VTK Backplot on RPi 4
- scotta
- Thank you received: 489
09 Sep 2020 07:50 #181392
by scotta
Replied by scotta on topic VTK Backplot on RPi 4
Great news! Quite some hours getting this to work on the RPi in Pi OS. It's been working for ages in Arch Linux....
The following user(s) said Thank You: KCJ
- Nabazul
11 Sep 2020 19:20 #181786
by Nabazul
Replied by Nabazul on topic VTK Backplot on RPi 4
Just had the time to test this out. This is way better now scotta! Thank you very much!! The axis backplot still feels a little bit snappier (especially when rotating the view) But it is good enough for me to switch over from axis.
- Nabazul
12 Sep 2020 19:20 #181920
by Nabazul
Does the ATC tab in probe_basic work for you guys? It does not show anything for me (in the sim as well as on my own machine). I don't really mind it not working since i am manually changing tools but i think it not working is messing up my tool screen and tool database.
- anfänger
- Thank you received: 256
13 Sep 2020 14:27 #182014
by anfänger
Replied by anfänger on topic VTK Backplot on RPi 4
the atc tab ist perfect for umbrella or side mount tool changers.
I like the widget, with a litte bit of work it can be adopted to different types of tool changers. I am working with a basket tool changer and modified my tool change code to detect if a tool is in the toll changer or If I need to manually change it.
I made the adjustments to suite my needs and really loving probe_basic.
- BigJohnT
- Thank you received: 994
28 Dec 2020 12:02 #193351
by BigJohnT
Replied by BigJohnT on topic VTK Backplot on RPi 4
I'm trying to get VTK to work on a Rpi4 with Raspian Lite and Openbox mainly because the desktop OS's change the colors of widgets to match someone's style in some far off place I guess.
Anyway I downloaded the deb and did dpkg -i and got this error.
Do you have the steps you used to build the deb?
JT
$ sudo dpkg -i vtk_7.1.1-qt5py2-1_armhf.deb
[sudo] password for john:
dpkg-deb: error: 'vtk_7.1.1-qt5py2-1_armhf.deb' is not a Debian format archive
dpkg: error processing archive vtk_7.1.1-qt5py2-1_armhf.deb (--install):
dpkg-deb --control subprocess returned error exit status 2
Errors were encountered while processing:
vtk_7.1.1-qt5py2-1_armhf.debDo you have the steps you used to build the deb?
JT
- nion
29 Dec 2020 23:31 #193466
by nion
Replied by nion on topic VTK Backplot on RPi 4
Don't execute "wget github.com/scottalford75/LinuxCNC-on-RPi...1-qt5py2-1_armhf.deb"
You will end up for some reason with a incomplete downloaded file.
Try to download the link github.com/scottalford75/LinuxCNC-on-RPi...1-qt5py2-1_armhf.deb with a browser
- nic
13 Jun 2021 08:40 #211924
by nic
Replied by nic on topic VTK Backplot on RPi 4
Hi scotta,
i´ve tried to install probe basic on RP4 with your deb file but i still have the
ImportError: No module named qt
error.
Do you know a solution on this issue?
Thanks in advance.
Best regards,
Nic
error.
Thanks in advance.
Best regards,
Nic
- scotta
19 Jun 2021 00:44 #212372
by scotta
Does qtpyvcp load the simpler QUI's? Looks like a basic config error and nothing to do with the VTK back plot.
- BigJohnT
19 Jun 2021 13:36 - 19 Jun 2021 13:37 #212401
by BigJohnT
Last edit: 19 Jun 2021 13:37 by BigJohnT.
- nic
21 Jun 2021 17:45 #212567
by nic
Hi scotta,
thank you for your reply. No, none of the qtpyvcp UI`s work.
Best regards,
Nic
Best regards,
Nic
Moderators: KCJ, Lcvette
Time to create page: 0.236 seconds
