 Y179.24 I0.316 J0.624
N16750 G1 X319.069 Y179.288
N16760 G2 X318.896 Y179.675 I0.524 J0.465
N16770 G2 X318.934 Y180.044 I0.876 J0.097
N16780 G2 X318.695 Y180.1 I0.255 J1.636
N16790 G1 X318.528 Y180.178
N16800 G1 X318.498 Y180.197
N16810 G2 X318.241 Y180.488 I0.376 J0.591
N16820 G1 X318.226 Y180.52
N16830 G2 X318.161 Y180.882 I0.632 J0.3
N16840 G1 X318.169 Y180.977
N16850 G2 X317.582 Y181.329 I1.22 J2.706
N16860 G2 X317.413 Y181.45 I0.319 J0.623
N16870 G1 X317.222 Y181.635
N16880 G1 X317.17 Y181.691
N16890 G1 X316.745 Y182.205
N16900 G2 X316.625 Y182.417 I0.539 J0.446
N16910 G1 X316.611 Y182.457
N16920 G2 X316.571 Y182.723 I0.66 J0.234
N16930 G2 X317.009 Y183.451 I0.892 J-0.041
N16940 G1 X317.117 Y183.503
N16950 G2 X316.629 Y185.006 I2.425 J1.618
N16960 G1 X316.629 Y185.029
N16970 G1 X316.629 Y185.081
N16980 G2 X317.16 Y185.892 I0.94 J-0.036
N16990 G1 X317.263 Y185.932
N17000 G1 X317.413 Y185.977
N17010 G1 X317.597 Y186.006
N17020 G2 X317.774 Y186.206 I0.768 J-0.502
N17030 G2 X318.092 Y186.387 I0.576 J-0.643
N17040 G2 X318.25 Y186.984 I1.364 J-0.043
N17050 G2 X317.981 Y187.719 I0.913 J0.752
N17060 G1 X316.592 Y187.066
N17070 G1 X316.498 Y187.03
N17080 G1 X315.658 Y186.774
N17090 G1 X315.602 Y186.76
N17100 G2 X314.812 Y186.705 I-0.582 J2.681
N17110 G2 X313.899 Y187.105 I0.097 J1.461
N17120 G2 X310.098 Y186.612 I-3.312 J10.624
N17130 G1 X310.027 Y186.618
N17140 G1 X309.478 Y186.699
N17150 G1 X309.307 Y186.746
N17160 G1 X309.069 Y186.847
N17170 G1 X308.912 Y186.938
N17180 G1 X308.811 Y187.016
N17190 G1 X308.735 Y187.085
N17200 G2 X308.475 Y187.545 I0.77 J0.739
N17210 G1 X308.461 Y187.608
N17220 G1 X308.446 Y187.691
N17230 G2 X308.446 Y187.929 I0.69 J0.12
N17240 G1 X308.496 Y188.221
N17250 G2 X308.58 Y188.454 I0.69 J-0.118
N17260 G1 X308.857 Y188.931
N17270 G1 X308.913 Y189.012
N17280 G2 X309.195 Y189.352 I6.317 J-4.973
N17290 G1 X308.993 Y189.302
N17300 G1 X308.96 Y189.295
N17310 G2 X307.344 Y189.285 I-0.834 J4.327
N17320 G1 X307.334 Y189.287
N17330 G2 X306.937 Y189.48 I0.165 J0.844
N17340 G1 X306.813 Y189.619
N17350 G1 X306.793 Y189.649
N17360 G2 X306.68 Y189.948 I0.581 J0.391
N17370 G1 X306.67 Y190.024
N17380 G2 X306.674 Y190.234 I0.694 J0.092
N17390 G2 X306.909 Y190.783 I1.265 J-0.216
N17400 G2 X305.714 Y190.897 I0.933 J16.096
N17410 G1 X304.86 Y191.017
N17420 G1 X304.821 Y191.024
N17430 G1 X303.79 Y191.228
N17440 G2 X301.319 Y190.623 I-2.612 J5.312
N17450 G1 X301.27 Y190.623
N17460 G1 X301.117 Y190.63
N17470 G2 X299.21 Y192.01 I0.091 J2.133
N17480 G1 X299.186 Y192.09
N17490 G2 X299.06 Y193.279 I4.26 J1.05
N17500 G2 X297.409 Y193.056 I-1.724 J6.551
N17510 G1 X297.38 Y193.056
N17520 G1 X296.701 Y193.078
N17530 G2 X294.426 Y193.425 I0.432 J10.438
N17540 G2 X293.306 Y193.927 I1.105 J3.97
N17550 G2 X292.727 Y197.244 I1.167 J1.912
N17560 G1 X292.734 Y197.252
N17570 G2 X295.762 Y199.235 I4.746 J-3.945
N17580 G1 X295.775 Y199.239
N17590 G1 X297.437 Y199.686
N17600 G2 X297.459 Y199.931 I1.51 J-0.014
N17610 G1 X297.462 Y199.944
N17620 G1 X297.472 Y199.999
N17630 G1 X297.477 Y200.023
N17640 G2 X298.835 Y202.087 I3.46 J-0.799
N17650 G2 X298.122 Y202.718 I6.71 J8.294
N17660 G1 X297.238 Y203.558
N17670 G1 X297.208 Y203.588
N17680 G1 X296.786 Y204.04
N17690 G1 X296.767 Y204.06
N17700 G2 X296.134 Y205.195 I2.44 J2.106
N17710 G1 X296.11 Y205.298
N17720 G1 X296.083 Y205.473
N17730 G1 X296.077 Y205.647
N17740 G2 X297.07 Y207.11 I1.829 J-0.173
N17750 G2 X297.679 Y207.274 I0.628 J-1.117
N17760 G1 X297.734 Y207.273
N17770 G1 X299.583 Y207.156
N17780 G1 X299.615 Y207.153
N17790 G1 X300.455 Y207.062
N17800 G2 X300.244 Y207.464 I5.381 J3.069
N17810 G2 X300.139 Y209.35 I2.152 J1.066
N17820 G1 X300.098 Y209.394
N17830 G2 X299.973 Y209.579 I0.509 J0.48
N17840 G1 X299.878 Y209.784
N17850 G1 X299.825 Y209.95
N17860 G1 X299.821 Y209.968
N17870 G2 X299.839 Y210.71 I1.532 J0.334
N17880 G1 X299.85 Y210.744
N17890 G2 X300.464 Y211.837 I3.04 J-0.989
N17900 G2 X302.047 Y213.326 I7.578 J-6.472
N17910 G2 X303.426 Y214.32 I23.885 J-31.673
N17920 G1 X302.966 Y214.312
N17930 G1 X302.855 Y214.318
N17940 G1 X302.305 Y214.396
N17950 G1 X302.245 Y214.408
N17960 G2 X301.321 Y214.941 I0.417 J1.789
N17970 G1 X301.283 Y214.984
N17980 G1 X301.254 Y215.022
N17990 G1 X301.21 Y215.084
N18000 G2 X301.154 Y215.885 I0.718 J0.452
N18010 G1 X301.171 Y215.919
N18020 G1 X301.259 Y216.089
N18030 G1 X301.306 Y216.168
N18040 G1 X301.32 Y216.188
N18050 G1 X301.356 Y216.234
N18060 G2 X302.399 Y216.991 I2.008 J-1.671
N18070 G2 X302.661 Y217.087 I2.857 J-7.336
N18080 G2 X301.411 Y217.95 I3.07 J5.783
N18090 G1 X301.385 Y217.974
N18100 G1 X301.334 Y218.024
N18110 G2 X300.085 Y219.63 I5.515 J5.58
N18120 G2 X299.586 Y220.897 I3.54 J2.123
N18130 G2 X299.867 Y222.385 I1.853 J0.42
N18140 G1 X299.989 Y222.521
N18150 G1 X300.145 Y222.656
N18160 G2 X300.471 Y222.814 I0.457 J-0.53
N18170 G1 X300.556 Y222.83
N18180 G2 X300.972 Y222.782 I0.132 J-0.688
N18190 G1 X301.086 Y222.732
N18200 G1 X301.106 Y222.723
N18210 G3 X305.938 Y220.859 I14.012 J29.142
N18220 G2 X306.722 Y220.937 I2.259 J-18.76
N18230 G2 X306.134 Y223.775 I1.84 J1.861
N18240 G1 X306.141 Y223.792
N18250 G2 X307.036 Y224.868 I2.291 J-0.994
N18260 G1 X307.054 Y224.881
N18270 G2 X309.281 Y225.777 I3.592 J-5.712
