Another GUI project underway
7 years 7 months ago #128821 by bevins
Replied by bevins on topic Another GUI project underway
WOW, that looks amazing. Nice job.
The following user(s) said Thank You: Lcvette
7 years 7 months ago #128907 by Lcvette
pl7i92 wrote: i tryed to set it up under a SIMULATOR 18.94
but it does not load Brender
The Probe Vertical does display DOUBLE Axe Entrys overlaping
once the original version of probe basic is completely hashed out and everything is working as intended, the vertical and lathe screens will then be brought current. it is the best use of time since they all share the same backend just different layout formatting. with things changing quickly now it would require a lot of doing and undoing potentially and that time is better served elsewhere to get the primary gui ready. then the others should be quickly updated with known good formatting.
Chris
7 years 7 months ago #128909 by KCJ
Replied by KCJ on topic Another GUI project underway
Thanks for reporting the problem with brender! Should be fixed as of this morning.
Kurt
7 years 7 months ago #128910 by Lcvette
pl7i92 wrote: @lavette
amazing work
woudt you considder to get a info of the tool shape in the pocket/holder
on this frame
like this?
7 years 7 months ago #128923 by tommylight
Gave it a try last night, could not make anything work ! Just a loooong list of errors.
Maybe tomorrow will have another go at it.
Thank you all for doing such a wonderful GUI.
7 years 7 months ago #128952 by BigJohnT
tommylight wrote: Gave it a try last night, could not make anything work ! Just a loooong list of errors.
Are you using Debian 9 64 bit or Linux Mint 19 64 bit with LinuxCNC 2.8 (master)? Zip up the errors and we will have a look see...
JT
The following user(s) said Thank You: tommylight, Lcvette, KCJ
Moderators: KCJ, Lcvette
Time to create page: 0.523 seconds
