Another GUI project underway
  • Lcvette
  • Lcvette's Avatar Topic Author
  • Moderator
  • Moderator
19 Mar 2019 23:08 #129020 by Lcvette
Replied by Lcvette on topic Another GUI project underway
oh you said this was on something other than debian?
19 Mar 2019 23:15 #129021 by KCJ
Replied by KCJ on topic Another GUI project underway
AHA! You are using Mint 18.3, I bet the problem is with the Qt version ...
When the error dialog come up click the "Open Issue" button and it should create a new issue pre-populated with a bunch of system info. If for some reason the error diolog does not work then let us know what the output this command is.
python -c "import qtpy; print qtpy.QT_VERSION"
The following user(s) said Thank You: tommylight, Lcvette
  • Moderator
  • Moderator
19 Mar 2019 23:21 #129022 by tommylight
Replied by tommylight on topic Another GUI project underway
Ok, i am glad to report that nothing works ! :)
I do have to many things installed on this PC ( main one with 4 monitors ), and the Mint version is 18.3 and the preempt-rt kernel was compiled on another PC ( the one with only 2 monitors <<jokes ) and i just installed it as is, linuxcnc has been installed and reinstalled several times as i do a lot of testing on this PC.
So all in all, a lot of places for things to go wrong ( currently any USB stick i insert that ends up being /dev/sdb will be ReadOnly !!! ). One of the 4 monitors or the graphic card ( Radeon RX580 ) has a strange issue when i power off the PC, it will remain on with a blank screen until i remove the DP cable !
Gremlins, lots of them !
I have another quad i5 here but no place to put it, so that will have to wait some more, it does have Mint 19.1 installed but no RT and no Linuxcnc. Soon......
The following user(s) said Thank You: Lcvette
  • Moderator
  • Moderator
19 Mar 2019 23:22 #129023 by tommylight
cnc@cncmine:~$ python -c "import qtpy; print qtpy.QT_VERSION"
5.5.1
cnc@cncmine:~$
The following user(s) said Thank You: Lcvette, KCJ
  • Moderator
  • Moderator
19 Mar 2019 23:26 #129024 by tommylight
I did , the result
414 Request-URI Too Large
19 Mar 2019 23:29 #129026 by KCJ
QtPyVCP currently only works with Qt 5.7.1 or later, so that is the problem right there :(
Once we support PySide2 that limitation will be removed and it should be able to run on pretty much any 64bit system with Python 2.7 support.
  • Moderator
  • Moderator
19 Mar 2019 23:30 #129027 by tommylight
This is getting more and more fun !
Did try again to send the report, now i got
Looks like something went wrong!
We track these errors automatically, but if the problem persists feel free to contact us. In the meantime, try refreshing.
After some refreshing it dawned on me, I need refreshing ! Down to grab a coke, back in a jiffy !
19 Mar 2019 23:31 #129028 by KCJ
I did , the result
LOL, you must have WAY too many errors!
  • Lcvette
  • Moderator
  • Moderator
19 Mar 2019 23:32 #129029 by Lcvette
Tommy broke it! :ohmy: :pinch:
  • Moderator
  • Moderator
20 Mar 2019 00:04 #129030 by tommylight
YES I DID ! :woohoo: :P
Moderators: KCJ, Lcvette
Time to create page: 0.119 seconds