N18280 G2 X309.83 Y227.987 I4.429 J0.073
N18290 G1 X309.53 Y227.889
N18300 G1 X309.507 Y227.882
N18310 G1 X306.982 Y227.147
N18320 G1 X306.954 Y227.14
N18330 G2 X303.971 Y226.783 I-2.938 J11.915
N18340 G1 X303.942 Y226.784
N18350 G1 X303.345 Y226.81
N18360 G1 X303.211 Y226.83
N18370 G1 X302.928 Y226.898
N18380 G1 X302.79 Y226.948
N18390 G2 X302.253 Y228.209 I0.451 J0.937
N18400 G2 X302.649 Y228.925 I2.039 J-0.659
N18410 G2 X303.75 Y230.031 I6.024 J-4.899
N18420 G1 X303.926 Y230.171
N18430 G1 X303.979 Y230.21
N18440 G1 X304.139 Y230.315
N18450 G1 X304.154 Y230.324
N18460 G2 X306.507 Y231.576 I10.592 J-17.076
N18470 G2 X305.391 Y232.514 I2.775 J4.434
N18480 G2 X304.772 Y233.802 I1.992 J1.749
N18490 G2 X306.266 Y235.555 I1.457 J0.271
N18500 G1 X306.298 Y235.558
N18510 G1 X306.338 Y235.56
N18520 G2 X307.626 Y235.386 I0.107 J-4.066
N18530 G1 X308.72 Y235.068
N18540 G1 X309.1 Y234.977
N18550 G1 X309.258 Y234.951
N18560 G3 X309.945 Y234.872 I2.26 J16.702
N18570 G3 X289.25 Y261.975 I-130.114 J-77.901
N18580 G1 X288.906 Y261.743
N18590 G1 X288.844 Y261.706
N18600 G2 X282.565 Y259.638 I-9.113 J17.111
N18610 G1 X282.546 Y259.636
N18620 G1 X280.792 Y259.424
N18630 G1 X280.732 Y259.419
N18640 G1 X280.159 Y259.4
N18650 G1 X280.112 Y259.4
N18660 G1 X278.977 Y259.437
N18670 G1 X278.958 Y259.438
N18680 G1 X278.003 Y259.495
N18690 G1 X277.992 Y259.496
N18700 G2 X275.268 Y259.792 I3.032 J40.64
N18710 G1 X271.649 Y260.296
N18720 G1 X270.605 Y260.409
N18730 G1 X270.117 Y260.431
N18740 G1 X268.683 Y260.412
N18750 G1 X266.857 Y260.33
N18760 G1 X263.776 Y260.156
N18770 G1 X263.756 Y260.155
N18780 G2 X262.371 Y260.378 I-0.107 J3.756
N18790 G1 X262.351 Y260.385
N18800 G1 X262.287 Y260.41
N18810 G1 X262.264 Y260.42
N18820 G2 X259.742 Y263.81 I1.711 J3.906
N18830 G1 X259.738 Y263.855
N18840 G2 X260.031 Y264.876 I1.606 J0.093
N18850 G1 X260.051 Y264.903
N18860 G1 X260.075 Y264.934
N18870 G1 X260.11 Y264.976
N18880 G2 X260.901 Y265.425 I1.087 J-0.993
N18890 G1 X260.928 Y265.43
N18900 G1 X261.348 Y265.499
N18910 G1 X261.401 Y265.506
N18920 G1 X263.02 Y265.648
N18930 G1 X264.576 Y265.86
N18940 G1 X265.163 Y265.968
N18950 G1 X265.223 Y265.977
N18960 G1 X266.596 Y266.109
N18970 G1 X266.625 Y266.111
N18980 G2 X269.34 Y266.153 I1.904 J-35.359
N18990 G1 X270.104 Y266.139
N19000 G1 X270.616 Y266.15
N19010 G3 X270.075 Y266.783 I-3.865 J-2.758
N19020 G1 X270.046 Y266.812
N19030 G3 X269.201 Y267.349 I-1.93 J-2.1
N19040 G3 X266.906 Y267.966 I-3.86 J-9.787
N19050 G1 X266.284 Y268.058
N19060 G3 X263.861 Y268.228 I-2.463 J-17.797
N19070 G1 X263.814 Y268.228
N19080 G3 X258.131 Y268.069 I0.462 J-118.564
N19090 G1 X256.988 Y268.024
N19100 G2 X254.599 Y268.114 I-0.493 J18.596
N19110 G1 X254.589 Y268.116
N19120 G1 X253.954 Y268.191
N19130 G3 X249.745 Y268.399 I-3.735 J-32.818
N19140 G1 X249.514 Y268.397
N19150 G2 X245.248 Y268.528 I-0.003 J69.264
N19160 G1 X243.143 Y268.633
N19170 G1 X242.541 Y268.657
N19180 G2 X241.174 Y268.846 I0.241 J6.77
N19190 G2 X240.166 Y269.194 I1.413 J5.725
N19200 G1 X239.549 Y269.476
N19210 G1 X239.523 Y269.486
N19220 G3 X238.639 Y269.629 I-0.763 J-1.921
N19230 G1 X238.267 Y269.6
N19240 G2 X236.677 Y269.699 I-0.47 J5.291
N19250 G1 X236.645 Y269.706
N19260 G2 X235.107 Y270.23 I1.449 J6.774
N19270 G2 X234.295 Y270.784 I1.419 J2.95
N19280 G2 X233.771 Y271.769 I1.111 J1.223
N19290 G1 X233.764 Y271.851
N19300 G2 X234.184 Y273.094 I1.894 J0.052
N19310 G1 X234.194 Y273.106
N19320 G1 X234.654 Y273.65
N19330 G1 X234.684 Y273.683
N19340 G1 X234.851 Y273.857
N19350 G1 X234.864 Y273.871
N19360 G2 X236.506 Y275.036 I4.381 J-4.432
N19370 G1 X236.531 Y275.048
N19380 G1 X236.612 Y275.083
N19390 G1 X236.649 Y275.098
N19400 G2 X238.469 Y275.518 I2.492 J-6.651
N19410 G2 X242.179 Y275.563 I2.14 J-23.367
N19420 G1 X243.889 Y275.45
N19430 G1 X243.903 Y275.449
N19440 G1 X246.816 Y275.196
N19450 G1 X247.094 Y275.174
N19460 G3 X252.412 Y275.416 I1.679 J21.654
N19470 G3 X254.112 Y275.965 I-1.21 J6.652
N19480 G1 X254.158 Y275.988
N19490 G3 X254.722 Y276.348 I-1.396 J2.814
N19500 G1 X254.734 Y276.356
N19510 G3 X255.129 Y276.894 I-0.727 J0.95
N19520 G1 X255.138 Y276.929
N19530 G3 X254.873 Y277.848 I-1.048 J0.195
N19540 G3 X253.674 Y278.257 I-1.093 J-1.244
N19550 G1 X253.657 Y278.256
N19560 G1 X252.512 Y278.21
N19570 G1 X251.629 Y278.151
N19580 G1 X251.615 Y278.15
N19590 G2 X249.573 Y278.301 I-0.401 J8.489
N19600 G1 X249.55 Y278.306
N19610 G1 X249.066 Y278.418
N19620 G3 X245.702 Y278.765 I-3.186 J-14.386
N19630 G1 X245.583 Y278.765
N19640 G3 X240.648 Y278.287 I0.443 J-30.306
N19650 G1 X240.635 Y278.285
N19660 G1 X239.482 Y278.1
N19670 G1 X239.458 Y278.097
N19680 G2 X236.082 Y278.365 I-1.04 J8.283
N19690 G1 X234.906 Y278.72
N19700 G1 X234.129 Y278.865
N19710 G3 X233.097 Y278.687 I-0.215 J-1.832
N19720 G1 X233.083 Y278.679
N19730 G3 X232.746 Y278.352 I0.444 J-0.794
N19740 G1 X232.611 Y278.124
N19750 G2 X231.857 Y277.226 I-2.756 J1.548
N19760 G1 X231.814 Y277.192
N19770 G1 X231.793 Y277.175
N19780 G2 X230.446 Y276.614 I-1.826 J2.484
N19790 G1 X230.404 Y276.608
N19800 G1 X229.203 Y276.493
N19810 G1 X229.151 Y276.49
N19820 G2 X226.595 Y276.54 I-0.666 J31.103
N19830 G1 X226.575 Y276.542
N19840 G1 X224.059 Y276.765
N19850 G1 X224.026 Y276.769
