PlasmaC Voltage Divider
1 year 2 months ago #332717
Replied by tommylight on topic PlasmaC Voltage Divider
Change pierce delay to something much smaller, like 0.2 for up to 5mm thick, 0 for up to 2mm and 0.5 for 5-10mm, etc.
Also show us other settings and the main screen while cutting.
- snowgoer540
- Thank you received: 907
1 year 2 months ago #332720
by snowgoer540
Replied by snowgoer540 on topic PlasmaC Voltage Divider
As Tommy said, it's difficult to say without seeing all of your settings and such. The sputtering is likely a connection issue of some sort, but the dive looked to me like there's something set incorrectly. Looked like a move to cut height that was in the part rather than above the part.
1 year 2 months ago #332797
by zzrzzr
Replied by zzrzzr on topic PlasmaC Voltage Divider
Thanks.
I tried 3mm thick steel and attached the clamp directly to the metal and it cut as it should.
When I do a torch-test with 3 seconds pulse then I read a voltage of 180V on the plasmac-screen. Is that a plausible value ?
Is it possible to get a table with cutting-settings for different thicknesses from sb. who also uses a Stahlwerk-Plasmacutter or comparable so I don't neet to try and waste so much metal ?
1 year 2 months ago #332814
Try searching this forum, i have explained several time in detail how to test and adjust for quality cutting.
Yes it is
That will not help you much, you have to do your tests and decide on results as there are to many conditions that will inevitably change the cut quality, like: air pressure, air moisture, nozzle type, cut height, cut speed, type of material (all mild steels are not the same), etc.Is it possible to get a table with cutting-settings for different thicknesses from sb. who also uses a Stahlwerk-Plasmacutter or comparable so I don't neet to try and waste so much metal ?
Time to create page: 0.261 seconds
