MonoKrom - QtPyVCP GUI for PlasmaC and Mill
6 years 1 month ago - 6 years 1 month ago #183236 by pinder
Replied by pinder on topic qtpyvcp Gui for plasmac
KCJ wrote: QtSASS can be used with either QtPyVCP or QtVCP, and would make it extremely easy to customize the colors.
I have seen from past experience, dark base with bright fonts gives better visibilty.
I think integrating color changing will ruin the experience. Users will more frequently try to change colors.
What can be done, there could be a colors.conf file containing three hex color codes for the theme.
It will save theme setting option in UI.
Last edit: 6 years 1 month ago by pinder.
The following user(s) said Thank You: rodw, KCJ
6 years 1 month ago #183237 by phillc54
Replied by phillc54 on topic qtpyvcp Gui for plasmac
pinderkhara wrote: Reverse-run can be a full tab. I can see the usabliity.
Morever, I think thats a good idea to show material selected and some properties. I can make some place for it. I will post.
I think it would be better as a swap between the jog panel. We can't (yet) jog while paused so the jog panel is not required when paused plus it is handy to see the preview when using cut recovery.
The following user(s) said Thank You: tommylight, pinder
6 years 1 month ago #183238 by pinder
Now I get it.
thats a fantastic idea. i can make tabs like in Work offsets
The following user(s) said Thank You: Clive S, rodw, KCJ
6 years 1 month ago #183291 by AgentWD40
Replied by AgentWD40 on topic qtpyvcp Gui for plasmac
pinder wrote:
rodw wrote: Video looks great!
Phil's idea of swapping out the jog panel sounds like a great idea.
The other thing that needs to be displayed is the Plasmac material that is selected.
Somewhere we need to be able to see all the cut parameters for the selected material but maybe they don't have to be on the main screen.
Maybe you could shorten the preview and place the material name, cut height, pierce height, pierce delay and cut speed either above or below the preview on one or two lines. Clicking that line might open a selection window or tab and show the rest of the settings.
I like the idea of at least having the selected material on the main screen, maybe even in a corner of the cut path rendering screen. The rest of the settings could stay on a settings tab to minimize clutter.
The following user(s) said Thank You: rodw, pinder
6 years 1 month ago #183296 by pinder
I am giving some time to thoughts, soon I will share the screen with material info and Reverse run on Halt.
The following user(s) said Thank You: rodw, KCJ, AgentWD40
6 years 1 month ago #183385 by KCJ
Replied by KCJ on topic qtpyvcp Gui for plasmac
Did a little bit of playing with bringing this GUI to life with QtPyVCP.
Really ugly so far, but it's a start.
Cheers,
Kurt
Moderators: KCJ, Lcvette
Time to create page: 0.640 seconds