N19860 G1 X223.804 Y276.8
N19870 G3 X222.457 Y276.882 I-1.257 J-9.528
N19880 G1 X220.686 Y276.785
N19890 G1 X220.011 Y276.719
N19900 G2 X218.124 Y276.795 I-0.647 J7.324
N19910 G1 X218.099 Y276.8
N19920 G1 X216.932 Y277.043
N19930 G1 X216.908 Y277.048
N19940 G1 X215.384 Y277.421
N19950 G1 X215.371 Y277.424
N19960 G1 X213.846 Y277.829
N19970 G1 X213.825 Y277.832
N19980 G3 X212.784 Y277.854 I-0.6 J-3.831
N19990 G1 X212.414 Y277.806
N20000 G2 X210.836 Y277.741 I-1.131 J8.328
N20010 G1 X210.808 Y277.743
N20020 G1 X209.936 Y277.824
N20030 G1 X209.983 Y277.74
N20040 G3 X210.415 Y277.341 I1.246 J0.914
N20050 G1 X210.76 Y277.143
N20060 G1 X210.801 Y277.118
N20070 G2 X211.805 Y274.031 I-1.449 J-2.178
N20080 G1 X211.757 Y273.873
N20090 G1 X211.752 Y273.857
N20100 G2 X208.57 Y271.649 I-3.061 J1.013
N20110 G1 X207.609 Y271.65
N20120 G1 X207.587 Y271.651
N20130 G1 X204.316 Y271.759
N20140 G1 X204.306 Y271.759
N20150 G1 X203.394 Y271.803
N20160 G1 X203.356 Y271.806
N20170 G1 X203.069 Y271.836
N20180 G1 X203.029 Y271.841
N20190 G2 X197.823 Y272.839 I14.754 J91.06
N20200 G1 X196.53 Y273.123
N20210 G3 X185.688 Y274.138 I-9.435 J-42.362
N20220 G1 X183.979 Y274.101
N20230 G1 X181.66 Y274.018
N20240 G2 X177.802 Y274.311 I-0.499 J18.969
N20250 G1 X177.775 Y274.317
N20260 G1 X176.042 Y274.7
N20270 G3 X172.53 Y275.008 I-2.836 J-12.162
N20280 G1 X172.514 Y275.007
N20290 G1 X171.864 Y274.987
N20300 G2 X169.352 Y275.173 I-0.417 J11.381
N20310 G1 X169.297 Y275.184
N20320 G2 X167.499 Y275.698 I2.489 J12.118
N20330 G1 X166.892 Y275.914
N20340 G3 X164.25 Y276.32 I-2.586 J-8.021
N20350 G3 X162.117 Y276.182 I0.477 J-23.889
N20360 G1 X159.852 Y275.943
N20370 G1 X159.824 Y275.94
N20380 G1 X159.205 Y275.9
N20390 G1 X159.178 Y275.899
N20400 G1 X157.573 Y275.858
N20410 G1 X157.558 Y275.858
N20420 G1 X154.264 Y275.844
N20430 G2 X159.756 Y255.894 I-34.364 J-20.191
N20440 G1 X159.757 Y255.612
N20450 G2 X159.377 Y250.204 I-39.878 J0.086
N20460 G2 X161.784 Y250.619 I10.177 J-51.875
N20470 G1 X163.728 Y250.896
N20480 G2 X167.326 Y251.226 I5.733 J-42.83
N20490 G1 X167.839 Y251.249
N20500 G3 X171.889 Y251.722 I-1.679 J31.963
N20510 G1 X174.007 Y252.098
N20520 G1 X174.05 Y252.104
N20530 G1 X175.681 Y252.289
N20540 G1 X175.709 Y252.292
N20550 G2 X179.019 Y251.684 I0.483 J-6.687
N20560 G1 X179.08 Y251.652
N20570 G1 X179.615 Y251.337
N20580 G1 X179.647 Y251.317
N20590 G2 X180.659 Y250.032 I-1.453 J-2.186
N20600 G1 X180.676 Y249.978
N20610 G1 X180.702 Y249.884
N20620 G1 X180.727 Y249.725
N20630 G2 X178.866 Y246.271 I-3.854 J-0.151
N20640 G1 X178.815 Y246.24
N20650 G2 X178.025 Y245.91 I-1.551 J2.603
N20660 G1 X176.901 Y245.587
N20670 G3 X175.924 Y245.079 I1.509 J-4.093
N20680 G1 X175.912 Y245.071
N20690 G1 X175.648 Y244.895
N20700 G2 X174.684 Y244.452 I-2.008 J3.092
N20710 G1 X174.662 Y244.446
N20720 G2 X172.822 Y244.263 I-1.503 J5.762
N20730 G1 X172.334 Y244.264
N20740 G1 X172.148 Y244.208
N20750 G1 X172.075 Y244.199
N20760 G1 X171.247 Y244.132
N20770 G1 X171.206 Y244.13
N20780 G1 X169.861 Y244.1
N20790 G1 X169.848 Y244.1
N20800 G1 X162.3 Y244.079
N20810 G1 X159.285 Y244.094
N20820 G1 X159.271 Y244.094
N20830 G1 X158.03 Y244.126
N20840 G2 X136.449 Y219.091 I-39.561 J12.283
N20850 G1 X136.46 Y219.066
N20860 G1 X137.399 Y216.807
N20870 G1 X137.566 Y216.421
N20880 G1 X137.581 Y216.382
N20890 G1 X138.621 Y213.522
N20900 G1 X138.627 Y213.505
N20910 G1 X139.474 Y210.969
N20920 G1 X140.053 Y209.287
N20930 G3 X141.539 Y205.647 I35.314 J12.293
N20940 G1 X141.694 Y205.33
N20950 G3 X142.945 Y203.054 I27.179 J13.45
N20960 G3 X145.386 Y200.028 I11.607 J6.869
N20970 G1 X145.444 Y199.975
N20980 G3 X146.286 Y199.635 I1.012 J1.291
N20990 G1 X146.34 Y199.627
N21000 G1 X147.853 Y199.347
N21010 G1 X148.211 Y199.301
N21020 G3 X148.944 Y199.359 I0.217 J1.918
N21030 G1 X148.989 Y199.37
N21040 G1 X149.792 Y199.536
N21050 G3 X151.75 Y200.147 I-2.263 J10.704
N21060 G1 X151.77 Y200.154
N21070 G3 X153.835 Y201.843 I-1.524 J3.972
N21080 G1 X154.641 Y203.876
N21090 G1 X155.802 Y207.051
N21100 G1 X156.409 Y208.645
N21110 G2 X158.015 Y212.238 I34.341 J-13.196
N21120 G1 X158.021 Y212.25
N21130 G1 X158.041 Y212.286
N21140 G2 X158.572 Y212.649 I0.616 J-0.332
N21150 G1 X158.898 Y212.689
N21160 G2 X159.682 Y212.016 I0.085 J-0.695
N21170 G1 X159.685 Y211.931
N21180 G1 X159.684 Y211.874
N21190 G2 X159.413 Y209.461 I-19.42 J0.964
N21200 G1 X158.934 Y206.863
N21210 G1 X158.315 Y203.661
N21220 G1 X158.311 Y203.641
N21230 G1 X158.035 Y202.409
N21240 G2 X156.755 Y198.709 I-17.877 J4.113
N21250 G1 X156.742 Y198.683
N21260 G1 X156.089 Y197.434
N21270 G3 X156.018 Y197.01 I0.719 J-0.339
N21280 G1 X156.027 Y196.936
N21290 G3 X157.779 Y194.836 I2.953 J0.682
N21300 G1 X158.285 Y194.794
N21310 G1 X159.199 Y194.822
N21320 G2 X161.15 Y194.701 I0.512 J-7.493
N21330 G1 X161.173 Y194.696
N21340 G1 X162.838 Y194.314
N21350 G1 X162.859 Y194.309
N21360 G1 X173.325 Y191.572
N21370 G1 X178.436 Y190.253
N21380 G1 X178.479 Y190.241
N21390 G1 X178.867 Y190.113
N21400 G2 X180.167 Y189.248 I-0.932 J-2.809
N21410 G1 X180.202 Y189.204
N21420 G1 X180.238 Y189.156
N21430 G1 X180.261 Y189.122
N21440 G2 X179.989 Y184.912 I-2.951 J-1.923
N21450 G1 X179.974 Y184.895
N21460 G1 X179.898 Y184.812
