- Thank you received: 784
eFalegname wrote: Hello mate!
my question is a bit ... desperate and I apologize for that, but could you tell us an estimated date for the public release? Have you already decided a name for your project?
Nothing can stop you now, keep up the good work!
Thanks!
Floris
Immutef wrote: I'm also looking forward to get that GUI running on my CNC converted MH25V. Good luck! Maybe I'll find some spare time to set the development environment up and help out a little bit.
once the gui builder interface is com-pleted and the mill gui is up and running i personally will look into making a lather interface of similar design feel but with all the feel of a true lathe interface. that is my plan at this point.
any coding help you can give Hazzy would be awesome he is unfortunately the only one at the moment who is working on the backend stuff as he is the only one who understands it in our group..lol anyone else whith the coding knowledge who could come in and help speed along the process would only be helping move up the release date!
Yeah. Three weeks ago I tried to get it running on a VirtualBox (so I can play with it anytime in the simulator) but I couldn't get it running (it missed some Python dependency [some widget] which I couldn't fix, beside installing everything needed / following the instructions). On the other hand, the VirtualBox performance is ... gosh. If there's a trick, I absolutely need it ... the Box freezes after 30seconds in Axis and doesn't recover.
I'm very close to get my mill CNC converted (just have to finish some parts, mount them, and then I can continue hooking up the electronics) so I can put a RIP-LinuxCNC on my controller and start testing.
