Probe Basic Transition from Axis
2 years 10 months ago #288583 by OldSQL
Okay, do you suggest renaming in the main .hal file or in the halib?
2 years 10 months ago #288584 by Unlogic
Go through all the hal files and check which ones that refer to e-stop, also check out my thread in this forum section regarding the initialization problems I had which forced me to load my customs changes after the probe basic post gui file.
2 years 10 months ago #288590 by OldSQL
2 years 10 months ago #288742 by OldSQL
What is the best recommendation to redo the entire configuration step by step. Any complements to the existing tutorial?
2 years 10 months ago #288769 by OldSQL
I have completed the setup from scratch and now have the PB functioning without errors. To correctly assign all the functions of the PB, I will need to create .hal files and assign them in the .ini file. Would it be possible for someone to share a configuration with ATC (Automatic Tool Changer)? Sorry for being a beginner, the questions might be too obvious, but im trying to learn it from 0.
2 years 10 months ago #288781 by Lcvette
In the atc_sim config subroutines folder is a working atc macros set, i would start there as a template.
Moderators: KCJ, Lcvette
Time to create page: 0.253 seconds
