Probe_basic Toolchanger
3 years 6 months ago #268094 by Lcvette
Replied by Lcvette on topic Probe_basic Toolchanger
Well done in the explanation!
Given the added cost he's now looking at,  why not just incorporate a Geneva mechanism.. seems like it would cost much less and be simple.   Not sure why you give them the Heisman..lol image missing /media/kunena/emoticons/laughing.png
Anyhow,  that would be my recommendation since he has no available stepgen readily available.  One disk,  one drive pin and then use a stepper with fwd rev speed pot setting board and home and index pulse on the platter.. easy peasy, control with simple io pins for fwd reverese.
3 years 6 months ago #268098 by CNC_ANDI
Replied by CNC_ANDI on topic Probe_basic Toolchanger
??? ääämmm what??? now i´m really conufsed... i don´t know what i have to doing now?
3 years 6 months ago #268099 by Lcvette
Geneva drive only requires simple io to control
3 years 6 months ago #268104 by spumco
Replied by spumco on topic Probe_basic Toolchanger
CNC_ANDI,
Remember earlier when I mentioned a geneva wheel is simpler to control, but more complex to fabricate?
And also that the 'stock' verison of PB's control scheme is based on a geneva wheel?
Lcvette is one of the Probe Basic devs and wrote the PB toolchange logic.  He was suggesting that you use a geneva wheel mechanism as the software configuration is easier than with a position-mode stepper or servo.
I do not know your fabrication skills or available tools.  If you are capable of fabricating a geneva wheel then you might give some consideration to @Lcvette's suggestion.
If you are not capable of fabricating a geneva wheel, then it's a moot point and you need to pursue a position-mode stepper system for the ATC.
Lcvette,
I know, we've been through the geneva vs. position-stepper before.  You're absolutely right in that if somebody has a geneva mechanism your PB scheme is damn near plug-and-play with just a few IO.
But not everyone can build a geneva mechanism that is reliable, or wants to go through a number of iterations (is it too small/weak? too big? how much motor power do I need? etc.) to get one sorted out.
For those folks, myself included, I've pursued a position-mode stepper/servo option.  Requires more fiddling with the control scheme than yours, but really isn't difficult to let carousel.comp do the heavy lifting to position the platter.
Like everything in  LCNC, it comes down to choices: do you want to spend more time on the mechanical side, or more time on the software?
-R
3 years 6 months ago #268105 by Lcvette
In otherwords, you have some options,  if you are open to redesigning some of the atc to use a Geneva drive,  you no longer need a stepgen. You can control the platter drive motor with general purpose output pins.
3 years 6 months ago #268107 by Lcvette
With 3d printers,  trial and error is pretty painless and cheap.
Moderators: KCJ, Lcvette
Time to create page: 0.167 seconds
