MonoKrom - QtPyVCP GUI for PlasmaC and Mill
6 years 1 month ago - 6 years 3 weeks ago #182773 by pinder
hello everyone.
I want to make a new gui for my PlasmaC Machine.
PlasmaC axis and gmoccapy work just fine, I just want to make an exclusive GUI. Can anyone guide me.
Moreover, other thing I want is that my system boots directly to the Plasmac, just like Pathpilot. If we want to desktop, there should be some key combination.
Pathpilot is based on linuxcnc if that can do it, linuxcnx should also.
Thanks in advance.
Update: 01/10/2020
MonoKrom is the decided name.
@KCJ is working hard in qtpyvcp.
05/10/2020
added VCP for Mill MonoKrom-Plasma & MonoKrom-Mill
You can install semi-working GUI from github
This is the result so far.
After discussions monochrome yellow is the way to go.
Last edit: 6 years 3 weeks ago by pinder.
The following user(s) said Thank You: TurBoss
6 years 1 month ago #182781 by tommylight
Replied by tommylight on topic qtpyvcp Gui for plasmac
pinderkhara wrote: I just want to make an exclusive GUI.
Are you willing to share that GUI after you are finished?
pinderkhara wrote: Can anyone guide me.
Yes, most probably for whatever is reasonable.
pinderkhara wrote: How i can load plasmac run tab in Plasmac.
pinderkhara wrote: Moreover, other thing I want is that my system boots directly to the Plasmac,
Just add the link to "startup applications" from the preferences menu. Or if you really want to skip everything else, use the "kiosk" mode for Linux.
6 years 1 month ago #182818 by pinder
Replied by pinder on topic qtpyvcp Gui for plasmac
Yes, definitely I am.
Thankyou @tommy, you are an inspiration for the community.
How can i load plasmac panels(config, run, preview) in qtpyvcp.
I will dig that up.
6 years 1 month ago #182819 by pinder
This is a sample of GUI
I am targeting touch screens. After working out the GUI I will also share physical control panel plans.
6 years 1 month ago #182830 by tommylight
pinderkhara wrote: How can i load plasmac panels(config, run, preview) in qtpyvcp.
Not that i am aware of, i think there is some work going on on QtVCP, but not on QtPyVCP , but PlasmaC works with Axis and Gmoccapy for now.
The following user(s) said Thank You: pinder
6 years 1 month ago - 6 years 1 month ago #182832 by phillc54
Replied by phillc54 on topic qtpyvcp Gui for plasmac
The PlasmaC panels are all Gladevcp panels so I doubt they would work with qtpyvcp.
I would imagine that you would need to rewrite it to fit into this environment.
Last edit: 6 years 1 month ago by phillc54.
Moderators: KCJ, Lcvette
Time to create page: 0.138 seconds
