MonoKrom - QtPyVCP GUI for PlasmaC and Mill
4 years 11 months ago #226087 by Joco
A short update. With reference to
forum.linuxcnc.org/media/kunena/attachments/22732/param-run.jpg
The save/update/reload/new have been implemented on the combination of process-filters to process-parameters.
I'm also working on a simple "behind the scenes" script to seed a filters/parameters cut database from sheetcam tool files or a standard tabular format.  The pattern being to convert from a source (sheetcam being the most likely source, but other popular formats could be supported) to the common tabular text format (just tab separated csv) which will be loadable into the qtpyvcp plasma database via the frameworks plasma-processes plugin.
The next stage is to get the linkage to hole/slot cutting parameters for hole/slot auto detection. The intent being to support process adjustment on gcode load.
Cheers - James.
4 years 11 months ago #226239 by Joco
A short video showing the new material/cut selection Model i was working on recently.  Some “fat finger” tuning to be done but hopefully it gives the general idea.
The following user(s) said Thank You: tommylight, rodw, KCJ
4 years 11 months ago #226600 by anfänger
Replied by anfänger on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Just took a short look at the mill version. its really at an early state with a lot work to do. Is there a way to get the development version like with Probe Basic?
cheers Patrick
4 years 11 months ago #226607 by Joco
The development version is the one here:
github.com/KurtJacobson/monokrom-vcp
The following user(s) said Thank You: BigJohnT
4 years 11 months ago - 4 years 11 months ago #226626 by anfänger
thanks I downloaded it. Strange on the weekend I thought it wanted a username and password to checkout.
Last edit: 4 years 11 months ago by anfänger.
4 years 11 months ago #227325 by Joco
New screen video of the interaction between gcode file, the filter program, the cutchart DB and the UI.  Audio might be a little loud so suggest you turn down to start with and increase to comfortable levels.
Cheers - J.
The following user(s) said Thank You: TurBoss, tommylight, rodw
Moderators: KCJ, Lcvette
Time to create page: 0.192 seconds
