Probe_Basic ATC Tool List
2 years 10 months ago #287717 by Lcvette
Replied by Lcvette on topic Probe_Basic ATC Tool List
did you reset the probing and tool setter parameters for your machine?
2 years 10 months ago - 2 years 10 months ago #287750 by CNC_ANDI
Replied by CNC_ANDI on topic Probe_Basic ATC Tool List
All the values was already at zero... i changed it to my values like the values before (from my other working pc).
But get always this failure when i load a program.
by the way have found a bug in the probe_basic.ui
the bug is in the atc page....
on the left side you have too buttons with atc fwd and atc rev
and on the right side you have it too...
but one side of this buttons works wrong
maybe you have to rename it or switch the ngc files
Last edit: 2 years 10 months ago by CNC_ANDI.
2 years 10 months ago #287763 by Lcvette
Bug report: Thank you for that catch! you are correct, the buttons were inverted, I have corrected and the fix will go out in the next update I am working on! thank you for reporting that!
can you load the program on the atc sim? need to sort if its in the file, config or ui edits.
The following user(s) said Thank You: tommylight, CNC_ANDI
2 years 10 months ago - 2 years 10 months ago #287782 by CNC_ANDI
you are welcome!
ok got it now work on a normal debian 12 apt installation...
so please can you tell me how i can install editvcp to edit the probe_basic.ui?
any chance to do this?
i would do little changes....
axis display... i only need xyzb
rename some buttons or give it a other ngc file...
2 years 10 months ago #287786 by Lcvette
that is set in the ini file based on your configuration for joints and axes, if you open the atc sim you will notice that only displays 3 axis, its all automated but requires a properly setup config file
2 years 10 months ago - 2 years 10 months ago #287790 by CNC_ANDI
i have 6 joints
XYYZBC
but C is actualy my toolchanger...
and probe basic gives me a XYZAB Display
but i would do other changes too.
Moderators: KCJ, Lcvette
Time to create page: 0.131 seconds
