MonoKrom - QtPyVCP GUI for PlasmaC and Mill
10 months 3 weeks ago #339946 by andypugh
Replied by andypugh on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Is there a way to manually apply the Monokrom filter plasma_gcode_preprocessor to a G-code file outside of Monokrom, just to see what the output looks like?
Does Monokrom have an option to save the current G-code file? (I can see that it might well not have, as you can't typically change the file in the GUI, so there is no point).
You might be able to view the file-as-run in the GUI though, and see something odd around (I stress "around" as the reported line number can be off by several lines)
Unary operators are things like SIN[] COS[] etc so I would be looking for unexpected square brackets.
10 months 6 days ago #340520 by Sandro
Replied by Sandro on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Okay it is possible to pre-process the g-code manually like this:
1) Launch an instance of Monokrom (sim)
2) Navigate to the Monokrom Simulation Config Directory. Open terminal there and set environment variables
~/linuxcnc/configs/sim.monokrom/plasmac$ export CONFIG_DIR=$(pwd) ~/linuxcnc/configs/sim.monokrom/plasmac$ export INI_FILE_NAME=$(pwd)/xyz.ini
3) Call preprocessor in terminal with the input.ngc processed by the SheetCam PlasmaC Post
~/linuxcnc/configs/sim.monokrom/plasmac$ python3 plasma_gcode_preprocessor.py input.ngc > processed.ngc
The output is the processed.ngc. The first few lines are below:
Filter name: from-ini func: <function from_ini at 0x7ff0a03176a0> (--------------------------------------------------) (            Plasma G-Code Preprocessor            ) (                 00.30                            ) (--------------------------------------------------) ;inputs #<ucs_x_offset> = [#5221 + [[#5220-1] * 20]] #<ucs_y_offset> = [#5222 + [[#5220-1] * 20]] #<ucs_r_offset> = [#5230 + [[#5220-1] * 20]] #<array_x_offset> = 0.0 #<array_y_offset> = 0.0 #<array_columns> = 1 #<array_rows> = 1 ...
This is why I get the error in input.ngc line 1: Unknown word where unary operation could be. The first line contains "Filter name: from-ini func: <function from_ini at 0x7ff0a03176a0>".
10 months 22 hours ago - 10 months 10 hours ago #340798 by Joco
That bug should be resolved in recent builds of the framework.  Its not a monokrom bug. It came out due to an errant print statement.
"What's the first rule?  Do NOT use print statements in the code.  Use LOG.debug"
Last edit: 10 months 10 hours ago by Joco.
8 months 2 weeks ago - 8 months 2 weeks ago #343157 by AlessandroEmm
Replied by AlessandroEmm on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Hey guys, trying to get monokrom or at this point qtpyvcp to run, but I always end up with problem in the DB lookups. Since i don't really know how the ORM works i struggle to fix this myself. This is with a clean sqlite db. With the latest main branch on monokrom.
Thanks!
  File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 224, in loadPlugins     registerPluginFromClass(plugin_id=plugin_id, plugin_cls=cls, args=args, kwargs=kwargs)     ~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^   File "/usr/lib/python3/dist-packages/qtpyvcp/plugins/__init__.py", line 79, in registerPluginFromClass     inst = plugin_cls(*args, **kwargs)   File "/usr/lib/python3/dist-packages/qtpyvcp/plugins/plasma_processes.py", line 356, in __init__     self._measurementid = LinearSystem.get_by_key(self._session, 'name', linear_setting)[0].id                           ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^ IndexError: list index out of range
Last edit: 8 months 2 weeks ago by AlessandroEmm.
Moderators: KCJ, Lcvette
Time to create page: 1.633 seconds
