Probe Basic Transition from Axis
2 years 10 months ago #288530 by OldSQL
Hello everyone, I'm a beginner in Probe Basic and I'm trying to transition from an Axis configuration to PB with ATC included, and I'm having some issues that I can't solve due to lack of experience. At the moment, I can open PB, if in my INI file the hal files (io.hal, spindle.hal, postgui.hal) are commented out. When I have not these file calls in the INI config, I can open PB, but it says I have to turn off EStop to be able to start the machine. I didn't have this problem with Axis. I've already reversed the signal call and it continues. Can anyone help me?Attached is my configuration.
File Name: tru.zip
File Size:126.47 KB
2 years 10 months ago #288534 by Lcvette
You need all of those files for pb, use the config conversion document in the sticky section.
forum.linuxcnc.org/qtpyvcp/48401-py3-pro...version-doc-lcnc-2-9
2 years 10 months ago #288535 by OldSQL
Yes, I have already followed this guide and successfully started and configured part of the Probe Basic. Now, I have this problem: is there a way to resolve it without losing all the progress I've made?
2 years 10 months ago #288536 by Lcvette
Did you press estop on the bottom left of the screen?
2 years 10 months ago #288564 by OldSQL
Yes, and it shows the same message.
2 years 10 months ago #288580 by Unlogic
When I migrated from Axis to Probe Basic I encountered something similar due to some e-stop signals in my custom.hal overlapping with the existing e-stop signals in Probe Basic.
I renamed my e-stop related signals to solve the problem.
Moderators: KCJ, Lcvette
Time to create page: 0.062 seconds
