MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- phillc54
- Thank you received: 2100
25 Sep 2020 23:07 #183763
by phillc54
Replied by phillc54 on topic QTPYVCP GUI for plasmac
A GUI should never have an Estop button, just an indicator.Oh, how about switching all the yellow to red when estop is active? Speaking of which the gui needs an estop button doesn't it?
The following user(s) said Thank You: KCJ, snowgoer540, pinder
- pinder
- Thank you received: 128
26 Sep 2020 02:10 #183770
by pinder
Replied by pinder on topic qtpyvcp Gui for plasmac
I was also suggesting this.
What I meant to ask what's the smallest physical screen size that's comfortable to use?
I also think 15" should be nice. I recently purchased an Asus VT168H 15" touch screen which is nice. Native resolution is 1366 x 768. Only issue is its a capacitive screen so not usable with work gloves. It is very nice size mounted in an enclosure with an Odroid H2+
See www.asus.com/au/Monitors/VT168H/
Thats my plan for this when you guys are done..
- AgentWD40
- Thank you received: 96
26 Sep 2020 02:10 - 26 Sep 2020 02:14 #183771
by AgentWD40
Replied by AgentWD40 on topic QTPYVCP GUI for plasmac
But don't both axis and gmoccapy have an estop button? ... now I'm confused
Anyway, turning the screen red or otherwise indicating disabled when estop is active might be useful.
Last edit: 26 Sep 2020 02:14 by AgentWD40.
- pinder
26 Sep 2020 02:14 #183772
by pinder
It should remember last location.
But Still for myself I will try to stick with USB or network drive
So It is decided.I don't think I have ever opened a gcode file from USB
- phillc54
26 Sep 2020 02:14 #183774
by phillc54
The "Estop" on a GUI should really only be an indicator to display the fact that a real Estop has occurred. At worst it could possibly be part of the Estop reset chain.
An Estop button should be exactly that, a hardware button that renders the machine safe. Estop should not rely on a soft button.But don't both axis and gmiccapy have an estop button? ... now I'm confused
The following user(s) said Thank You: KCJ, AgentWD40, snowgoer540, pinder
- pinder
26 Sep 2020 02:16 #183775
by pinder
In emergency, no one should run for a Mouse or touchpad.
Physical ESTOP is the way to go.
There can be a indicator for Estop on GUI.
Replied by pinder on topic QTPYVCP GUI for plasmac
The following user(s) said Thank You: phillc54, KCJ
- phillc54
26 Sep 2020 02:16 #183776
by phillc54
Replied by phillc54 on topic qtpyvcp Gui for plasmac
That would be good. I really like the simple clean look of your GUI. Do you mind it I replicate it?
- phillc54
26 Sep 2020 02:17 #183777
by phillc54
+1
- pinder
26 Sep 2020 02:20 #183778
by pinder
Its must stay open-source.
Cheers,
Pinder
It would be a pleasure.That would be good. I really like the simple clean look of your GUI. Do you mind it I replicate it?
Cheers,
Pinder
- phillc54
26 Sep 2020 02:22 #183779
by phillc54
Thank you, I appreciate it.
Absolutely, everything I do is open-source.Its must stay open-source.
The following user(s) said Thank You: Clive S, pinder
Moderators: KCJ, Lcvette
Time to create page: 1.926 seconds
