qtpyvcp - widget rules editor missing
- spumco
- Thank you received: 905
28 Oct 2022 18:33 #255323
by spumco
Replied by spumco on topic qtpyvcp - widget rules editor missing
I un-gave up.
OMG. I've been using the wrong Debian ISO file. It's finally reading the USB...we'll see how this goes.
- Thank you received: 4149
28 Oct 2022 20:53 #255335
Replied by rodw on topic qtpyvcp - widget rules editor missing
Yes, Joco assumes a Debian Bullseye build. A lot of the Python 3 stuff requires Debian 5.10 and above.I un-gave up.
- spumco
28 Oct 2022 21:21 #255339
by spumco
So it's working. Deb12, lcnc, qtpyvcp are all installed. Many dependencies not met, had to go back and forth enabling/disabling the bookworm & bullseye repositories.
Couldn't use Deb11 as it hosed up my display to 800x600.
I can now see widget rules for the first time. QtDesigner won't open except through terminal, but this is a significant improvement.
LOL... it was worse than that. I was using the i386 iso.
I un-gave up.
- Thank you received: 7476
28 Oct 2022 21:40 #255341
Now it is to late, but still:
No you do not!
Giving up never fixes anything!
Replied by tommylight on topic qtpyvcp - widget rules editor missing
I read this while i was having a coffee with some friends, so i could not reply.I give up.
No you do not!
- Lcvette
- Thank you received: 782
29 Oct 2022 16:33 #255394
by Lcvette
Replied by Lcvette on topic qtpyvcp - widget rules editor missing
I have not had that issue with the display, are you sure you are using the correct ISO now? installing it correctly with install settings? bios settings? I have done this probably 20-30 times on various PC's and have not had these issues you keep finding. you are either exponentially better than me at bug finding or have had some rotten luck... /o\
- spumco
30 Oct 2022 02:54 #255419
by spumco
I'm using the correct ISO now. It's an intel x86 platform, why would I have chosen an ISO with 'amd' in the name?
The RT kernel used with Deb11 didn't have video drivers for the chipset, so I had to switch to Deb12 non-free. The OS installation is fine, have a newer RT kernel that has video drivers.
The two PC's I'm using are an Odroid H2+ (machine) and Mele Quieter3q (testing). Both have had issues causing me no end of headaches. The Odroid's ethernet port drivers weren't included in Deb10 when I first got started last year so I was forced to use Mint or MX on that one. And the Quieter3 appears to be new enough that I need Deb12 (or Mint21).
Every time I tried to fix something, I made it worse. Being impatient and totally linux-dumb, I probably caused more problems than the hardware.
I'm just used to Windows. Dependencies, terminal gibberish, and the whole software installation process are all foreign to me. Based on my experiences with Linux, Windows just works. With Win10-LTSC there's no issues, no spam, no non-security updates, no bugs. Windows hasn't become a hobby.
I know, I know... once it's set up and functioning, Linux is stable and Windows aint...
I did set up another PC with MX21 to run Kipper directly to my printer - that was super-easy. But the process of setting up Linux, LCNC, and the other related software has been a nightmare.
- spumco
30 Oct 2022 03:00 #255420
by spumco
But all the other CNC options have issues, too. Every time I'm thinking F-this, I'll get an Acorn... I realize the only way to spend my way out of this Linux nightmare is with REAL money. And I don't have $25k for a turn-key Siemens or $8k for a GSK controller.
You have no idea how close I've been in the past year to sending Centroid or someone else a wad of cash. I've got a UCCNC board & license in a drawer - I can end the Linux pain when it gets too bad.
I give up.
No you do not!
Moderators: KCJ, Lcvette
