Probe_Basic ATC Tool List
2 years 10 months ago #288510 by Connor9220
Do you not need kinstype=BOTH to support the Y Y setup?
I have a XYYZ and this is my settings.
[DISPLAY]
GEOMETRY = xyz
[TRAJ]
COORDINATES = XYYZ
[KINS]
KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH
JOINTS = 4
Also, I looked at the docs, I don't see anything about the ! on the GEOMETRY line, not sure what that is. I did read the "-" sign preceding the axis letter, that inverts the sense of rotation.
2 years 10 months ago #288578 by CNC_ANDI
Replied by CNC_ANDI on topic Probe_Basic ATC Tool List
I will check this.
2 years 10 months ago #288703 by CNC_ANDI
have tried this:
[DISPLAY]
GEOMETRY = bxyz
[TRAJ]
COORDINATES = XYYZB
[KINS]
KINEMATICS = trivkins coordinates=XYYZBC kinstype=BOTH
works... but probe_basic shows me XYZA in the DRO
with COORDINATES = XYYZBC probe_basic shows me XYZAB in the DRO
2 years 10 months ago #288717 by Connor9220
This makes sense. Does that fix your issue with the G0 B0 bug?
You'll need to use a custom_probebasic.py file to relabel A to B and B to C.
Why is your tool changer a Axis if I might ask?
2 years 10 months ago - 2 years 10 months ago #288748 by CNC_ANDI
no that does not fix the bug..
toolchanger is C this time...
i would change them to W but first time i have tried the toolchanger as W the motor was verly slow...
yes for sure on my debian 11 with dev install i´ve done some changes....
but how can i do that on debian 12 with the normal apt install?
i´m searching for a way to make my cutom.py
Last edit: 2 years 10 months ago by CNC_ANDI.
2 years 10 months ago #289010 by Lcvette
Replied by Lcvette on topic Probe_Basic ATC Tool List
does the carousel component utilize an axis setup in the ini? im uncertain and asking, maybe spumco can chime in, he is the resident carousel.comp guru for PB
Moderators: KCJ, Lcvette
Time to create page: 0.327 seconds
