Probe_basic Toolchanger
3 years 6 months ago #268041 by tommylight
Replied by tommylight on topic Probe_basic Toolchanger
Mesa 7i76E has two more IDC26 headers, each of those have 17 IO pins that can do high speed stepgen, encoder, PWM, etc.
Use those if they are free.
3 years 6 months ago #268042 by spumco
Replied by spumco on topic Probe_basic Toolchanger
 test the carousel component with real hardware, and i have plenty of hardware so i can do stepper/position driven, DC motor driven, or whatever might be a good idea to try, also have a big box of sensors in all types and shapes.
Tommy,
The stock Probe Basic control scheme doesn't use carousel.comp.  All platter movement is controlled in the ngc files using parameters and motion.digital-out (or in) and motion.analog-out for the pocket number command.
My modified version of PB does use carousel.comp because I'm using a stepper in position mode - no geneva wheel - and I didn't want to treat the ATC as an axis.  Andy Pugh modified carousel.comp to send position-mode pulses to a stepper dive rather than treating the stepper as a velocity-mode 'dumb' motor.
The experimental version of carousel still needs some work (jogging doesn't work), but it's driving my ATC now.
3 years 6 months ago #268044 by tommylight
Yup, i followed the development there, and that is the main reason i started thinking about making a TC.
3 years 6 months ago #268047 by spumco
I've collected every ATC example I can find on the forum and github. Rack, ATC-as-axis, carousel.comp, Classic Ladder, etc.
I don't have a double-arm ATC, nor do I have an example using an external controller (arduino, PLC, robot arm).  And I'm limited in my knowledge of programming GUI's to interface with ATC's.
When you're ready I'll be happy to help - it's the least I can do to reciprocate.
3 years 6 months ago #268049 by spumco
What isolation - if any - would be used/needed for those IDC26 headers?  I've come across threads where PCW has mentioned using those pins, but I cant remember what the best way to physically hook them up to a drive (or other component for I/O).
3 years 6 months ago - 3 years 6 months ago #268059 by CNC_ANDI
Replied by CNC_ANDI on topic Probe_basic Toolchanger
ok im thinking about that for one night....
so i think i will order a second Mesacard....
what do you say is the best doughtercard for my mesa 7i76e?
7i76 or 7i85s or 7i78
7i78 only have 4 more STEP/DIR Ports and 1 rs422
7i85s does have 4 More Axis, 1x Smartserial, 4x Encoder
or 7i76 for 4 more axis, 32inputs, 16 outputs, 1x rs422, 1x encoder
i think i will order the 7i76
7i76E+7i76
a homing sensor is already placed on my TC prototyp
Last edit: 3 years 6 months ago by CNC_ANDI.
Moderators: KCJ, Lcvette
Time to create page: 0.178 seconds
