- User Interfaces
- Other User Interfaces
- QtPyVCP
- User Install for Probe Basic Py3 (For Machine Control)
- ihavenofish
- Thank you received: 287
29 Apr 2023 17:29 #270251
by ihavenofish
Replied by ihavenofish on topic User Install for Probe Basic Py3 (For Machine Control)
I did that as per rodw's instructions yes.
There was another gui related option i left default. But i see online perhaps it should have been the other one. Can't remember what it was now.
- Lcvette
- Thank you received: 784
29 Apr 2023 17:34 #270252
by Lcvette
Replied by Lcvette on topic User Install for Probe Basic Py3 (For Machine Control)
the only change is uncheck gnome and check xfce4, no other changes!
- ihavenofish
29 Apr 2023 17:43 #270253
by ihavenofish
k. well, then what went wrong.
The only other notable screw up i had was after installing linuxcnc, I lost sudo privileges from my account and switched to root. Realised that does not work, figured out how to reinstate sudo, then continued.
Would that break something? Put something in the wrong spot?
- Lcvette
29 Apr 2023 17:51 #270256
by Lcvette
yes, when installing linuxcnc leave root password blank, then first time you run sudo apt update it will ask you to set the root password. this is used during the installation.
- ihavenofish
29 Apr 2023 17:57 #270257
by ihavenofish
ok, im going to install in a few mins.
The following user(s) said Thank You: Lcvette
- Lcvette
29 Apr 2023 18:17 #270261
by Lcvette
cool, keep us posted
- ihavenofish
29 Apr 2023 18:35 #270263
by ihavenofish
Curious. i now have a completely different linux gui - similar to the older linuxcnc one. clearly i pressed something wrong last time.
My brain hurts. haha.
- Lcvette
29 Apr 2023 18:42 #270264
by Lcvette
You must not have been on xfce4 which likely accounts for the error, it looks like that because that was preset in linuxcnc distros
- ihavenofish
29 Apr 2023 19:08 #270267
by ihavenofish
wooo
seems to have worked. in addition t the ui, i think something was wrong with python last time. this time it gave me an error and told me to fix instal. after that it took a while to do various things, which it definitely didnt do before.
So the next thing is the config. am i right in that other pinned post is the instructions (something about merging the sim into the pncconf generated config?
- Lcvette
29 Apr 2023 19:24 #270269
by Lcvette
read thoroughly the instructions here:
forum.linuxcnc.org/qtpyvcp/48401-configu...-for-probe-basic-py3
when you get to the ini file be sure you understand what is in that link for the ini is NOT all that is needed, it must be integrated into your newly spit out axis ini file.
once you get it all copied over it should startup and run on your machine .
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
Time to create page: 0.103 seconds
