Probe_Basic Install
4 years 7 months ago #236481 by jkkicks
Replied by jkkicks on topic Probe_Basic Install
Okay great thanks so much for all your input! I ended up sorting out the wifi issues tonight and I think the hal and ini are sorted for now. Waiting on a mouser order to come in with some hardware to get it plugged and tested. Still need to do the ball screw conversion on the mill.
Do the hal and ini look better?
File Name: test5_2022-03-06.hal
File Size:10.09 KB
File Name: test5_2022-03-06.ini
File Size:5.59 KB
4 years 7 months ago #236482 by Lcvette
Replied by Lcvette on topic Probe_Basic Install
looks better, is probe basic opening now?
if so what is on the status page? trying to determine which version of probe basic you have installed and if it is the latest master or a previous tagged version, it will determine if the post gui hal file is correct.
4 years 7 months ago #236483 by jkkicks
Yes sir everything is working okay. Even before those hal and ini file fixes it was working. A screenshot of the status window is linked below. Ive even got it running the steppers using the conversational window. Having a latency error come up so thats next step getting it working reliably. Even after the issue the gcode continues to run just fine. Project for tomorrow me.
4 years 7 months ago - 4 years 7 months ago #236484 by Lcvette
Ok so you need to change the post gui hal file call in the ini to match what is in the configuration folder for probe basic, i think it's probe basic post gui hal, but check the sim folder and make sure it's in your current configuration.  It's for the latest version which appears you have installed.
Last edit: 4 years 7 months ago by Lcvette.
4 years 7 months ago #236486 by jkkicks
Okay yes i found it and copied it into my test config. its called "probe_basic_postgui.hal" ill call it in the [HAL] of ini. Should I add another line like "HALFILE = probe_basic_postgui.hal" or edit "POSTGUI_HALFILE"?
When setting up there was no time.hal in my install so i grabbed it from github.
currently looks like:
HALFILE = custom.hal
SHUTDOWN = shutdown.hal
HALUI = halui
HALFILE = test5.hal
POSTGUI_HALFILE = time.hal
4 years 7 months ago #236487 by Lcvette
Replace time.hal with the other, the time. Hal is now integrated into the probe basic post gui file
Moderators: KCJ, Lcvette
