Qtpyvcp has no Linux CNC components
19 Oct 2021 12:44 - 19 Oct 2021 13:42 #223581 by Joco
The error suggests either the designer plugin has not been copied across per developer install instructions or a non supported OS is being used.
Or if using a RIP install the LinuxCNC rip-environment script has not been run and/or you are not starting designer from a cli with those paths setup.
Last edit: 19 Oct 2021 13:42 by Joco. Reason: Extra idea.
19 Oct 2021 19:47 #223610 by yi2580
Replied by yi2580 on topic There is no linuxcnc component in qtpyvcp
I am using Ubuntu 18.04 system, running the Linux CNC rip environment script and the designer started from the script window started by the terminal. I don't know what my fault is now. I don't have these plug-ins. I hope I can get your help.
Thank you very much
19 Oct 2021 20:51 - 19 Oct 2021 20:53 #223614 by Joco
You followed these steps?
www.qtpyvcp.com/install/dev_install.html#qtdesigner-plugins
You also run this script from the terminal you are launching qtdesigner from before launching the designer?
<your linuxcnc rip install dir>/scripts/rip-environment
Note you need to run this in a special way either of (assuming you have cd'd into the scripts directory):
. ./rip-environment
or
source ./rip-environment
then run:
editvcp <name of ui to edit or path to UI's config.yaml>
Also, assume you have found:
www.qtpyvcp.com/tutorials/index.html
Last edit: 19 Oct 2021 20:53 by Joco.
19 Oct 2021 22:22 #223624 by yi2580
Yes, I did it according to the tutorial. I understand what you mean. I have started and executed the Linux CNC environment, but there is no Linux CNC control. I don't know why I don't have this control
Thank you for your answer
20 Oct 2021 00:10 #223629 by yi2580
I also implemented the Linux CNC startup environment
. ./rip-environment
or
then run:
You may not understand my problem. I now open qtpyvcp without a Linux CNC control. Then I think the control of linuxcnc is not loaded. Please see if my picture library is not loaded. How should I load this library?
Thank you for your reply
20 Oct 2021 00:14 #223630 by Joco
I looked again at the screen shot, that so is for python3.  And the error is complaining about not finding a supporting python3 libraray.  Have you installed the necessary python3 dependencies?
It is wanting libpython3.5
howtoinstall.co/en/libpython3.5
20 Oct 2021 01:13 #223633 by yi2580
I didn't find the libpython 3.5 library. I tried his installation command, but the installation failed. I don't know why
20 Oct 2021 02:47 #223637 by Joco
If you are looking to develop with qtpyvcp I would recommend you use a Debian distro (10 or 11) and not Ubuntu. If nothing else that removes a set of potential questions.
Given the shift to python3 Debian 11 (Bullseye) is an easy choice. Especially if you are already comfortable in using a rip linuxcnc install.
I have setup debian 11 following the developer instructions and things "just worked".
Cheers - J.
20 Oct 2021 04:21 - 20 Oct 2021 04:41 #223644 by yi2580
Replied by yi2580 on topic Qtpyvcp has no Linux CNC components
 I used to use glade-3 to build the interface, but I don't think glade-3 is very good-looking, so I want to use qtpyvcp to build the interface. But now there is an error. It doesn't have Linux CNC components. I use this tutorial This is the tutorial I use
I don't know where I'm wrong,I think it may be related to these two mistakes.The first one I think is that the plug-in is not loaded. The second one is that there is no qtpy function library when starting editvcp. I attached the picture below. I hope you can help me further and make my UI more cool. Thank you here
Last edit: 20 Oct 2021 04:41 by yi2580.
Moderators: KCJ, Lcvette
Time to create page: 0.135 seconds
