Something is broken somewhere..... missing dependency....???
It was working yesterday (on another build)..... clean slate today and I can't get probe basic or robe basic lathe to load..... everything else (axis, gmoccapy, QtPlasmaC) load just fine....
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/rob/linuxcnc/configs/probe_basic'
Machine configuration file is 'probe_basic.ini'
Starting LinuxCNC...
File: tool.tbl Unrecognized line skipped:
;Tool Pocket Z Offset Diameter Remark
Note: Using POSIX non-realtime
twopass:invoked with <> options
twopass:found ./hallib/core_sim_5.hal
twopass:found ./hallib/spindle_sim.hal
twopass:found ./hallib/simulated_home_probe_basic.hal
twopass:found ./hallib/sim_cannon.hal
motion.c: Creating unlock hal pins for joint 4
link (updating variable file): No such file or directory
[qtpyvcp][INFO] Logging to /home/rob/linuxcnc/configs/probe_basic/sim.log (logger.py:97)
[qtpyvcp][INFO] QtPyVCP Version: python3_master+174.g2c249709 (opt_parser.py:207)
[qtpyvcp][DEBUG] Qt Version: 5.15.2 (opt_parser.py:211)
[qtpyvcp][DEBUG] Qt API: QT_API (opt_parser.py:212)
[qtpyvcp][DEBUG] QtPy Version: 2.0.1 (opt_parser.py:213)
[qtpyvcp][DEBUG] Command line options:
"command_line_args": null,
"config_file": "/home/rob/linuxcnc/configs/probe_basic/custom_config.yml",
"confirm_exit": false,
"develop": false,
"fullscreen": null,
"help": false,
"hide_cursor": false,
"hide_menu_bar": false,
"hide_status_bar": false,
"info": false,
"ini": "/home/rob/linuxcnc/configs/probe_basic/probe_basic.ini",
"log_file": "/home/rob/linuxcnc/configs/probe_basic/sim.log",
"log_level": "DEBUG",
"maximize": null,
"perfmon": false,
"position": "0x0",
"qt_api": null,
"size": null,
"stylesheet": null,
"theme": null,
"version": false
} (opt_parser.py:216)
File "/home/rob/.local/bin/probe_basic", line 33, in <module>
sys.exit(load_entry_point('probe-basic', 'gui_scripts', 'probe_basic')())
File "/home/rob/dev/probe_basic/probe_basic/__init__.py", line 20, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/home/rob/dev/qtpyvcp/qtpyvcp/__init__.py", line 27, in run_vcp
run(*args, **kwargs)
File "/home/rob/dev/qtpyvcp/qtpyvcp/app/__init__.py", line 125, in run
from qtpyvcp.utilities.config_loader import load_config_files
File "/home/rob/dev/qtpyvcp/qtpyvcp/utilities/config_loader.py", line 3, in <module>
import hiyapyco
File "/home/rob/.local/lib/python3.9/site-packages/hiyapyco/__init__.py", line 30, in <module>
from jinja2 import Environment, Undefined, DebugUndefined, StrictUndefined, TemplateError
File "/home/rob/.local/lib/python3.9/site-packages/jinja2/__init__.py", line 12, in <module>
from .environment import Environment
File "/home/rob/.local/lib/python3.9/site-packages/jinja2/environment.py", line 25, in <module>
from .defaults import BLOCK_END_STRING
File "/home/rob/.local/lib/python3.9/site-packages/jinja2/defaults.py", line 3, in <module>
from .filters import FILTERS as DEFAULT_FILTERS # noqa: F401
File "/home/rob/.local/lib/python3.9/site-packages/jinja2/filters.py", line 13, in <module>
from markupsafe import soft_unicode
ImportError: cannot import name 'soft_unicode' from 'markupsafe' (/home/rob/.local/lib/python3.9/site-packages/markupsafe/__init__.py)
task: 200 cycles, min=0.000065, max=0.032832, avg=0.009062, 0 latency excursions (> 10x expected cycle time of 0.010000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/rob/linuxcnc_debug.txt
and
/home/rob/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
