User Install for Probe Basic Py3 (For Machine Control)
  • Lcvette
  • Lcvette's Avatar Topic Author
  • Moderator
  • Moderator
05 Mar 2023 03:52 #265897 by Lcvette
I will take a look in a bit when I'm at dev again, I noticed a few dependencies listed in the terminal were called in the build package,  there may be a version issue going on with it not building into the package.   Learning curve for me.. /o\
05 Mar 2023 11:20 #265906 by rodw
Sounds like it might.
Assuming a deb install, as an outside chance run this script:
/usr/lib/python3/dist-packages/qtvcp/designer/install_script
This is for QTVCP but it shares a lot of dependencies with QTPYVCP.
  • Lcvette
  • Moderator
  • Moderator
06 Mar 2023 16:59 - 06 Mar 2023 17:00 #265962 by Lcvette
i just tried the alpha 2 iso and it installs the non free firmware by default now this is the unedited apt source list file from the base installation:
Last edit: 06 Mar 2023 17:00 by Lcvette.
  • Lcvette
  • Moderator
  • Moderator
06 Mar 2023 18:27 #265964 by Lcvette
Updated install files
3/6/23 1:26pm EST
06 Mar 2023 23:25 #265986 by nwallace
I can confirm that the new packages and instructions work on a fresh install of Debian 12. The only thing that I noticed is that the "sudo apt --fix-broken install" step after the python3_probe_basic package install will fail if you haven't already started LinuxCNC and copied an existing config to your home directory which creates the /home/user/linuxcnc/configs/ folder. You could also create those folders manually. Re-running the command after creating the folders works. I will edit my first post to not confuse new readers.
The following user(s) said Thank You: Lcvette
  • Lcvette
  • Moderator
  • Moderator
07 Mar 2023 00:31 #265998 by Lcvette
no need will add to the readme doc and yes i forgot about that
downside of working on an unclean system that had linuxcnc installed already and opened. I may be able to create the directory in the postinst script, I will try and see if it does it!
The following user(s) said Thank You: nwallace
07 Mar 2023 02:57 #266010 by nwallace
I have noticed that the carousel images are not loading. Anything I should check?
  • Lcvette
  • Moderator
  • Moderator
07 Mar 2023 03:25 #266012 by Lcvette
hmmm, let me check on that, i am just loading a clean installation of debian and going to test the debs to try and see if anything else popped up missing, will report back shortly.
  • Lcvette
  • Moderator
  • Moderator
07 Mar 2023 06:41 #266015 by Lcvette
confirmed, somewhere while fixing the sims folder issue the atc widget broke.. will get that found and fixed in the morning with some luck.  thanks for pointing it out!
The following user(s) said Thank You: tommylight, nwallace
07 Mar 2023 12:20 #266022 by KCJ
I wonder if the resources aren’t being compiled so the ATC images are not able to be loaded.
Moderators: KCJLcvette
Time to create page: 0.145 seconds
