Probe_basic Toolchanger
2 years 11 months ago #285978 by dpslwk
Replied by dpslwk on topic Probe_basic Toolchanger
you may need to add some lines to your [RS274NGC] PARAMETER_FILE
either add lines for
5170 > 5171
5190 > 5209
5231
or copy over the sim.var or vmc.var from the sample configs to what ever you have the file names, but note this would override a bunch of you current numbered params
They current routines and the above only support a 12 pocket changer I have an open PR that supports changes up to 24 pockets, it requires adding params #3990 to #4024 instead of the above
2 years 11 months ago #285992 by CNC_ANDI
Replied by CNC_ANDI on topic Probe_basic Toolchanger
Ok thank you i will check this.
At the moment i only have a 8 pocket Changer.
Wich params will it be override?
2 years 11 months ago - 2 years 11 months ago #286055 by dpslwk
if you overwrite the file then anything listed in here as persistent
linuxcnc.org/docs/html/gcode/overview.ht...:numbered-parameters
mainly
G28, G30, G54-59.4 and more
Last edit: 2 years 11 months ago by dpslwk.
2 years 11 months ago #286075 by CNC_ANDI
can´t find any other params in sim.var from basic..... only the same params where my var.....
2 years 11 months ago #286085 by dpslwk
are you referencing your changer first, as that routine not only homes the carousel but repopulates the UI
the bundled subroutines store which pocket holds which tool in the variables
5191>5202
The following user(s) said Thank You: CNC_ANDI
2 years 11 months ago #286112 by CNCaddict.1970
Please share your var file and your current toolchange.ngc. let's see if you have the correct variables set so it saves the tools.
As a recent coming change is happening for the parameters used in toolchange.ngc, we need to see which toolchange.ngc you are using. Based on that you will have to add some variables to linuxcnc.var file. So it has a place to store your tools.
It's actually really not difficult. It's the understanding what needs to be set to work that can be hard :)
Moderators: KCJ, Lcvette
Time to create page: 0.066 seconds
