Probe_Basic ATC Tool List
2 years 10 months ago #287640 by CNC_ANDI
Replied by CNC_ANDI on topic Probe_Basic ATC Tool List
Ok i will try it....
2 years 10 months ago #287648 by CNC_ANDI
ok this lines will work with debian bullseye too.
i´ve updated probe_basic...
but my tool list won´t work. what i have to do now?
2 years 10 months ago #287657 by Lcvette
Replied by Lcvette on topic Probe_Basic ATC Tool List
Install Debian 12
2 years 10 months ago #287660 by dpslwk
Replied by dpslwk on topic Probe_Basic ATC Tool List
Once you have update to the latest probe_basic apt install you should have the latest ui
the new "Program Tools" tab (under ATC) should look something like this when no program is loaded
when you load a program it should populate with a list of T numbers
if your not seeing the above, your update may not have work, or you have not told us that your running some thing more than just an apt install (dev? custom ui changes? etc)
 more info you give in a in a post the more someone can help
2 years 10 months ago - 2 years 10 months ago #287669 by CNC_ANDI
i mean i use the dev install of probe_basic...
so i have tried with install the new deb files manually.
i see the files like the ini or postgui file in probe_basic sim folder was changed to an other version...
but the ui is still the same.
apt update tells me all files are up to date
Last edit: 2 years 10 months ago by CNC_ANDI.
2 years 10 months ago #287670 by Lcvette
dev install is not on apt, you would need to run the update script from the qtpyvcp bookworm installer to receive the latest files required for the latest main branch to function correctly. apt is for updating machine installations and is saving to a completely different directory.
Moderators: KCJ, Lcvette
Time to create page: 0.356 seconds
