- Thank you received: 327
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- Joco
4 years 11 months ago #225273
by Joco
Replied by Joco on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Cheers - will run with that. It was also my preferred path and will be way quicker to implement.I would suggest having the access level set in designer. This makes it easier from a editing standpoint, and also harder for somebody to change permission levels.
- Joco
4 years 11 months ago #225282
by Joco
Stage 1 on security feature done and pull request raised to framework. This supports trapping the security level against a widget via Designer.
As for the behaviour side of the implemnetation I am thinking doing this via a plugin is the correct pattern. This way it's not there as standing overhead and can be enabled by a UI designer via the UI's yaml config file.
The following user(s) said Thank You: KCJ
- pinder
- Thank you received: 128
4 years 11 months ago #225765
by pinder
Replied by pinder on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
hello @Joco
I appriciate for efforts you are putting here.
I will try to catch up the project again.
Cheers
Pinder
Cheers
Pinder
- anfänger
- Thank you received: 267
4 years 11 months ago #225929
by anfänger
Replied by anfänger on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Hi, has anyone tried MonoKrom on a mill yet. I think it would be fun to keep the oldschool look of my current retrofit project. For my other machines I’ve used probe basic, but I am not sure if it fits the screen I’ve here.
Thanks Patrick
Thanks Patrick
- Joco
4 years 11 months ago #226015
by Joco
Hazzy did the initial mill work. But don’t know if he has done anything more than sim tests with it. I’m solely focused on the plasma version slowly nibbling at the long road to catchup with qtplasmac.
The following user(s) said Thank You: anfänger
- anfänger
4 years 11 months ago #226020
by anfänger
Thanks, I will give it a look when I start with the GUI
Moderators: KCJ, Lcvette
Time to create page: 0.245 seconds