N21470 G3 X179.798 Y184.564 I0.33 J-0.278
N21480 G1 X179.736 Y183.744
N21490 G1 X179.732 Y183.699
N21500 G2 X179.435 Y182.918 I-1.86 J0.259
N21510 G1 X179.393 Y182.861
N21520 G1 X179.364 Y182.825
N21530 G2 X179.158 Y182.656 I-0.541 J0.445
N21540 G2 X176.38 Y181.495 I-6.943 J12.721
N21550 G1 X169.055 Y179.179
N21560 G1 X167.223 Y178.585
N21570 G1 X166.017 Y178.165
N21580 G1 X165.635 Y178.024
N21590 G3 X164.629 Y177.015 I5.774 J-6.762
N21600 G1 X164.622 Y177.007
N21610 G1 X164.089 Y176.397
N21620 G3 X157.847 Y163.907 I23.884 J-19.74
N21630 G1 X157.842 Y163.889
N21640 G1 X157.809 Y163.764
N21650 G3 X156.954 Y160.182 I56.408 J-15.35
N21660 G1 X155.944 Y155.31
N21670 G2 X154.884 Y151.161 I-50.415 J10.671
N21680 G1 X154.813 Y150.931
N21690 G2 X153.765 Y148.297 I-18.247 J5.735
N21700 G1 X153.742 Y148.254
N21710 G1 X153.598 Y148.004
N21720 G1 X153.588 Y147.986
N21730 G2 X143.698 Y136.273 I-43.552 J26.738
N21740 G1 X142.319 Y135.096
N21750 G2 X139.797 Y133.157 I-23.812 J28.349
N21760 G1 X138.144 Y131.173
N21770 G1 X137.429 Y130.274
N21780 G1 X137.344 Y130.184
N21790 G1 X138.162 Y129.473
N21800 G1 X138.175 Y129.462
N21810 G1 X139.889 Y127.897
N21820 G1 X139.904 Y127.883
N21830 G1 X140.724 Y127.091
N21840 G1 X140.737 Y127.077
N21850 G1 X142.286 Y125.496
N21860 G1 X142.297 Y125.484
N21870 G1 X143.212 Y124.507
N21880 G1 X143.227 Y124.491
N21890 G1 X143.892 Y123.734
N21900 G2 X146.323 Y120.157 I-13.87 J-12.042
N21910 G1 X146.328 Y120.148
N21920 G1 X146.381 Y120.042
N21930 G1 X146.413 Y119.969
N21940 G2 X146.243 Y116.203 I-4.594 J-1.68
N21950 G1 X144.68 Y112.297
N21960 G1 X144.2 Y111.067
N21970 G3 X143.191 Y107.993 I29.577 J-11.412
N21980 G1 X143.097 Y107.639
N21990 G2 X140.448 Y99.294 I-122.328 J34.242
N22000 G1 X140.106 Y98.307
N22010 G2 X138.302 Y96.171 I-3.738 J1.325
N22020 G1 X137.624 Y95.711
N22030 G1 X137.308 Y95.48
N22040 G1 X137.006 Y95.226
N22050 G3 X136.446 Y94.397 I1.263 J-1.458
N22060 G1 X136.35 Y92.982
N22070 G1 X136.348 Y92.957
N22080 G2 X135.724 Y90.772 I-6.477 J0.668
N22090 G1 X135.703 Y90.731
N22100 G1 X135.627 Y90.599
N22110 G1 X135.614 Y90.578
N22120 G2 X132.537 Y87.496 I-8.14 J5.049
N22130 G1 X132.429 Y87.429
N22140 G2 X131.392 Y87.825 I-0.366 J0.597
N22150 G1 X131.381 Y87.862
N22160 G1 X131.356 Y87.982
N22170 G2 X131.223 Y92.811 I27.402 J3.172
N22180 G1 X131.179 Y92.893
N22190 G2 X131.096 Y93.246 I0.617 J0.331
N22200 G1 X131.097 Y93.269
N22210 G2 X131.154 Y93.525 I0.7 J-0.021
N22220 G1 X131.163 Y93.546
N22230 G2 X131.308 Y93.76 I0.643 J-0.278
N22240 G1 X131.325 Y93.778
N22250 G1 X131.372 Y93.821
N22260 G3 X131.337 Y94.378 I-2.036 J0.153
N22270 G1 X131.335 Y94.39
N22280 G1 X131.197 Y95.14
N22290 G1 X131.192 Y95.172
N22300 G1 X131.141 Y95.548
N22310 G1 X131.139 Y95.563
N22320 G2 X131.243 Y96.787 I3.081 J0.354
N22330 G1 X131.251 Y96.811
N22340 G1 X131.264 Y96.851
N22350 G2 X131.523 Y97.201 I0.664 J-0.221
N22360 G1 X132.768 Y98.084
N22370 G1 X132.786 Y98.096
N22380 G1 X133.445 Y98.533
N22390 G1 X133.487 Y98.922
N22400 G2 X134.049 Y99.534 I0.696 J-0.075
N22410 G1 X134.845 Y99.69
N22420 G3 X135.131 Y99.935 I-0.197 J0.519
N22430 G1 X135.174 Y100.001
N22440 G1 X135.192 Y100.027
N22450 G3 X136.962 Y103.728 I-9.464 J6.799
N22460 G1 X136.971 Y103.758
N22470 G1 X138.333 Y107.96
N22480 G1 X138.772 Y109.381
N22490 G3 X139.636 Y112.92 I-31.197 J9.493
N22500 G1 X139.752 Y113.622
N22510 G3 X139.761 Y116.449 I-8.843 J1.443
N22520 G1 X139.653 Y116.588
N22530 G1 X139.642 Y116.607
N22540 G3 X139.4 Y116.846 I-0.699 J-0.467
N22550 G1 X138.881 Y117.191
N22560 G3 X136.538 Y118.587 I-17.959 J-27.486
N22570 G1 X131.572 Y121.305
N22580 G1 X131.56 Y121.312
N22590 G1 X130.065 Y122.169
N22600 G1 X129.439 Y122.498
N22610 G1 X129.403 Y122.518
N22620 G1 X128.851 Y122.849
N22630 G3 X128.172 Y116.338 I34.233 J-6.861
N22640 G1 X128.17 Y112.842
N22650 G1 X128.17 Y112.817
N22660 G1 X128.127 Y111.654
N22670 G1 X128.127 Y111.644
N22680 G2 X127.572 Y108.341 I-14.551 J0.744
N22690 G1 X127.504 Y108.112
N22700 G3 X125.439 Y91.898 I55.761 J-15.341
N22710 G1 X125.439 Y91.478
N22720 G3 X126.084 Y89.091 I5.674 J0.252
N22730 G1 X126.137 Y88.995
N22740 G3 X127.871 Y86.957 I5.898 J3.262
N22750 G1 X127.888 Y86.943
N22760 G1 X128.751 Y86.222
N22770 G3 X137.004 Y86.58 I0.904 J74.313
N22780 G1 X138.088 Y86.715
N22790 G1 X139.534 Y86.924
N22800 G1 X144.615 Y87.758
N22810 G1 X144.625 Y87.76
N22820 G1 X146.537 Y88.044
N22830 G1 X146.548 Y88.046
N22840 G1 X146.695 Y88.065
N22850 G1 X146.706 Y88.066
N22860 G2 X162.826 Y88.736 I12.602 J-108.988
N22870 G1 X169.935 Y88.599
N22880 G1 X173.928 Y88.484
N22890 G1 X183.906 Y88.116
N22900 G1 X195.88 Y87.604
N22910 G1 X203.856 Y87.282
N22920 G1 X211.827 Y87.018
N22930 G1 X215.412 Y86.931
N22940 G1 X217.151 Y88.977
N22950 G1 X217.176 Y89.005
N22960 G2 X219.677 Y90.808 I5.996 J-5.678
N22970 G1 X219.762 Y90.848
N22980 G3 X222.03 Y92.712 I-3.179 J6.181
N22990 G3 X224.484 Y99.992 I-12.023 J8.107
N23000 G1 X224.486 Y100.01
N23010 G1 X224.575 Y101.083
N23020 G1 X224.657 Y102.511
N23030 G1 X224.748 Y104.872
N23040 G1 X224.812 Y111.062
N23050 G1 X224.864 Y113.724
N23060 G1 X224.865 Y113.739
N23070 G1 X224.935 Y115.433
N23080 G3 X224.783 Y119.741 I-45.487 J0.549
N23090 G1 X224.656 Y121.515
