- Thank you received: 454
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- Hakan
11 months 3 weeks ago - 11 months 3 weeks ago #338079
by Hakan
Replied by Hakan on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Yes, trixie uses python3.13. I guess it would be fine in bookworm with 3.11.
It turned out the tool_db issue was just a setting in xyz.ini. The tool program is in /usr/bin.
I have played around a bit and yes it looks very very nice.
The material handling looks awesome.
So I'll turn it into a real machine, for my plasma cutter.
Last edit: 11 months 3 weeks ago by Hakan.
- Thank you received: 4153
11 months 3 weeks ago #338110
Replied by rodw on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Yes, I helped Joco get this working on real hardware when he did the first development. and it is very good. Built like a touch screen gui should be!Yes, trixie uses python3.13. I guess it would be fine in bookworm with 3.11.
- Sandro
- Thank you received: 38
11 months 6 days ago #339256
by Sandro
Replied by Sandro on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
So the plasma_gcode_preprocessor which comes with Monokrom works for you? I still had no success.
11 months 5 days ago #339306
I used sheetcam with the plasmac post processor and let monokrom's filter do the hole processing.So the plasma_gcode_preprocessor which comes with Monokrom works for you? I still had no success.
- Sandro
10 months 4 weeks ago #339698
by Sandro
Hello Rodw,
I’m also using the Plasmac post from SheetCam. I followed your advice and changed the SheetCam setting to output .ngc instead of .tap. Unfortunately, as long as the Monokrom filter is enabled, it doesn’t work—I get the error:
“unknown word where unary operation could be.”
This happens both on my actual machine and with the Monokrom simulation configuration. With QtPlasmaC, I don’t have any issues. Maybe over the weekend I can share a G-code test file that fails for me.
Is there a way to manually apply the Monokrom filter plasma_gcode_preprocessor to a G-code file outside of Monokrom, just to see what the output looks like?
10 months 4 weeks ago #339703
I can't help here. I had a feeling that a linuxcnc filter was a program that accepted an input file and wrote out an output file so you should be able to run the filter stand alone. The file name will be in the ini file. ref:.
linuxcnc.org/docs/html/gui/filter-programs.html
Moderators: KCJ, Lcvette
Time to create page: 1.019 seconds
