- Thank you received: 7491
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
1 year 2 months ago #332811
Replied by tommylight on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Subbed with @tomapc and was already subbed with @toma.cnc1 , i think, will also check @toma.3d.
- Thank you received: 4153
1 year 2 months ago #332854
Replied by rodw on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Thanks Tommy! (9 to go), keep up the good work.Subbed with @tomapc and was already subbed with @toma.cnc1 , i think, will also check @toma.3d.
1 year 2 months ago #332858
Added 2 more.
@tomapc
@toma.cnc1
@toma.3d
@tomaberisha5688
Reminds me, i have to fix the name on the last one as it was the first one i registered.
@tomapc
@toma.cnc1
@toma.3d
@tomaberisha5688
- Sandro
- Thank you received: 38
1 year 1 week ago #336722
by Sandro
Replied by Sandro on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Hello everyone
After seeing your video (looks really great by the way), I wanted to check out MonoKrom as well. However, following the instructions on the QtPyVCP repo, I fail at the step of installing MonoKrom itself. The apt source seems not be available anymore.
www.qtpyvcp.com/install/apt_install.html
$ sudo apt install python3-monokrom
Greetings Sandro
Greetings Sandro
- Joco
- Thank you received: 327
1 year 1 week ago - 1 year 1 week ago #336895
by Joco
Replied by Joco on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
The standard instructions are for stable releases. Monokrom is still in development. To enable access to development you need to adjust the sources line in /etc/apt/sources.list.d/kcjengr.list to read:deb [arch=arm64]
repository.qtpyvcp.com/apt
develop main
NOTE: the arch= on your install migh be different. Do no change that part of the entry.
Cheers.
Cheers.
Last edit: 1 year 1 week ago by Joco.
- Sandro
11 months 4 weeks ago #337778
by Sandro
Thank you Joco!
This works and I'm able to control my plasmacutter. I really like the interface.
I'm now only facing an issue loading g-code. I'm using the plasmac post processor for Sheetcam which outputs .tap files. When I load a file, I get the message “unknown word where unary operation could be”. I just assume, it has something to do with the filte section in my INI-File.
Is it possible, that the preprocessor cannot interpret my .tap. file?
[FILTER]
PROGRAM_EXTENSION = .ngc,.nc,.tap GCode File (*.ngc, *.nc, *.tap)
ngc = plasma_gcode_preprocessor
nc = plasma_gcode_preprocessor
tap = plasma_gcode_preprocessor
Moderators: KCJ, Lcvette
Time to create page: 0.806 seconds