N23100 G2 X224.57 Y121.802 I0.612 J0.341
N23110 G1 X224.556 Y121.98
N23120 G3 X223.968 Y126.851 I-76.418 J-6.759
N23130 G1 X223.622 Y129.314
N23140 G1 X223.621 Y129.325
N23150 G1 X223.608 Y129.43
N23160 G3 X222.956 Y132.24 I-14.947 J-1.986
N23170 G2 X221.603 Y130.94 I-6.269 J5.174
N23180 G1 X221.545 Y130.901
N23190 G2 X218.233 Y130.935 I-1.628 J2.663
N23200 G1 X215.432 Y132.328
N23210 G1 X214.08 Y132.894
N23220 G3 X212.948 Y133.232 I-2.584 J-6.578
N23230 G1 X212.921 Y133.239
N23240 G1 X212.83 Y133.262
N23250 G3 X211.749 Y133.403 I-1.248 J-5.327
N23260 G1 X210.648 Y133.431
N23270 G1 X210.601 Y133.434
N23280 G1 X209.435 Y133.541
N23290 G1 X209.416 Y133.543
N23300 G1 X209.33 Y133.553
N23310 G2 X203.333 Y134.581 I3.758 J39.935
N23320 G1 X203.307 Y134.588
N23330 G1 X202.279 Y134.888
N23340 G1 X202.02 Y134.938
N23350 G3 X201.737 Y134.862 I-0.051 J-0.376
N23360 G3 X201.138 Y134.18 I1.448 J-1.875
N23370 G3 X200.541 Y132.854 I6.888 J-3.899
N23380 G1 X200.537 Y132.844
N23390 G1 X200.461 Y132.631
N23400 G3 X199.546 Y128.198 I21.435 J-6.733
N23410 G1 X199.527 Y127.938
N23420 G3 X199.469 Y124.846 I39.477 J-2.285
N23430 G1 X199.556 Y121.407
N23440 G1 X199.568 Y120.702
N23450 G2 X198.485 Y120.104 I-0.7 J-0.011
N23460 G1 X198.477 Y119.532
N23470 G2 X197.458 Y118.919 I-0.7 J0.01
N23480 G2 X197.172 Y118.571 I-0.655 J0.247
N23490 G3 X197.832 Y117.863 I4.548 J3.577
N23500 G1 X197.85 Y117.846
N23510 G1 X198.643 Y117.074
N23520 G1 X198.668 Y117.049
N23530 G1 X198.92 Y116.777
N23540 G2 X199.902 Y115.126 I-3.472 J-3.183
N23550 G1 X199.915 Y115.084
N23560 G1 X200.549 Y112.775
N23570 G1 X200.554 Y112.757
N23580 G2 X200.893 Y109.199 I-11.913 J-2.929
N23590 G2 X200.021 Y108.556 I-0.699 J0.036
N23600 G1 X199.58 Y108.668
N23610 G1 X199.461 Y108.71
N23620 G1 X198.443 Y109.177
N23630 G1 X196.844 Y109.869
N23640 G1 X196.79 Y109.896
N23650 G1 X196.043 Y110.299
N23660 G1 X196.022 Y110.312
N23670 G2 X195.08 Y111.077 I2.041 J3.474
N23680 G1 X195.042 Y111.123
N23690 G1 X194.985 Y111.197
N23700 G1 X194.961 Y111.231
N23710 G2 X194.409 Y112.267 I4.776 J3.209
N23720 G1 X193.903 Y113.527
N23730 G1 X193.722 Y113.898
N23740 G1 X193.615 Y114.087
N23750 G3 X192.005 Y116.599 I-24.8 J-14.125
N23760 G1 X191.047 Y117.883
N23770 G1 X190.742 Y118.262
N23780 G1 X190.715 Y118.297
N23790 G1 X190.071 Y119.212
N23800 G1 X190.04 Y119.26
N23810 G1 X190.009 Y119.314
N23820 G2 X189.914 Y119.619 I0.604 J0.355
N23830 G1 X189.908 Y119.703
N23840 G1 X189.906 Y119.743
N23850 G2 X190.276 Y122.352 I8.599 J0.113
N23860 G1 X190.283 Y122.375
N23870 G1 X190.9 Y124.185
N23880 G1 X190.923 Y124.243
N23890 G1 X191.639 Y125.863
N23900 G1 X191.656 Y125.899
N23910 G1 X192.978 Y128.482
N23920 G1 X193.495 Y129.587
N23930 G1 X194.631 Y132.278
N23940 G1 X196.301 Y136.566
N23950 G1 X197.255 Y139.095
N23960 G2 X197.702 Y139.966 I4.515 J-1.765
N23970 G1 X197.732 Y140.01
N23980 G1 X197.785 Y140.079
N23990 G1 X197.826 Y140.128
N24000 G2 X200.502 Y141.545 I3.324 J-3.042
N24010 G1 X200.627 Y141.568
N24020 G1 X200.665 Y141.574
N24030 G2 X205.776 Y141.297 I1.79 J-14.313
N24040 G1 X205.838 Y141.286
N24050 G3 X212.7 Y141.043 I4.771 J37.731
N24060 G1 X214.235 Y141.222
N24070 G1 X214.736 Y141.315
N24080 G3 X215.615 Y141.63 I-0.668 J3.253
N24090 G3 X215.737 Y142.775 I-3.088 J0.907
N24100 G1 X215.685 Y143.556
N24110 G3 X215.356 Y144.627 I-2.764 J-0.262
N24120 G1 X215.339 Y144.661
N24130 G1 X215.032 Y145.303
N24140 G1 X215.011 Y145.351
N24150 G1 X214.583 Y146.449
N24160 G2 X213.712 Y149.006 I30.382 J11.778
N24170 G2 X213.019 Y154.106 I15.331 J4.679
N24180 G1 X213.02 Y154.132
N24190 G1 X213.039 Y154.434
N24200 G1 X213.042 Y154.461
N24210 G2 X213.6 Y157.008 I11.292 J-1.142
N24220 G1 X213.888 Y157.928
N24230 G1 X214.139 Y158.855
N24240 G3 X214.29 Y160.585 I-5.517 J1.354
N24250 G3 X213.109 Y168.088 I-50.036 J-4.03
N24260 G1 X213.107 Y168.098
N24270 G1 X212.579 Y170.497
N24280 G1 X211.993 Y172.955
N24290 G1 X211.127 Y176.448
N24300 G1 X210.444 Y179.055
N24310 G1 X209.667 Y181.854
N24320 G1 X209.272 Y183.018
N24330 G3 X208.706 Y184.389 I-12.734 J-4.449
N24340 G1 X208.702 Y184.399
N24350 G3 X207.161 Y186.425 I-5.306 J-2.435
N24360 G3 X205.272 Y186.302 I-0.421 J-8.096
N24370 G1 X205.247 Y186.298
N24380 G1 X204.188 Y186.143
N24390 G2 X202.781 Y186.076 I-1.06 J7.423
N24400 G1 X202.681 Y186.078
N24410 G1 X202.655 Y186.08
N24420 G2 X199.266 Y186.693 I0.94 J14.872
N24430 G1 X199.255 Y186.696
N24440 G1 X198.554 Y186.922
N24450 G1 X198.449 Y186.965
N24460 G1 X197.205 Y187.603
N24470 G1 X197.191 Y187.61
N24480 G1 X196.389 Y188.044
N24490 G1 X196.235 Y188.115
N24500 G1 X196.158 Y188.139
N24510 G3 X191.833 Y188.865 I-5.646 J-20.389
N24520 G1 X191.821 Y188.866
N24530 G1 X190.062 Y189.009
N24540 G1 X188.776 Y189.131
N24550 G1 X188.727 Y189.137
N24560 G1 X188.119 Y189.238
N24570 G2 X186.462 Y189.742 I1.251 J7.085
N24580 G2 X184.619 Y191.569 I1.339 J3.195
N24590 G1 X183.746 Y192.088
N24600 G2 X183.53 Y192.29 I0.358 J0.601
N24610 G1 X183.503 Y192.328
N24620 G1 X183.45 Y192.419
N24630 G2 X183.395 Y195.246 I2.994 J1.472
N24640 G1 X183.439 Y195.371
N24650 G1 X183.456 Y195.416
N24660 G2 X184.358 Y196.513 I2.342 J-1.006
N24670 G1 X184.627 Y196.704
N24680 G1 X184.736 Y196.767
N24690 G2 X188.214 Y198.086 I10.44 J-22.291
