Another GUI project underway
- pl7i92
- Thank you received: 358
10 Mar 2019 08:27 #128212
by pl7i92
Replied by pl7i92 on topic Another GUI project underway
@lavette
amazing work
woudt you considder to get a info of the tool shape in the pocket/holder
on this frame
amazing work
on this frame
The following user(s) said Thank You: Lcvette
- BigJohnT
- Thank you received: 994
12 Mar 2019 10:10 #128417
by BigJohnT
Replied by BigJohnT on topic Another GUI project underway
Looking good you and Turboss are on a roll.
JT
JT
The following user(s) said Thank You: Lcvette, KCJ
- Thank you received: 7468
12 Mar 2019 16:43 #128449
Replied by tommylight on topic Another GUI project underway
Still drooling over it, you guys owe me a laptop !
Nice work !
BTW i think there are 3 of them working on it, Lcvete, TurBoss and KJC.
Hopefully in 2 to 4 days i will finish a project i am working on ( not related to CNC ) so i can try to join them with helping or messing or just plain annoying !
Nice work !
The following user(s) said Thank You: BigJohnT, Jedi, Lcvette, KCJ
- KCJ
- Thank you received: 267
12 Mar 2019 16:52 #128450
by KCJ
Replied by KCJ on topic Another GUI project underway
JT has been helping a LOT too! It's great, I can just sit back and watch the commits roll in
The following user(s) said Thank You: tommylight, Jedi
- Type_Zero_Design
12 Mar 2019 16:58 #128451
by Type_Zero_Design
Replied by Type_Zero_Design on topic Another GUI project underway
This project looks awesome! Any idea when the mill version might be trickling out?
- Becksvill
- Thank you received: 115
15 Mar 2019 22:08 #128689
by Becksvill
Replied by Becksvill on topic Another GUI project underway
Hey guys.
This looks awesome!
I am currently retrofitting a machining centre and will be very interested in this new gui.
One thing I think may be needed though is there needs to be some way of adjusting stuff like number of toolholders in the toolchanger. my machine has 24 tools etc. And any other custom things which need to change. If there was a way to easily change little details and we just use the gui as is for most of the other 90 percent of functionality that may be the way to go.
Not sure how hard that is to code in while building but I am so glad to see a gui project that doesn't look like it was made in the 1970s like axis.
Regards
Andrew
This looks awesome!
Regards
Andrew
- pl7i92
16 Mar 2019 08:29 #128716
by pl7i92
i tryed to set it up under a SIMULATOR 18.94
but it does not load Brender
The Probe Vertical does display DOUBLE Axe Entrys overlaping
- BigJohnT
17 Mar 2019 12:22 #128813
by BigJohnT
There are two mill versions of probe basic as well as the lathe version and other mill ui's to pick from.
qtpyvcp.kcjengr.com/showcase/mill_vcps.html
Or you can simply roll your own after doing the tutorial.
qtpyvcp.kcjengr.com/tutorials/index.html
JT
JT
The following user(s) said Thank You: tommylight, Lcvette
- bevins
- Thank you received: 338
17 Mar 2019 13:39 #128821
by bevins
Replied by bevins on topic Another GUI project underway
WOW, that looks amazing. Nice job.
- Lcvette
- Thank you received: 782
18 Mar 2019 16:58 #128907
by Lcvette
once the original version of probe basic is completely hashed out and everything is working as intended, the vertical and lathe screens will then be brought current. it is the best use of time since they all share the same backend just different layout formatting. with things changing quickly now it would require a lot of doing and undoing potentially and that time is better served elsewhere to get the primary gui ready. then the others should be quickly updated with known good formatting.
Chris
Replied by Lcvette on topic Another GUI project underway
Chris
Moderators: KCJ, Lcvette
Time to create page: 0.174 seconds
