MonoKrom - QtPyVCP GUI for PlasmaC and Mill
6 years 1 month ago #183188 by rodw
Replied by rodw on topic qtpyvcp Gui for plasmac
Really nice. Couple of things.
1. I think it needs a torch enable button. I use that a lot.
2. Consider separating cycle start from machine power to avoid unintentional triggers.
I really like the touch friendly flat interface, no annoying tabs like Gmoccappy has.
The following user(s) said Thank You: KCJ, pinder
6 years 1 month ago #183194 by pinder
Replied by pinder on topic Gui for plasmac
Thanks @rodw
1) I liked your idea, so I changed that.
2) For the moment we will have to sacrifice reverse-run. How much reverse-run is important?
The following user(s) said Thank You: rodw, KCJ
6 years 1 month ago #183195 by pinder
I have modified it as per suggestions. Made a little animation., hope you all like it.
checkout the video
The following user(s) said Thank You: KCJ, Himarc3D
6 years 1 month ago #183200 by phillc54
Replied by phillc54 on topic Gui for plasmac
pinderkhara wrote: Thanks @rodw
Reverse Run is only useable while paused so you could swap out the jog panel with a reverse run panel when a job is paused or you could make it a cut recovery panel with these functions:
Warning: Spoiler!
The following user(s) said Thank You: pinder
6 years 1 month ago #183202 by rodw
Video looks great!
Phil's idea of swapping out the jog panel sounds like a great idea.
The other thing that needs to be displayed is the Plasmac material that is selected.
Somewhere we need to be able to see all the cut parameters for the selected material but maybe they don't have to be on the main screen.
Maybe you could shorten the preview and place the material name, cut height, pierce height, pierce delay and cut speed either above or below the preview on one or two lines. Clicking that line might open a selection window or tab and show the rest of the settings.
6 years 1 month ago #183203 by AgentWD40
Replied by AgentWD40 on topic qtpyvcp Gui for plasmac
Is there a way to make the color scheme easily customizable?
Moderators: KCJ, Lcvette
Time to create page: 0.589 seconds