N24700 G1 X191.195 Y199.016
N24710 G1 X194.272 Y200.093
N24720 G1 X195.445 Y200.549
N24730 G1 X196.543 Y201.076
N24740 G1 X196.958 Y201.322
N24750 G1 X198.179 Y202.199
N24760 G1 X198.199 Y202.212
N24770 G1 X198.706 Y202.551
N24780 G1 X198.722 Y202.561
N24790 G2 X200.205 Y203.174 I2.533 J-4.025
N24800 G1 X200.318 Y203.19
N24810 G1 X201.583 Y203.267
N24820 G1 X201.629 Y203.268
N24830 G1 X202.591 Y203.263
N24840 G3 X201.288 Y204.621 I-2.144 J-0.752
N24850 G1 X201.206 Y204.654
N24860 G3 X197.579 Y205.52 I-5.406 J-14.622
N24870 G1 X197.562 Y205.522
N24880 G1 X192.563 Y206.22
N24890 G1 X192.531 Y206.225
N24900 G1 X191.042 Y206.504
N24910 G1 X191.022 Y206.508
N24920 G2 X188.31 Y207.557 I1.997 J9.191
N24930 G1 X188.29 Y207.569
N24940 G1 X188.248 Y207.595
N24950 G2 X185.442 Y210.977 I3.824 J6.028
N24960 G1 X185.397 Y211.093
N24970 G2 X184.973 Y214.099 I6.246 J2.414
N24980 G1 X184.979 Y214.158
N24990 G2 X185.03 Y214.362 I0.697 J-0.067
N25000 G1 X185.035 Y214.373
N25010 G2 X185.682 Y215.361 I2.758 J-1.103
N25020 G1 X185.696 Y215.374
N25030 G1 X185.717 Y215.394
N25040 G2 X186.107 Y215.582 I0.483 J-0.506
N25050 G1 X186.128 Y215.585
N25060 G1 X186.226 Y215.591
N25070 G2 X188.845 Y213.057 I-0.015 J-2.636
N25080 G1 X188.845 Y213.026
N25090 G3 X189.578 Y211.218 I2.564 J-0.014
N25100 G1 X189.602 Y211.196
N25110 G3 X190.109 Y210.833 I1.722 J1.874
N25120 G1 X190.121 Y210.827
N25130 G3 X191.584 Y210.343 I2.528 J5.185
N25140 G1 X190.701 Y211.785
N25150 G1 X190.694 Y211.797
N25160 G1 X190.362 Y212.365
N25170 G2 X189.658 Y213.967 I6.774 J3.933
N25180 G1 X189.65 Y213.995
N25190 G2 X189.775 Y215.56 I2.017 J0.627
N25200 G1 X189.78 Y215.57
N25210 G1 X189.827 Y215.661
N25220 G2 X190.138 Y215.967 I0.622 J-0.321
N25230 G1 X190.193 Y215.994
N25240 G1 X190.236 Y216.013
N25250 G2 X192.77 Y215.961 I1.207 J-2.922
N25260 G1 X192.871 Y215.904
N25270 G1 X192.934 Y215.86
N25280 G1 X192.982 Y215.825
N25290 G2 X194.298 Y213.033 I-2.259 J-2.771
N25300 G1 X194.319 Y211.777
N25310 G3 X196.983 Y209.659 I3.037 J1.085
N25320 G3 X196.855 Y209.844 I-2.309 J-1.466
N25330 G1 X196.397 Y210.465
N25340 G1 X196.378 Y210.492
N25350 G1 X196.099 Y210.911
N25360 G1 X196.087 Y210.929
N25370 G2 X195.647 Y212.091 I2.708 J1.692
N25380 G1 X195.645 Y212.103
N25390 G1 X195.642 Y212.12
N25400 G2 X196.262 Y213.876 I1.888 J0.321
N25410 G2 X196.57 Y214.034 I0.463 J-0.525
N25420 G1 X196.6 Y214.041
N25430 G1 X196.686 Y214.055
N25440 G2 X199.678 Y212.088 I0.284 J-2.828
N25450 G1 X200.144 Y210.927
N25460 G1 X200.154 Y210.902
N25470 G1 X200.59 Y209.676
N25480 G3 X201.05 Y208.821 I3.928 J1.561
N25490 G1 X201.077 Y208.785
N25500 G1 X201.09 Y208.774
N25510 G1 X201.765 Y208.371
N25520 G3 X203.83 Y207.475 I5.448 J9.725
N25530 G3 X205.285 Y207.449 I0.808 J4.51
N25540 G1 X205.712 Y207.612
N25550 G1 X205.747 Y207.63
N25560 G3 X209.763 Y210.87 I-6.174 J11.762
N25570 G1 X210.4 Y211.723
N25580 G1 X210.441 Y211.784
N25590 G3 X211.338 Y215.871 I-4.615 J3.155
N25600 G3 X208.938 Y218.999 I-4.338 J-0.843
N25610 G1 X208.919 Y219.009
N25620 G2 X207.833 Y219.697 I3.733 J7.093
N25630 G2 X206.436 Y222.559 I1.832 J2.665
N25640 G1 X206.461 Y222.706
N25650 G1 X206.473 Y222.75
N25660 G1 X206.489 Y222.8
N25670 G2 X207.169 Y223.945 I3.375 J-1.229
N25680 G2 X208.962 Y224.517 I1.38 J-1.228
N25690 G2 X209.291 Y224.339 I-0.157 J-0.682
N25700 G1 X209.757 Y223.89
N25710 G1 X209.816 Y223.825
N25720 G1 X209.869 Y223.76
N25730 G1 X209.888 Y223.735
N25740 G2 X210.678 Y222.408 I-6.473 J-4.75
N25750 G1 X210.876 Y222.015
N25760 G1 X211.407 Y221.126
N25770 G3 X213.379 Y221.18 I0.961 J0.948
N25780 G3 X213.797 Y222.332 I-2.685 J1.625
N25790 G3 X213.783 Y224.503 I-9.65 J1.025
N25800 G3 X212.818 Y226.209 I-3.078 J-0.616
N25810 G1 X212.784 Y226.242
N25820 G1 X212.428 Y226.614
N25830 G1 X212.406 Y226.638
N25840 G1 X212.372 Y226.677
N25850 G1 X212.336 Y226.721
N25860 G2 X212.791 Y229.986 I1.895 J1.4
N25870 G2 X213.104 Y230.123 I0.428 J-0.554
N25880 G1 X213.175 Y230.134
N25890 G1 X213.19 Y230.137
N25900 G2 X215.227 Y229.818 I0.497 J-3.481
N25910 G1 X215.362 Y229.732
N25920 G1 X215.978 Y229.231
N25930 G1 X216.005 Y229.208
N25940 G2 X217.01 Y227.867 I-2.896 J-3.215
N25950 G1 X217.03 Y227.821
N25960 G1 X217.322 Y227.082
N25970 G1 X217.355 Y226.975
N25980 G2 X217.512 Y224.296 I-8.37 J-1.835
N25990 G1 X217.484 Y224
N26000 G2 X216.823 Y219.833 I-38.463 J3.969
N26010 G1 X216.4 Y217.959
N26020 G1 X216.397 Y217.946
N26030 G1 X215.762 Y215.368
N26040 G1 X215.686 Y214.968
N26050 G1 X215.653 Y214.468
N26060 G3 X215.877 Y213.96 I0.748 J0.027
N26070 G3 X216.497 Y213.869 I0.57 J1.72
N26080 G3 X218.303 Y214.382 I-0.518 J5.255
N26090 G1 X218.334 Y214.397
N26100 G1 X218.561 Y214.494
N26110 G3 X223.609 Y219.566 I-4.213 J9.241
N26120 G1 X223.622 Y219.594
N26130 G3 X224.288 Y227.804 I-9.764 J4.924
N26140 G1 X224.269 Y227.858
N26150 G3 X221.672 Y232.99 I-19.987 J-6.891
N26160 G1 X221.3 Y233.497
N26170 G1 X220.107 Y235.003
N26180 G2 X219.192 Y236.488 I6.637 J5.117
N26190 G1 X219.166 Y236.55
N26200 G1 X219.126 Y236.658
N26210 G1 X219.1 Y236.747
N26220 G2 X219.759 Y239.112 I2.538 J0.567
N26230 G1 X219.806 Y239.157
N26240 G2 X222.03 Y239.629 I1.538 J-1.776
N26250 G1 X222.076 Y239.613
N26260 G1 X222.185 Y239.571
N26270 G1 X222.221 Y239.556
