MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- htdave
4 years 5 months ago #242842
by htdave
Replied by htdave on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- Thank you received: 4153
4 years 5 months ago #242843
Replied by rodw on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Dave, Its pretty close to working. I think it can be used for production.
Just get master branch installed from source on Debian BUllseye per the instructions on QTPYVCP site
and then install from here
github.com/joco-nz/monokrom-vcp
James and I both got busy....
The following user(s) said Thank You: Joco, CNCFred, htdave, Ashley
- Joco
- Thank you received: 327
4 years 5 months ago #243194
by Joco
Replied by Joco on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
This work is being reviewed and should become part of the official qtpyvcp master in the coming days.
I will announce here when the merge is completed.
Thanks.
Thanks.
The following user(s) said Thank You: tommylight, rodw, htdave
- Joco
4 years 5 months ago - 4 years 5 months ago #243220
by Joco
Pleased to announce that the underlying qtpyvcp work that supports monokrom plasma is now merged into the master code line. This means no need to use my repo to access that work and run the monokrom plasma UI.
It is quite a significant add so if anyone hits a problem I might have missed please raise a bug report so we can track, investigate and fix.
Thanks - James.
Thanks - James.
Last edit: 4 years 5 months ago by Joco.
The following user(s) said Thank You: TurBoss, tommylight, rodw, CNCFred
4 years 5 months ago #243238
Awesome work! Thanks James!!
- aabtech
- Thank you received: 16
3 years 9 months ago #262634
by aabtech
Replied by aabtech on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
It's a good thing but if you can make the UI an advance laser cutter and engraving it will be better because there is no UI that is made for laser cutter and engraving in linuxcnc.
Moderators: KCJ, Lcvette
Time to create page: 0.818 seconds
