Qtpyvcp has no Linux CNC components
21 Oct 2021 03:33 #223796 by Joco
Replied by Joco on topic Qtpyvcp has no Linux CNC components
Also remember that linuxcnc rip requires pthyon >= 3.7  and that needs to be set as the default python.
And qtpyvcp master needs a working python3 linuxcnc.
Ubuntu 18.04  gives you python 3.6.
21 Oct 2021 19:56 #223862 by yi2580
Replied by yi2580 on topic Qtpyvcp has no Linux CNC components
Yes, the python compiler I use now is Python 3.6. Do I need to upgrade it to a higher version? I also installed Python 3.5, but I set Python 3.6 as the default compiler for Python
Thank you for your comments
21 Oct 2021 21:20 #223869 by Joco
you need to have python 3.7 or higher and you will need to have compiled linuxcnc after you have installed the correct python 3.7+ dependencies.
Moderators: KCJ, Lcvette
Time to create page: 0.146 seconds