N26280 G2 X223.763 Y238.006 I-1.24 J-2.775
N26290 G1 X224.108 Y237.239
N26300 G1 X224.117 Y237.219
N26310 G1 X225.303 Y234.347
N26320 G1 X226.375 Y231.994
N26330 G1 X226.594 Y231.601
N26340 G3 X226.909 Y231.189 I1.873 J1.104
N26350 G1 X226.942 Y231.209
N26360 G1 X227.063 Y231.344
N26370 G3 X227.525 Y237.487 I-5.225 J3.482
N26380 G1 X227.503 Y237.54
N26390 G1 X226.904 Y239.151
N26400 G1 X226.899 Y239.164
N26410 G2 X226.455 Y240.915 I9.814 J3.423
N26420 G1 X226.446 Y241.019
N26430 G1 X226.44 Y241.548
N26440 G1 X226.444 Y241.626
N26450 G2 X227.514 Y242.914 I1.49 J-0.15
N26460 G2 X230.512 Y241.986 I0.894 J-2.417
N26470 G1 X230.552 Y241.934
N26480 G1 X230.58 Y241.895
N26490 G2 X232.322 Y234.788 I-8.763 J-5.914
N26500 G1 X232.313 Y234.617
N26510 G1 X232.312 Y234.594
N26520 G2 X231.319 Y230.116 I-17.281 J1.481
N26530 G1 X230.525 Y227.843
N26540 G1 X230.149 Y226.705
N26550 G3 X229.609 Y224.555 I16.302 J-5.231
N26560 G1 X229.604 Y224.529
N26570 G1 X229.267 Y223.014
N26580 G1 X229.262 Y222.993
N26590 G1 X228.953 Y221.78
N26600 G1 X228.774 Y220.974
N26610 G3 X228.635 Y220.053 I7.744 J-1.644
N26620 G3 X231.859 Y222.783 I-5.727 J10.033
N26630 G3 X234.354 Y226.454 I-17.784 J14.774
N26640 G1 X234.79 Y227.308
N26650 G3 X238.192 Y239.858 I-34.771 J16.16
N26660 G1 X238.193 Y239.873
N26670 G1 X238.502 Y242.511
N26680 G1 X238.505 Y242.536
N26690 G1 X238.646 Y243.454
N26700 G2 X239.415 Y246.102 I11.13 J-1.793
N26710 G1 X239.428 Y246.131
N26720 G1 X239.463 Y246.203
N26730 G2 X240.266 Y247.419 I4.767 J-2.278
N26740 G2 X241.88 Y248.262 I1.912 J-1.695
N26750 G1 X241.913 Y248.265
N26760 G1 X241.995 Y248.271
N26770 G2 X243.073 Y248.074 I0.187 J-2.028
N26780 G1 X243.122 Y248.048
N26790 G1 X243.67 Y247.726
N26800 G1 X243.818 Y247.609
N26810 G2 X244.497 Y244.71 I-2.088 J-2.018
N26820 G1 X244.462 Y244.621
N26830 G1 X244.309 Y244.3
N26840 G1 X244.289 Y244.261
N26850 G1 X243.614 Y243.043
N26860 G1 X243.331 Y242.431
N26870 G3 X241.656 Y237.195 I22.988 J-10.239
N26880 G1 X241.653 Y237.177
N26890 G1 X240.979 Y234.26
N26900 G1 X240.682 Y232.849
N26910 G1 X240.598 Y232.34
N26920 G3 X240.558 Y232.028 I4.339 J-0.702
N26930 G3 X241.877 Y233.907 I-6.612 J6.042
N26940 G1 X242.569 Y235.192
N26950 G1 X244.249 Y238.675
N26960 G1 X244.26 Y238.695
N26970 G1 X244.443 Y239.046
N26980 G1 X244.619 Y239.437
N26990 G1 X244.635 Y239.47
N27000 G1 X245.146 Y240.464
N27010 G1 X245.157 Y240.484
N27020 G1 X246.082 Y242.149
N27030 G1 X246.097 Y242.175
N27040 G1 X246.546 Y242.905
N27050 G2 X248.504 Y245.325 I10.239 J-6.281
N27060 G1 X248.541 Y245.358
N27070 G1 X249.108 Y245.826
N27080 G1 X249.118 Y245.834
N27090 G2 X251.805 Y246.688 I2.465 J-3.101
N27100 G1 X251.941 Y246.667
N27110 G1 X251.982 Y246.656
N27120 G2 X253.299 Y245.955 I-0.752 J-3.001
N27130 G2 X253.471 Y245.718 I-0.468 J-0.52
N27140 G1 X253.493 Y245.668
N27150 G1 X253.547 Y245.477
N27160 G2 X253.042 Y243.495 I-2.713 J-0.364
N27170 G1 X253.033 Y243.483
N27180 G1 X253.007 Y243.449
N27190 G1 X252.98 Y243.416
N27200 G2 X251.936 Y242.354 I-8.979 J7.779
N27210 G1 X250.99 Y241.493
N27220 G1 X250.865 Y241.368
N27230 G3 X249.561 Y239.558 I7.174 J-6.541
N27240 G1 X249.153 Y238.79
N27250 G1 X248.789 Y238.046
N27260 G1 X248.923 Y238.146
N27270 G1 X248.959 Y238.176
N27280 G2 X254.506 Y240.101 I5.109 J-5.769
N27290 G1 X254.596 Y240.09
N27300 G1 X255.752 Y239.872
N27310 G1 X255.789 Y239.864
N27320 G2 X257.508 Y238.966 I-0.964 J-3.938
N27330 G2 X258.318 Y236.027 I-1.65 J-2.036
N27340 G1 X258.3 Y235.981
N27350 G1 X258.262 Y235.897
N27360 G1 X258.194 Y235.779
N27370 G2 X257.009 Y234.968 I-1.689 J1.195
N27380 G1 X256.993 Y234.964
N27390 G2 X255.671 Y234.844 I-1.11 J4.916
N27400 G1 X254.49 Y234.9
N27410 G1 X254.456 Y234.902
N27420 G1 X252.98 Y235.042
N27430 G3 X251.927 Y235.028 I-0.445 J-6.041
N27440 G1 X251.851 Y235.019
N27450 G3 X251.103 Y234.699 I0.366 J-1.889
N27460 G1 X251.064 Y234.673
N27470 G1 X250.698 Y234.449
N27480 G3 X247.51 Y231.968 I13.71 J-20.908
N27490 G1 X247.193 Y231.646
N27500 G2 X246.99 Y231.502 I-0.499 J0.491
N27510 G1 X246.269 Y230.773
N27520 G3 X242.886 Y226.486 I19.23 J-18.648
N27530 G1 X242.777 Y226.314
N27540 G1 X242.769 Y226.301
N27550 G2 X240.016 Y222.698 I-28.543 J18.957
N27560 G1 X239.873 Y222.533
N27570 G2 X229.784 Y213.723 I-38.684 J34.117
N27580 G1 X229.766 Y213.712
N27590 G1 X228.563 Y212.962
N27600 G1 X228.527 Y212.941
N27610 G1 X226.449 Y211.812
N27620 G1 X226.407 Y211.791
N27630 G1 X224.714 Y211.013
N27640 G1 X224.191 Y210.764
N27650 G1 X224.167 Y210.753
N27660 G1 X223.442 Y210.441
N27670 G1 X219.211 Y208.476
N27680 G1 X214.687 Y206.299
N27690 G1 X211.825 Y204.849
N27700 G1 X211.236 Y204.514
N27710 G3 X210.007 Y203.451 I2.401 J-4.015
N27720 G1 X209.68 Y202.952
N27730 G3 X209.545 Y202.68 I1.832 J-1.077
N27740 G1 X209.635 Y202.654
N27750 G1 X209.671 Y202.643
N27760 G1 X210.783 Y202.259
N27770 G1 X211.222 Y202.139
N27780 G1 X211.233 Y202.136
N27790 G3 X213.082 Y202.692 I0.496 J1.702
N27800 G1 X213.124 Y202.737
N27810 G1 X214.921 Y204.515
N27820 G1 X214.945 Y204.537
N27830 G1 X215.586 Y205.114
N27840 G1 X215.596 Y205.122
N27850 G2 X217.683 Y206.429 I5.244 J-6.056
N27860 G1 X217.761 Y206.464
N27870 G1 X217.78 Y206.472
N27880 G2 X220.083 Y206.944 I2.396 J-5.839
