MonoKrom - QtPyVCP GUI for PlasmaC and Mill
22 Sep 2020 00:32 #183206 by rodw
Replied by rodw on topic qtpyvcp Gui for plasmac
Is there a way to make the color scheme easily customizable?
I was too polite to ask... :)
The following user(s) said Thank You: KCJ
22 Sep 2020 00:59 #183214 by Himarc3D
Replied by Himarc3D on topic Gui for plasmac
I haven't seen any. Maybe I should do a bit of Googling and have a look at a few...
Hi, Phill.
If you wanna check CNC Panels from big players at market check the simulator (trial) from here:
www.swansc.com/en/download/Software.html
The following user(s) said Thank You: phillc54, pinder
  • pinder
  • pinder's Avatar Topic Author
  • Elite Member
  • Elite Member
22 Sep 2020 02:04 #183227 by pinder
Replied by pinder on topic qtpyvcp Gui for plasmac
Video looks great!
Phil's idea of swapping out the jog panel sounds like a great idea.
The other thing that needs to be displayed is the Plasmac material that is selected.
Somewhere we need to be able to see all the cut parameters for the selected material but maybe they don't have to be on the main screen.
Maybe you could shorten the preview and place the material name, cut height, pierce height, pierce delay and cut speed either above or below the preview on one or two lines. Clicking that line might open a selection window or tab and show the rest of the settings.
Reverse-run can be a full tab. I can see the usabliity.
Morever, I think thats a good idea to show material selected and some properties. I can make some place for it. I will post.
  • pinder
  • Elite Member
  • Elite Member
22 Sep 2020 02:06 #183228 by pinder
Replied by pinder on topic Gui for plasmac
Hi, Phill.
this is interesting
thank you
  • pinder
  • Elite Member
  • Elite Member
22 Sep 2020 02:10 #183229 by pinder
This only uses 3 colors
So changing them would not be any problem
We can do this in settings or whatever.
The following user(s) said Thank You: KCJ, AgentWD40
22 Sep 2020 02:35 #183234 by KCJ
Replied by KCJ on topic qtpyvcp Gui for plasmac
QtSASS can be used with either QtPyVCP or QtVCP, and would make it extremely easy to customize the colors.
  • pinder
  • Elite Member
  • Elite Member
22 Sep 2020 02:51 - 22 Sep 2020 02:55 #183236 by pinder
I have seen from past experience, dark base with bright fonts gives better visibilty.
I think integrating color changing will ruin the experience. Users will more frequently try to change colors.
What can be done, there could be a colors.conf file containing three hex color codes for the theme.
It will save theme setting option in UI.
Last edit: 22 Sep 2020 02:55 by pinder.
The following user(s) said Thank You: rodw, KCJ
22 Sep 2020 02:54 #183237 by phillc54
Replied by phillc54 on topic qtpyvcp Gui for plasmac
I think it would be better as a swap between the jog panel. We can't (yet) jog while paused so the jog panel is not required when paused plus it is handy to see the preview when using cut recovery.
The following user(s) said Thank You: tommylight, pinder
  • pinder
  • Elite Member
  • Elite Member
22 Sep 2020 02:59 #183238 by pinder
Now I get it.
thats a fantastic idea. i can make tabs like in Work offsets
The following user(s) said Thank You: Clive S, rodw, KCJ
22 Sep 2020 12:17 #183291 by AgentWD40
Replied by AgentWD40 on topic qtpyvcp Gui for plasmac
Video looks great!
I like the idea of at least having the selected material on the main screen, maybe even in a corner of the cut path rendering screen. The rest of the settings could stay on a settings tab to minimize clutter.
The following user(s) said Thank You: rodw, pinder
Moderators: KCJLcvette
Time to create page: 0.319 seconds
