What are the chances of getting this setup working?
- Thank you received: 7487
17 Apr 2025 00:14 #326498
Ending rant here, sorry to all.
Replied by tommylight on topic What are the chances of getting this setup working?
Yeah that never ended good in my case, as i might have mentioned before, until 2008 i was extremely aggressive, not helped by surviving 2 wars, so i made sure i get no such requests ever again.I am sure you have also had to deal with the type of people that look at you and go " Oh you look fine,
say can you ( add requested favor here ) for me"? I have had to deal with that a lot. It don't matter how
tired you are, how much you just gut out life's aches and pains. they are utterly convinced you exist
to make other people's whims a reality.
The following user(s) said Thank You: my1987toyota
- my1987toyota
- Thank you received: 448
17 Apr 2025 16:32 #326527
by my1987toyota
Replied by my1987toyota on topic What are the chances of getting this setup working?
No need to apologize, war is hell.
- blazini36
- Thank you received: 167
07 May 2025 22:52 #327964
by blazini36
It'd be nice if there was a proven simplified PnP setup for LinuxCNC. I'd be alot more inclined to finish the mechanical stuff if I knew software wasn't going to be a long drawn out slug fest. Hopefully somebody beats me to it, if not maybe I'll get there one day lol.
I do find flexGUI to be a pretty easy (ish) way to get a purpose built UI going. I was able to convert the one I was making for my mill into a laser UI fairly simple. I'd definately use that to tackle the PnP thing if I were at it right now.
Replied by blazini36 on topic What are the chances of getting this setup working?
I tend to post and then forget about LinuxCNC for a few weeks lol, forgot to check on this. I just converted the machine I intended to be to a laser cutter.....since I needed one and figured I could actually get that going. I had a belted see-saw Z, which I just stripped to mount the laser to the carriage. I did redesign it to be a rack and pinion see-saw so that way I could easily swap out the PnP nozzles for and the laser and have a compatible Z. I haven't machined it yet thoughWell with my project I got interested in other things and haven't spent much time on it in a while.
Partly the placer head desperately needs updating to modern day equipment. Cable and pulley
for the Z axis is in my opinion a terrible idea but the machine was designed in 1993. We have a few
other PnP machines where I work so this one was more or less an experiment. Plus work just
doesn't seem to ease up.
- my1987toyota
12 May 2025 10:41 #328264
by my1987toyota
Where I work right now it's pretty lean ( thanks to the new tariffs ) so I wont be messing with ours unless
we have a really good reason to need it. That said I wish you luck on your project.
Time to create page: 0.106 seconds
