M62-M68 codes not working
- Cdub
22 May 2025 15:55 #328937
by Cdub
M62-M68 codes not working was created by Cdub
I can figure out why my feed rate percentages and thc on/off isn’t working. Feed rate is just constantly the same and doesn’t change unless I change it manually and thc doesn’t turn off unless I turn it off manually. The g code commands are doing nothing. G code attached bellow. I made a new install media with 9.4 and reinstalled linuxcnc completely just to make sure I wasn’t out of date with anything.
(test2)
(5/22/2025 2:48 PM)
(ProNest LT 16.2.0.9215 PostBuilder 2.88 Linux CNC PlasmaC)
N10 G20
N15 G90 G40
N20 G17 G91.1
N25 G64 P0.01 Q0.01
N30 M52 P1 (Allow paused motion)
N35 M52 P0 (Disable paused motion)
N40 M65 P2 (Enable THC)
N45 M65 P3 (Allow torch on)
N50 M68 E3 Q0 (100% feed)
N55 G0 X3.088 Y3.9014
(0.375--1--D751-0243-00-Default - Seq 1)
N60 M190 P1 (Select material 1)
N65 M66 P3 L3 Q1 (1s delay to allow material selection)
N70 F#<_hal[plasmac.cut-feed-rate]>
N75 M3 $0 S1
N80 M68 E3 Q20 (Set to 20% feed)
N85 M62 P2 (Disable THC)
N90 G3 X2.8229 Y3.6363 I-0.1325 J-0.1326
N95 G3 X2.8229 Y3.6363 I0.4329 J0.4329
N100 G3 X3.088 Y3.6363 I0.1326 J0.1325
N105 M68 E3 Q100 (Reset to 100% feed)
N110 M5
N115 M65 P2 (Enable THC)
N120 G0 X0.7118 Y0.4627
N125 M3 $0 S1
N130 M63 P2 (Enable THC)
N135 G1 X0.7118 Y0.8377
N140 G1 X0.7118 Y5.8999
N145 G1 X1.2376 Y6.4257
N150 G1 X4.274 Y6.4257
N155 G1 X5.2998 Y5.3999
N160 G1 X5.2998 Y1.8635
N165 G1 X4.274 Y0.8377
N170 G1 X0.7118 Y0.8377
N175 G1 X0.4618 Y0.8377
N180 M5
N185 G0 X0.0 Y0.0
N190 M30
(test2)
(5/22/2025 2:48 PM)
N10 G20
N15 G90 G40
N20 G17 G91.1
N25 G64 P0.01 Q0.01
N75 M3 $0 S1
N110 M5
N125 M3 $0 S1
N180 M5
N185 G0 X0.0 Y0.0
N190 M30
- Cdub
22 May 2025 15:58 #328938
by Cdub
Replied by Cdub on topic M62-M68 codes not working
I also tested the default qtplasmac preamble instead of the preamble outputted by the pronest post pro to see if that had anything to do with it but didn’t change anything.
(test2)
(5/22/2025 2:07 PM)
N10 G20
N15 G40
N20 G49
N25 G64 P0.01
N30 G80
N35 G90
N40 G92.1
N45 G94
N50 G97
N75 M3 $0 S1
N110 M5
N125 M3 $0 S1
N180 M5
N185 G0 X0.0 Y0.0
N190 M30
(test2)
(5/22/2025 2:07 PM)
N10 G20
N15 G40
N20 G49
N25 G64 P0.01
N30 G80
N35 G90
N40 G92.1
N45 G94
N50 G97
N75 M3 $0 S1
N110 M5
N125 M3 $0 S1
N180 M5
N185 G0 X0.0 Y0.0
N190 M30
- snowgoer540
- Thank you received: 907
23 May 2025 09:57 - 23 May 2025 10:35 #328985
by snowgoer540
Replied by snowgoer540 on topic M62-M68 codes not working
The code (at least the code in your first post), works fine on 2.10.008.064. I realize you are on some version of 2.9, just was easy for me to test on that.
Can you state the specific version of 2.9 you are on (like above, as taken from the window title with QtPlasmaC open)?
Back when, there was a commit that temporarily broke feed reductions, but it was fixed. I honestly can’t remember if it was in 2.9 or master or both, but perhaps you have an older version that has the bug.
Last edit: 23 May 2025 10:35 by snowgoer540.
- Thank you received: 4660
23 May 2025 15:23 #329011
Replied by andypugh on topic M62-M68 codes not working
M62 and friends need connections in HAL to have any effect. Do these connections exist? (motion.digital-out-NN etc)
- Cdub
27 May 2025 10:24 #329229
by Cdub
Version is 2.9-238.315.
- Cdub
27 May 2025 10:33 #329230
by Cdub
I’m not too familiar with Hal but his is what I could find not sure if I’m even looking in the right spot.
- Cdub
27 May 2025 15:17 - 27 May 2025 15:20 #329269
by Cdub
Ok I cannot make any sense of this I have been trying to update to 2.10 for the past few hours thinking that 2.9 might be the root of anll my problems and can’t figure it out. I went into sympathetic package manager then repositories and deleted the two lunixcnc.com lines and refreshed. I then created a new one as follows
buildbot2.highlab.com/debian/
bookworm
master-uspace
then when I enter “sudo apt update” in the terminal it gives me the error I attached bellow. I have read through these post several times, but just end up more confused each time.
www.forum.linuxcnc.org/38-general-linuxc...-do-i-update-to-2-10
forum.linuxcnc.org/9-installing-linuxcnc...ate-from-2-9-to-2-10
Some clarification would be amazing, thank you.
bookworm
master-uspace
Last edit: 27 May 2025 15:20 by Cdub.
- Thank you received: 7506
27 May 2025 15:45 #329271
Replied by tommylight on topic M62-M68 codes not working
Not exactly sure but i think that is the wrong buildbot, try
buildbot.linuxcnc.org
- Cdub
27 May 2025 16:20 #329275
by Cdub
Doesn’t work. Says “does not have release file”
- snowgoer540
27 May 2025 19:30 #329283
by snowgoer540
Buildbot2 is correct, you need to sign it though, as per the instructions on the page:
Time to create page: 0.176 seconds
