What are the chances of getting this setup working?
3 years 2 months ago #277970 by blazini36
github.com/yur7aev/linuxpnp/blob/master/configs/pnp/pnp.hal
Judging by the date it was created in the days of Python2. I'm not worried about the hal stuff, I'm just curious if the Python stuff will run on 2.9.
3 years 2 months ago #277975 by tommylight
Video is by Dimitry, he is a meember here and is very helpful.
His nic here has numbers in it, something like D1m1try ....
3 years 2 months ago #278020 by blazini36
This forum doesn't really have a means of contacting people so maybe he'll stumble across the thread.
3 years 2 months ago #278037 by tommylight
He is here a lot i think, does mirracles with Mitsubishi servo drives.
Again, i think that is him.
3 years 2 months ago #278155 by Aciera
Out of curiosity I had a go at it and got it mostly working with 2.9 on a recent Bookworm installation.
Here is a sim config:
File Name: axis_camview.tar
File Size:200 KB
I was struggling to get the usb camera stream working and ended up installing a bunch of stuff that turned out to be irrelevant but you will probably need this:
sudo apt install qv4l2
To try it out:
1. open a terminal and go to
/home/user/linuxcnc/configs/axis_camview/
2. run the vision app
$ python3 pnp.py
this should open a window and show a live stream of your usb cam.
If you don't then you may have to adjust the video device number in the brackets in line 271 in 'pnp.py'
 self.cam = cv.VideoCapture(0)
once that works, open another terminal and run
$ linuxcnc
then choose the 'axis_camview' config.
Some notes:
I don't know much about opencv and even less about gtk so pnp.py will likely need some more work. Sometimes the stream breaks when loading pnp.py or when starting the linuxcnc config. Also exiting the vision app seems a bit iffy, I usually need to hit CTRL+c a few times and then ENTER a few times.
Setting 'vision'debug' to 0 in halshow will hide the edge finding debug window.
To test I used a SD-card and good lighting with a ring light. The vision app seems to be looking for a certain format of rectangle.
I use a usb web cam with 720x480 resolution. Depending on your camera you may need to adjust 'pnp.py' in the following lines:
300    self.cam.set(cv.CAP_PROP_FRAME_WIDTH, 720)
301    self.cam.set(cv.CAP_PROP_FRAME_HEIGHT, 480)
418    frame = cv.warpPerspective(frame, M, (720, 480))
pnp.py is made to handle two cameras (bottom, top). Since I only have the one camera I had to disable the second camera by commenting line 383 and adding line 384
383        #if p.cam == 0:
384        if True:
Good luck.
The following user(s) said Thank You: tommylight, blazini36, my1987toyota
3 years 2 months ago #278235 by jpg
essayez ici , je pense que c est son site :
yurtaev.com/
Time to create page: 0.266 seconds