N27890 G1 X221.352 Y206.996
N27900 G1 X223.355 Y207.22
N27910 G1 X224.235 Y207.362
N27920 G1 X224.254 Y207.365
N27930 G1 X224.929 Y207.454
N27940 G1 X224.952 Y207.456
N27950 G1 X225.094 Y207.47
N27960 G2 X225.847 Y206.629 I0.068 J-0.697
N27970 G1 X225.836 Y206.575
N27980 G1 X225.81 Y206.485
N27990 G2 X224.99 Y204.531 I-17.812 J6.327
N28000 G1 X224.982 Y204.515
N28010 G1 X224.703 Y203.979
N28020 G2 X223.666 Y202.374 I-9.679 J5.117
N28030 G2 X220.947 Y200.416 I-4.329 J3.144
N28040 G2 X218.955 Y200.087 I-1.996 J5.898
N28050 G1 X217.155 Y200.075
N28060 G3 X216.222 Y199.957 I0.213 J-5.454
N28070 G1 X216.151 Y199.941
N28080 G1 X216.014 Y199.861
N28090 G3 X215.78 Y199.413 I1.55 J-1.095
N28100 G3 X218.576 Y197.113 I7.541 J6.319
N28110 G1 X218.636 Y197.076
N28120 G2 X220.803 Y195.119 I-6.36 J-9.223
N28130 G1 X221.821 Y193.983
N28140 G1 X221.839 Y193.962
N28150 G1 X224.24 Y191.064
N28160 G1 X224.246 Y191.055
N28170 G1 X227.821 Y186.606
N28180 G1 X229.892 Y184.082
N28190 G1 X230.943 Y182.84
N28200 G1 X232.579 Y180.955
N28210 G3 X236.4 Y177.067 I38.32 J33.832
N28220 G1 X237.593 Y176.078
N28230 G3 X240.693 Y174.527 I6.31 J8.737
N28240 G1 X240.704 Y174.524
N28250 G1 X242.987 Y173.773
N28260 G3 X254.492 Y171.173 I23.218 J75.996
N28270 G1 X255.83 Y170.982
N28280 G3 X266.313 Y170.455 I8.062 J55.84
N28290 G1 X267.745 Y170.536
N28300 G1 X270.27 Y170.764
N28310 G1 X270.294 Y170.766
N28320 G1 X271.13 Y170.811
N28330 G2 X285.905 Y170.592 I6.188 J-81.078
N28340 G1 X285.939 Y170.588
N28350 G1 X287.492 Y170.344
N28360 G2 X289.877 Y169.871 I-5.746 J-35.18
N28370 G2 X293.675 Y168.518 I-3.672 J-16.317
N28380 G1 X293.706 Y168.504
N28390 G3 X294.14 Y168.392 I0.666 J1.69
N28400 G1 X294.926 Y168.29
N28410 G2 X297.101 Y167.866 I-2.644 J-19.341
N28420 G1 X297.998 Y167.646
N28430 G2 X298.233 Y167.54 I-0.167 J-0.68
N28440 G1 X298.254 Y167.525
N28450 G1 X298.905 Y167.326
N28460 G1 X298.939 Y167.315
N28470 G1 X299.982 Y166.936
N28480 G1 X300.003 Y166.928
N28490 G2 X301.608 Y165.956 I-2.134 J-5.333
N28500 G1 X301.646 Y165.921
N28510 G1 X301.761 Y165.806
N28520 G1 X301.802 Y165.762
N28530 G2 X304.14 Y161.56 I-9.489 J-8.032
N28540 G1 X304.4 Y160.838
N28550 G1 X304.41 Y160.809
N28560 G1 X304.652 Y160.033
N28570 G1 X304.761 Y159.72
N28580 G1 X304.781 Y159.65
N28590 G1 X304.897 Y159.156
N28600 G2 X305.606 Y156.238 I-29.544 J-8.724
N28610 G1 X305.89 Y154.789
N28620 G1 X305.894 Y154.766
N28630 G1 X306.22 Y152.745
N28640 G1 X306.225 Y152.708
N28650 G1 X306.38 Y151.268
N28660 G1 X306.383 Y151.214
N28670 G1 X306.384 Y151.193
N28680 G2 X305.121 Y150.757 I-0.7 J-0.02
N28690 G1 X304.741 Y151.273
N28700 G1 X303.524 Y152.628
N28710 G2 X302.364 Y152.189 I-0.695 J0.085
N28720 G1 X301.93 Y152.575
N28730 G1 X301.937 Y152.507
N28740 G1 X301.94 Y152.467
N28750 G1 X301.943 Y152.411
N28760 G2 X301.865 Y146.759 I-42.006 J-2.247
N28770 G1 X301.863 Y146.74
N28780 G1 X301.646 Y144.754
N28790 G1 X301.645 Y144.741
N28800 G1 X301.094 Y140.431
N28810 G3 X300.811 Y137.069 I45.178 J-5.492
N28820 G1 X300.809 Y136.948
N28830 G3 X302.09 Y130.324 I21.057 J0.634
N28840 G1 X302.097 Y130.304
N28850 G1 X302.183 Y130.044
N28860 G3 X304.421 Y124.646 I42.961 J14.649
N28870 G1 X304.728 Y124.001
N28880 G1 X305.516 Y122.48
N28890 G1 X306.21 Y121.265
N28900 G3 X307.726 Y119.164 I11.799 J6.918
N28910 G3 X310.115 Y116.721 I28.967 J25.939
N28920 G1 X310.52 Y116.341
N28930 G1 X310.563 Y116.297
N28940 G1 X311.382 Y115.381
N28950 G1 X311.393 Y115.368
N28960 G2 X312.993 Y111.774 I-5.309 J-4.515
N28970 G1 X314.413 Y104.597
N28980 G1 X315.045 Y101.186
N28990 G1 X315.378 Y99.261
N29000 G1 X315.381 Y99.246
N29010 G1 X315.391 Y99.181
N29020 G2 X314.862 Y98.395 I-0.692 J-0.105
N29030 G1 X315.289 Y97.075
N29040 M5 $0 (plasma end)
N29050 ;
N29060 ;begin post-amble
N29070 G40 (cutter compensation: off)
N29080 G90 (distance mode: absolute)
N29090 M65 P2 (enable THC)
N29100 M65 P3 (enable torch)
N29110 M68 E3 Q0 (velocity 100%)
N29120 M5 $-1 (backup stop)
N29130 ;end post-amble
N29140 ;
N29150 ;begin statistics
N29160 ;Pierces = 31
N29170 ; Cuts = 31, Length = 7575.88mm
N29180 ;end statistics
N29190 ;
N29200 M30 (end program)
1 year 5 months ago #327851 by snowgoer540
I’ll try to take a peek after work today
The following user(s) said Thank You: RNJFAB
1 year 5 months ago #327918 by snowgoer540
So I've run this in my virtual machine several times, both in an imperial and a metric simulation on v2.9.238.315.  I cant get it to do anything but cut in the same place over and over.
Perhaps it would be helpful to know more about your workflow?  If it's still a problem, maybe a backup of your config as made from QtPlasmaC would help.
1 year 5 months ago #327939 by RNJFAB
Thanks Snow.
I'll save a backup next time I'm in the shed and upload it.
Cheers
1 year 5 months ago #327985 by RNJFAB
File Name: CNC_V5_V2....1.tar.gz
File Size:14.77 KB
1 year 5 months ago - 1 year 5 months ago #328365 by RNJFAB
I'll try and get a video of this and upload it.
www.youtube.com/shorts/b2f-urW5Wb4
So, load file - no worries.
preview opens a long way from 0,0
cuts in location
frames where preview is shown.
Could it be the post processor??
Last edit: 1 year 5 months ago by RNJFAB.
Time to create page: 0.203 seconds
