PlasmaC Voltage Divider
- zzrzzr
20 Jul 2025 06:06 #332048
by zzrzzr
PlasmaC Voltage Divider was created by zzrzzr
i'm looking for a good plasmacutter that works with plasmac.
What if the plasmacutter doesn't have an internal voltage divider ? Then the THCAD 300 would be good, but its out of stock everywhere. What is the alternative if I want to use THAD 5 oder 10 ?
To buy a Proma voltage-divider or is there another professional-looking alternative ?
And maybe you can recommend a plasmacutter for plasmaC ?
Thanks.
Thanks.
- Thank you received: 7478
20 Jul 2025 14:15 #332058
Replied by tommylight on topic PlasmaC Voltage Divider
www.stahlwerk-schweissgeraete.de/Plasmas...ider-CUT-50-SThtml_1
www.stahlwerk-schweissgeraete.de/Plasmas...er-CUT-60-Pilot-IGBT
www.stahlwerk-schweissgeraete.de/plasma-schneidbrenner-p60
www.stahlwerk-schweissgeraete.de/plasmas...-cut70-pilotzuendung
www.stahlwerk-schweissgeraete.de/zubehoe...r-p-80-cnc-edelstahl
Kein divider, und kein ARC_OK, aber
noch 2 mal die 1MOhm/2W resistors und ein "reed switch/reed relay" ist alles notig, etwa 5 Euro total
dan die THCAD2 von Mesa
www.welectron.com/Mesa-Electronics-THCAD...n-A-D-Accessory-Card
sehe
linuxcnc.org/docs/devel/html/plasma/plas....html#_arc_ok_signal
forum.linuxcnc.org/plasma-laser/52203-th...able?start=30#299935
forum.linuxcnc.org/plasma-laser/52203-th...able?start=30#299958
linuxcnc.org/docs/2.8/html/plasma/plasma...ide.html#reed-arc-ok
forum.linuxcnc.org/plasma-laser/35349-op...ea-and-a-lot-of-info
That should pretty much cover everything... i hope!
sehe
- Thank you received: 5325
20 Jul 2025 14:15 #332059
Replied by PCW on topic PlasmaC Voltage Divider
You can use a THCAD2 or THCAD-10 with a series resistor
or resistors, for example 2.4M will give a 250V full scale range.
Mesa has a set of three .4W 1M .1% resistors for this purpose, when used
with a THCAD-10 or a THCAD2 set for 10V you get:
1 = 110V full scale
2 in series 210V full scale
3 in series 310V full scale
Note that lower voltage ranges improve resolution so the 210 V range is fine for most
plasma systems as it will accept continuous inputs over 1000V without damage
and voltages over 200V are not typically useful when cutting.
1 = 110V full scale
- zzrzzr
21 Jul 2025 09:53 #332107
by zzrzzr
Replied by zzrzzr on topic PlasmaC Voltage Divider
Thanks a lot for your replies.
The stahlwerk-plasmacutters look good.
I already have a THCAD10 that I use for my hypertherm powermax 1000g3, but the cut quality on the hyptherm is not the best because there is a thermal dynamics-torch mounted on the machine and it doesn't cut without an angle at 10mm steel (2mm bevel to the other side). I already changed most of the parts exept the starter cartrigde, and if I can't get it to work properly I need to buy another plasma-machine.
So I could change the Plasmacutter and still use the THCAD-10 if I add series resistors.
Maybe you can explain which exact resistor(s) I need and how exactly the resistors should be added to the plasma-cutter ? I
Somewhere I read that the THCAD should not be placed inside the controller-box ? Is that right ? So where should I put the THCAD 10 and the resistors ?
21 Jul 2025 13:36 #332120
The resistor(s) go in series with the plasma voltage to the negative THCAD input
Safety wise the resistors should be in the plasma source itself.
- zzrzzr
21 Jul 2025 16:39 #332133
by zzrzzr
Thanks.
So I could open the Plasma source, cut the cable behind the THC-plug and solder 2 x 1MegaOhm in series of the negative cable and put a shrink tubing over the 2 resistors ?
Is there an alternative to the 1MegaOhm-resistor ? I ask because in the mesanet-store it shows me over 200$ shipping-cost for the 3 resistors and there is an error when the website calculates shipping costs to germany.
21 Jul 2025 17:26 #332137
Put 1 resistor on each cable, much safer.
www.mouser.de/ProductDetail/Vishay-Dale/...rmWJGO8s8TXMfjOoM%3D
- zzrzzr
24 Jul 2025 11:59 - 24 Jul 2025 13:42 #332260
by zzrzzr
Thanks.
Is it also possible to put the voltage-divider (2 resistors) outside the plasma-source in a separate box to avoid warranty loss of the new machine ?
And where can I get a plug to connect to the THC and Start-socket of the Stahlwerk machine to connect it to my cnc-system ? Is it included when buying the stahlwerk 70P ?
Last edit: 24 Jul 2025 13:42 by zzrzzr.
- zzrzzr
26 Jul 2025 13:49 #332364
by zzrzzr
Thanks. I bought the Stahlwerk 70 P Plasmacutter.
Would this resistor also be possible (Mouser wants 20€ shipping) ?
www.reichelt.de/de/de/shop/produkt/wider...7_250_mw_0_1_-237509
Inside a box outside the pasma-source to avoid warranty-loss (7 Years warranty on the machine).
26 Jul 2025 14:05 #332367
I would choose a higher wattage/higher maximum voltage resistor
Time to create page: 0.321 seconds
