PlasmaC Voltage Divider
26 Jul 2025 15:59 #332371 by zzrzzr
Replied by zzrzzr on topic PlasmaC Voltage Divider
26 Jul 2025 16:27 #332372 by Clive S
Replied by Clive S on topic PlasmaC Voltage Divider
2 x 2watt is correct I believe
26 Jul 2025 16:46 #332374 by PCW
Replied by PCW on topic PlasmaC Voltage Divider
Much better.
02 Aug 2025 14:45 - 02 Aug 2025 14:46 #332672 by zzrzzr
Thanks.
I soldered both resistors in the + und - Line inside the plasma source and also connected the 2 torch-start pins of the plasma-source with the Spindle enable + and Spindle enable - -Pin of the Mesa 7i76e-board.
When I power up the plasmacutter it instantly fires although the torch is not activated in plasmac. When I remove the 2 wires from spindle enable +- then the plasmacutter doesn't start when powered up.
When I measure between s-en+ and e-en- with a multimeter there is no connection but the plasma fires when started. Maybe somebody has an idea ? Do I need an additional relays ? With the hypertherm powermax 1000 G3 on the same mesa-card this didn't happen ?
Maybe sb has an Idea?
Last edit: 02 Aug 2025 14:46 by zzrzzr.
02 Aug 2025 15:29 #332677 by PCW
Sounds like you may have the spindle ENA polarity backwards.
02 Aug 2025 19:06 #332688 by zzrzzr
I tried it again without changing anything and the plasmacutter started without firing at startup. Then I loaded the materal and tried to make a cut through 10mm mild steel. The torch fired, but the machine didn't move. And the torch went on and of a few times.
Why does that happen ? And why doesn't the machine move ?
02 Aug 2025 19:59 #332692 by snowgoer540
Replied by snowgoer540 on topic PlasmaC Voltage Divider
Sounds like it did not get an Arc OK signal.
The criteria is different depending what Mode you are using:
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#plasma:modes
03 Aug 2025 08:01 - 03 Aug 2025 08:23 #332710 by zzrzzr
I use mode 0.
I connected the divided arc voltage to the thcad and now the machine moves when it cuts, but it also goes on and of very often. You can see it here:
Could it also be a grounding-problem as the part is very small and I attached the ground clamp to the aluminium box where a steel grid is inside.
And why does it dive down in the middle of the part ? It seems to stop when the float switch is activated.
Last edit: 03 Aug 2025 08:23 by zzrzzr.
03 Aug 2025 12:45 #332717 by tommylight
Replied by tommylight on topic PlasmaC Voltage Divider
Change pierce delay to something much smaller, like 0.2 for up to 5mm thick, 0 for up to 2mm and 0.5 for 5-10mm, etc.
Also show us other settings and the main screen while cutting.
03 Aug 2025 13:54 #332720 by snowgoer540
As Tommy said, it's difficult to say without seeing all of your settings and such.  The sputtering is likely a connection issue of some sort, but the dive looked to me like there's something set incorrectly.  Looked like a move to cut height that was in the part rather than above the part.
Time to create page: 0.124 seconds
