Probe_Basic ATC Tool List
2 years 10 months ago #288226 by CNC_ANDI
Replied by CNC_ANDI on topic Probe_Basic ATC Tool List
it works with m300 and M500 now too.
i think the problem does have a other reason. but i don´t know what was the reason....
need this module geedit or other editor set in the ini file?
2 years 10 months ago #288278 by Connor9220
Heya, Connor here, aka Knox Machining (YouTube), also Billy.
Ha.. Anyway..
Here is a link to my custom_probebasic.py file doing label changes
github.com/KnoxMakers/AvidCNC/blob/main/...custom_probebasic.py
You'll also need to update your custom_config.yml file
github.com/KnoxMakers/AvidCNC/blob/main/...be/custom_config.yml
adding provider: custom_probebasic:CustomProbeBasic under windows:
mainwindow:
My config is for a AVID CNC, which has 4 joints, but only 3 axis at the moment. XYYZ, But are seen as XYZ. You should be able to do a editvcp probe_basic and bring up the GUI so you can find the label names. Or check out /usr/lib/python3/dist-packages/probe_basic/probe_basic.ui
Be careful, you'll find multiple things labeled the same, for 3, 4 or 5 axis configurations are in the file.
Hope this helps!
2 years 10 months ago #288333 by CNC_ANDI
my question was how can i edit my probe_basic gui on the normal APT debain 12 bookworm install without a developement install
2 years 10 months ago #288491 by CNC_ANDI
ok found the bug why my list does not work everytime....
when i have a G0 B0. in my Gcode the list won´t work correctly...
when i delete the G0 B0. in my Gcode then the list works!
2 years 10 months ago #288494 by Connor9220
What do you have in your ini for the following
[KINS]
KINEMATICS =
[TRAJ]
COORDINATES =
[DISPLAY]
GEOMETRY =
2 years 10 months ago #288508 by CNC_ANDI
[KINS]
KINEMATICS =
[TRAJ]
COORDINATES =
[DISPLAY]
GEOMETRY =
[DISPLAY]
GEOMETRY = !BXYZC
[TRAJ]
AXES = 6
COORDINATES = X Y Y Z B C
KINEMATICS = trivkins coordinates=XYYZBC
JOINTS = 6
Moderators: KCJ, Lcvette
Time to create page: 0.096 seconds
