- Thank you received: 784
tommylight wrote: I have to say, it is looking better and better with every iteration! I like the jog thingy very much as i plan to get my mints on a 17" touch screen, bigger ones are prohibitively expensive.
Great work from all of you. Thank you.
P.S.
The pressure at work is unrelenting so i have no time to even visit on the IRC.
Lcvette wrote: it was also noted a few times about the 5 axis being shown when most only need 3, the short answer for that is we still have to design for the 5 axis if we will offer it, the 3 and 4 axis will be similar just without the extra buttons and a little more room between things in those groups, they will be probably bigger buttons there as well since less needs to be packed into the same space! so bear with us on that front!
BigJohnT wrote:
Why don't you just dynamically add the axis buttons/controls based on the [TRAJ] COORDINATES when in world mode and jog controls in joint mode based on [KINS] JOINTS?
JT
