PlasmaC Voltage Divider
04 Aug 2025 07:53 #332797 by zzrzzr
Replied by zzrzzr on topic PlasmaC Voltage Divider
Thanks.
I tried 3mm thick steel and attached the clamp directly to the metal and it cut as it should.
When I do a torch-test with 3 seconds pulse then I read a voltage of 180V on the plasmac-screen. Is that a plausible value ?
Is it possible to get a table with cutting-settings for different thicknesses from sb. who also uses a Stahlwerk-Plasmacutter or comparable so I don't neet to try and waste so much metal ?
04 Aug 2025 12:44 #332814 by tommylight
Replied by tommylight on topic PlasmaC Voltage Divider
Yes it is
That will not help you much, you have to do your tests and decide on results as there are to many conditions that will inevitably change the cut quality, like: air pressure, air moisture, nozzle type, cut height, cut speed, type of material (all mild steels are not the same), etc.
Try searching this forum, i have explained several time in detail how to test and adjust for quality cutting.
Time to create page: 0.080 seconds
